Question about HP Color LaserJet 2600n Printer
HP 2600 fuser unit
Can you give me directions on how to install the fuser unit? Don't have a service manual and so far have not found anything on line.
  • lefatle May 16, 2008
    I would like to change the fuser unit on my printer as i have discovered that with the color print out problem that i have that the fuser unit was having problems giving out the displayed colors.
  • 300 Answers
1 Unplug the power cable.
2 Remove the paper delivery tray assembly
3 Remove two (2) screws from the right cover assembly
4 Remove the right cover assembly, carefully disengaging the catches
5 Unplug the control panel cable.
6 Insert a screwdriver to loosen the release tab on each side of the upper face cover.
7 Remove the upper face cover
8 Remove four (4) screws from the upper cover
9 Lift up and remove the face-down cover
10 Remove the output tray by releasing the tabs.
11 Unplug the harness from the fuser motor
12 Open two (2) clips and remove one (1) clip to remove the fuser connector.
13 Unplug two (2) 3-pin optical encoder wires.
14 Unplug the red high-voltage bias wire.
15 Remove the thermistor wire.
16 Remove the cables from the wiring harness.
17 Remove three (3) screws from the fuser chassis.
18 Gently rocking if necessary, roll the fuser
Use the following procedure to replace the fuser.
1 Align the fuser tabs with their respective holes.
forward to remove.
2 Complete replacement by following steps 1 through 18 above in reverse order.
NOTE When replacing the right cover, align the tabs on the upper edge of the right cover
and lower edge of the face-down cover with their respective slots.
Posted on May 16, 2008
Says I have a paper jam but don't
Remove fuser assembly mounted on the top, check paper input & out put sensors clean or blow air on it to clean the dust, if found any sensor flag dis located, locate it properly, if found damaged replace fuser unit..
Feb 01, 2012 | HP Color LaserJet 3500 Printer
Part number brother 9840cdw fuser
Part# LU4103001
About $150
The service manual will be hard if not impossible to find. They only release those to factory authorized service centers. If you just need it for the fuser replacement instructions then often those will be either in the operators manual which is easy to find or the instructions will be in the box that the fuser comes in.
Good Luck and Thank You for using Fixya.
Apr 01, 2010 | Brother MFC-9840CDW Laser Printer
Need a service manual for a hp 3050 printer so that i can change the fuser unit
Typically HP and other printer manufacturer's such as Lexmark and Canon do not distribute these manuals to anyone who is not a factory authorized technicians.
That said, you might be able to borrow one from a local authorized repair shop.
The R&R of the fuser is not a trivial task. One small ESD can fry chips. Please consider having the repair accomplished at an authorized dealer and that way the work is warrantied.
Don
Nov 23, 2009 | HP LaserJet 1320 Printer
From the printer indicator,the printer is requesting for transfer fuser kit. the percentage is low,down to 0%. What is transfer fuser kit?
GENUINE HP COLOR LASERJET 2600 MAINTENANCE KIT - Kit Includes: 120V(220v) Fuser Unit, Tray 2 Paper Pickup Roller (D-Shaped Roller), Tray 2 Separation Pad Assembly - Includes The Spring Loaded Separation Pad In Holder Assembly - Genuine HP Part
Oct 21, 2009 | HP Color LaserJet 2600n Printer
I have an error code 50.2 it says i need to remove the fuser ,, where is the fuser located
http://www.feedroller.com/Store/Service%20Manual/LaserJet%204345%20MFP%20sm.pdf
This a link to a 4345 service manual. Fuser is in removal and replacement/user replaceable parts. A 50.2 is the fuser is not warming up to temp. A replacement may ne needed. If the fuser was just replaced you would want to check this pdf
www.lbrty.com/tech/ta4xxx.pdf
Jul 06, 2009 | HP Office Equipment & Supplies
Install fuser
please reference the service manual from page 89 shows how to remove and reinstall the fuser unit, download from:
http://www.google.ca/search?hl=zh-CN&q=HP+2420+laser+jet+service+manual&btnG=Google+%E6%90%9C%E7%B4%A2&aq=f&oq=
choose second one PDF file and download for a while. then go to page 89.
hope help you to fix it , and please take a rating let me know how much helped you thanks!
May 16, 2009 | HP LaserJet 2420 Printer
Error 58.04
This is from the service manual and should help you determine if you need to call in for service. If is in warranty I would anyways since the fuser would be covered if at fault.
58.04 ERROR To continue turn off then on. The low-voltage power supply has experienced an error.
1. Reinstall the fuser. Check the connector
(J1901) between the fuser and product.
Replace the cable or fixing unit if the
connector is damaged.
2. Reconnect the connectors of the fuser
control PCA (J303, J305) and the DC
controller PCA (J107).
3. Replace the fuser. See Fuser
on page 191.
May 03, 2009 | HP LaserJet 5200tn Printer
Printer HP ColorLaserJet displays Fuser Error
My HP Color Laserjet 2600n Printer is giving me error as
" 50.2 Fuser error " . then every time i have to reatart my printer.
please give me suggestion.
thanks and regards.
ajinmumbai
Dec 05, 2007 | HP Color LaserJet 2600n Printer
Cleaning
Yes , you can manually clean the printer usually you can use a lint free cloth to do so. I don't recommend taking canned air and blowing it out. As far as the ghosting goes yes you seem to have a fuser problem and best case is to have service done to replace the fuser!! Hope I have helped!!!
Nov 13, 2007 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
509 people viewed this question
Ben Johnson
