Question about ViewSonic VPW425 42 in. Plasma HDTV
Originally I had a problem with my Viewsonic VPW425 TV. The unit was not turning on. I just replaced the Power Supply board in the unit. Now it turns on, but just stays on for a few minutes, then I loose the picture. Was there an adjustment that I had to make? Please help. .
  • aromim Sep 13, 2010
    I have two fuses that I need to replace. They are both ceramic but I am having a world of trouble finding where to get them. They are an:
    F8701 T6 3AH/250V
    F8702 T6 3AH/250V
    Do you know where I can get them?
  • 666 Answers
No it sounds like you probably didnt need a new power supply but simply needed to check your fuses this error normally occurs when a fuse or capacitor has blown and will either be really cheap or really expensive to fix depending on which it is the fuse change should be possible on your own but running a diagnostic to find out which circuit has a blown unit would require some technical assistance and tools
hope this helps
Robb
Posted on Sep 11, 2010
Viewsonic LCD TV N4280p haven't picture and no sound ,but turn on
Hello
There is some missing output voltages from the power supply regulator board to your tv. Normally, these board are replaced as card basis. some of them are repairable too. You have to check this board first, to find whether it is repairable or not. If not replace it as card basis.
2_8_2012_4_19_29_pm.jpgTwo vies of the power baord to your TV is attached here. This board can be purchased either from the authorised service center for Viewsonic at your town, or from any electronic sparepart selling shops at your town.2_8_2012_4_20_00_pm.jpg
Feb 08, 2012 | ViewSonic N4280P TV
Viewsonic VPW425 No inputs working
Seem like the power supply hav blow off inside the unit.
Jul 02, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
Viewsonic 425 shuts itself off.
im not too familiar with viewsonic but it sounds like an ovrheating issue. i would monitor th power supply and the y sustain board. they seem to be the most common failures in plasma tvs. if you can tell me the panel model number inside the tv i may be able to assist you further...
Oct 22, 2007 | ViewSonic VPW425 42 in. Plasma HDTV
When i turn on tv the green power light blinks and i have to hold the power button in on the tv for it to turn on?
The power supply board is dead.That the board where the power a/c cord go into it.Replaced the
power supply board ur tv will work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 24, 2010 | ViewSonic N4060w 40 in. LCD TV
No picture or indication its on
did you check if the bulb was burnt out
Jan 13, 2010 | ViewSonic N4785p 47 in. LCD TV
VIEWSONIC VPW425 42' PLASMA SOUND FADES ALL THE WAY OFF
I have a brand new Panasonic 42" tv, once in a while the sound fades out and then fades back in right away. I have it hooked up to a high def cable box with high def cable.
Jan 16, 2009 | ViewSonic VPW425 42 in. Plasma HDTV
Blue color gone
This sound like the color wheel needs to be replaced!
That should fix ya!
Dec 17, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
Viewsonic LCD TV Power Issues?
You have probably already resolved this, however if your TV is 32" or smaller it likely has bad capacitors in the power supply. If you try it once more take note of: Does the red standby light still come on? If so, unplug the unit and either replace the capacitors in the power supply or purchase a new power supply from a Viewsonic service centre. Don't keep plugging it in and trying to get it to work in this condition or you'll completely blow the supply. If the standby light no longer comes on and the tv will no longer power up, the power supply board is toast. Get a new one and install it (they are pretty easy to install, unscrew the remove the back cover, remove the shield covering the boards, unplug two plugs going to the power board and remove the board. Install the new board and reassemble.
Aug 03, 2008 | ViewSonic NextVision N2010 20 in. LCD...
Viewsonic n3752w plasma television
Viewsonic normaly does not sell service manuals to non contracted servicers. You can call Viewsonic and see if they will sell you a service manual.
With the Pasma and LCD sets that we work on (we are not a Viewsonic rep), they are all supported from the manufacture for mainly board swap only, just like in a computer.
The circuit boards are mostly using SMD technology mounted and embeded in to multi layered circuit boards. Troubleshooting these boards is like trying to troubshoot computer boards. There is almost no supported component level service. In any case, you would also have problems to buy non generic type replacement components.
The service manuals do not always have detailed schematics of all the boards. The manual is more for modular assembly, specific types of service, and for doing the factory level alignments.
Good Luck!
Jerry G.
Apr 09, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
TV power cycles but does not come on
This website has many service manuals that you can download for a fee
www.ServiceManuals.Net
Good luck.
Nov 12, 2007 | ViewSonic VPW425 42 in. Plasma HDTV
ViewSonic VPW425 42 in. Plasma HDTV Logo
206 people viewed this question
Top ViewSonic Televison & Video Experts
Jaime Hernandez
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
