Question about Goodman CKL60AR60 Air Conditioner
MY OUTDOOR A/C WENT OFF! BUT THE ONE INTHE INSIDE STILL WORKS ,BUT IT IS STILL HOT. WHAT IS THE PROMBLEM???
    Sergeant:
    Novelist:
  • 193 Answers
In most cases the outside unit is on a seperate breaker than the inside unit. Check your breaker box to see if any of the 220 volt breakers are tripped out. There may also be fuses or a breaker at the unit outside.
Posted on Sep 11, 2010
Wall AC Unit blows cold air for a little bit then blows hot air. If I turn it off for a while, it will do the same thing.
When you mansion water in the pan, do you mean the indoor coil pan or the outdoor catch "pan"? I've seen some models have a drain plug that's on the bottom of the outdoor panel or underneath. And that plug should remain installed. It uses that water to cool the copper freon tube that curves along the bottom of the outdoor section. With plug removed it can overheat. Basically it does not drain onto the ground outside, it retains its water. And the air entering side of outdoor coil is clean? May sound like repetition(forgive me). The side you see clearly is the air leaving side. The dual shaft motor has a run capacitor that may be weakening. And the outdoor air that passes thru the outdoor coil may be recirculating out then directly back in to the unit causing it to overheat. Anything blocking airflow outside? 10 mins of runtime then shouting down tells me its overheating. It may even be the electrical circuit. Loose connections can cause high amperage, low voltage issue and cause the ac load to over amp. Over amp=over heat. Hope this helps!
Jun 27, 2015 | LG LWHD1800R Wall/Window Air Conditioner
My tv went off when i was watching it what went wrong?
remove the power lead, wait 2-3 minutes and try to power back on. If that fials - repair center it is ...
Apr 07, 2014 | Protron PLTV3250 32 in. LCD Television
1994 jeep laredo stalls when hot. Won't start till
by pass the starter motor see the diagrams attached, and chart for troubleshooting. God bless you
159fe92a-9a7e-4f86-bf05-dd0c28d0ca5b.gif7a5969b1-4b92-441e-8cbf-df7c579bfc60.jpg260df33a-d478-404a-8d61-b6596b1a7499.gif
Sep 30, 2013 | Cars & Trucks
Water pump and ignitor do not work
took coleman away for weekend wouldn't work. Very dissapointed, was cold would have loved a hot shower. Had charged battery, when I went to start it. It wouldn't go, light come up as battery low tried it on car charger still no luck. Got home and looked up this site told me to try taking filter off pump and putting a long nail inside to turn pump to make sure it wasn't seized. And guess what every thing works well thank god, water temp was dodgy as well but now all good. Thanks to people that do reply to these sites, it has saved me a lot of money and frustration.
May 23, 2011 | Coleman Hot Water On Demand
96 Blazer A/C WILL NOT BLOW ANY AIR HOT OR COLD
BEFORE YOU DO ANY HARD WORK TURN ON YOUR A/C AND BLOWER AND TAP THE BACK OF THE BLOWER MOTOR WITH A SMALL HAMMER IN A COMPLETE CIRCLE. SOUNDS LIKE YOU JUST HAVE SOME STICKING BRUSHES IN THE BLOWER MOTOR.
JAMESFWALKERJR2006@YAHOO.COM
Aug 25, 2009 | 1996 Chevrolet Blazer
2002 tahoe temperature is blank
maybe faulty you can get them at wrecking yard fairly reasonable! good luck!!!
Jun 21, 2009 | 2002 Chevrolet Tahoe
Heat pump not running
check your house circuit breakers first that should be labeled heatpump or outdoor unit
make sure it is on and or not tripped
then if you have a box outside near the outdoor unit open it up and see if there is a breaker or maybe fuses that could be blown
May 26, 2009 | Goodman CPLE24-1 Air Conditioner
Samsung 1.0 ton(split) AC stops working during 36-37 degree C.
i believe you have a high pressure switch on your condenser that is going bad .it is a switch that has two red wires connected to it inside your outside unit
Feb 11, 2009 | Samsung Heating & Cooling
Hello my name is Floyd and I have a 1984 dodge ram d150 and I have a promblem with my alternator it is getting to hot and blowing up my battery and now I might have other promblems possible with wiring,...
it sounds like your alternator is putting out to much juice, you would proberly have to hook it up to a machine that tells you how many volts it is putting out and most of the auto part. stores will check it out for free.
Jan 20, 2009 | 1984 Dodge Pickup 4WD
Humidity too low
I corrected the problem...RH is rising nicely!! Installed by "professionals" on my Trane XV90....I redid their wiring and now have the following setup...
600A water supply coming from hot water line.
Removed orifice inside incoming feed tube.
control incoming water flow from saddlevalve on hot water supply ( make sure its a nice solid flow, no drips, but no "force" too it either)..enough to insure entire evaporator unit is wet and water is slightly flowing out of bottom to drain.
I also have it wired to run when ever the furnace blower is on. Heat or no heat. XV90 is variable speed, and by doing this the 600a is always adding moisture, until it reaches correct RH%
Also, I disconnected the outdoor temp sensor. I went to Radio Shack and bought a 47K ohm resistor ( 1/2 watt....4 pack for 99 cents). Installed that in place of outdoor sensor...now runs in manual mode. Have unit currently set to number 5.
Jan 14, 2009 | Aprilaire 600 Humidifier
Goodman CKL60AR60 Air Conditioner Logo
50 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
