posted by Scottbo on May 14, 2008
I can turn the dishwasher on but it will not fill with water. I replaced the valve under the front of the dishwasher that the main water line attaches to. Is there something else i can check?
1 Other User Has The Same Problem
Comment by Guest, posted on May 18, 2008
My Bosch dishwasher will not fill with water. I had a clogged sink that is now fixed but because water got underneath the dishwaher in the pan, the sensor won't let it work. How can I get to the water to remove it without calling a technician? My model is 5300
Solution #1
posted on Jun 10, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
I was able to find out the problem. There was water at the base of the dishwasher that was hitting the switch which i guess is for flood prevention. I pulled the machie out and sucked all the water out. I assume you can just take the toe kick panel off and use a wet dry vac and do the same with out removing the unit,
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Bosch 24 in. SHU43 Built-in
Email this problem
Email this problem
Can you Help with these Dishwashers problems?
Bosch 24 in. SHU43 Built-in Dishwasher
drain pump will not shut off
I found the red plunger after I... Answer This...
Exact same problem
Exact same problem
What is the base plate? I... Answer This...
dishwasher wont fill.
Washer runs but will not full.... Answer This...
There is a terrible smell in...
we can't get rid of the... Answer This...
BOSH SHU43 dishwasher
I have a Bosh SHU43 dishwasher... Answer This...
Repair Service
Find Dishwasher Repairman Near You:
Find Parts
