Question about Refrigerators
GE side by side Refrigerator approx. 8 years old. Fridge side barely cold.
Freezer side working. Refrigerator side barely cold on coldest setting, light does come on.
  • heather47203 May 14, 2008
    Approx. 8 years old. fridge side barely cold, trying to figure out how expensive to fix, or if I should just get a new one.
    Guru:
  • 93 Answers
With your fridge, does the light go out when you shut the refrigerator door?
That could be your issue, that light running inside will create Alot of heat.
Also check to see if there is air circulating from the freezer to the fridge side through the damper. The damper is on the Fridge side left wall up towards the top. That is where the cold air gets to the fridge side. If that damper doesn't open that will also cause your problem, Let me know how you make out.
Bill
Posted on May 15, 2008
We have a GE GTS 222C top freezer refrigerator, approx. 8 years old. The freezer works fine but the frig doesn't cool and is at the highest setting. We had to turn the electricity off for some wiring...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 23, 2010 | GE Refrigerators
Hello...we have a JCD2289AT that is 6 years old approx...frezer and ice maker are working fine butr refrig seems to not hear a cold temerature even after setting to the coldest setting. I pulled the unit...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 19, 2010 | Jenn-Air JSD2789GES Side by Side...
Top mount freezer won't cool, fridge works fine.
check for compresor operation. a relay on compresor could be out
Feb 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is very cold, refrigerator not cooling on Maytag side-by-
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
s
Nov 25, 2009 | Maytag MZD2766GES Side by Side...
Refrigerator too warm on coldest setting
The refrigerator coos from the bleed over from the freezer, See if the fan in the freezer is working properly and the crossover duct/vet is not obstructed or close.. Ck to make sure the control in the fridge is working,
Nov 21, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Refrigerators Logo
138 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
