Question about Goodman Heating & Cooling
Ac unit freezing up - Goodman Heating & Cooling
  • 407 Answers
The most common problems that causes the lines to freeze up are the charge of refrigerant in the system or a restriction in air flow. The charge will have to be checked by a technician with the proper tools, the air flow can be checked yourself though. You will want to check your return air filter to make sure it is clean, then when the unit is NOT froze up, turn the fan on to the furnace and see how much air comes through the vents. If you do not have the same air flow or no air at all, your indoor coil might need to be cleaned or your blower motor isn't coming on, which will usually be a bad capacitor or the motor itself. Hope this steers you in the right direction and good luck!
Posted on Sep 11, 2010
We have a Goodman AC Unit and the pipe continues to freeze.
either the inside coil is dirty or system is overcharged.
May 14, 2014 | Goodman CLQ36AR49 Air Conditioner
The ac unit freezes up when it gets really hot and humid out and the ac blows hot air. what would cause this problem? it seems like the unit is freezing up and getting too hot and not allowing itself to...
This is caused by the low pressure AC compressor cycling switch, it is a very cheap part and located in the larger of the two AC lines coming from the AC compressor.
Jun 22, 2011 | 2004 Chevrolet TrailBlazer
Ice fallingfrom split ac
Try turning off the ac unit for about an hour.(Your might have too small of ac unit or just have the ac set too low..Causing the coils to freeze.
May 27, 2010 | LG Art Cool LA121CNP wall/window Air...
Freezing up, home ac unit no air flow after running a while
A low freon level in the unit can cause them to freeze up. Are the fins behind the filter clean?
Jun 19, 2009 | Whirlwind FH-778 Air Conditioner
Weather King 13AJA36A01 AC freezing up at night
check the inside coil is dirtyor may be low on freon
May 14, 2009 | Weather King 12AJA4801AH Air Conditioner
Ac freezing up
Most freezing is caused low refrigerant or temp control will not shut off unit if there is no humidity problem.
one or the other can be checked by an refrigeration tech.
May 01, 2009 | Ruud UBHC Air Conditioner
AC not producing cool air
If this is a newer system there will be a freeze sensor. It may be low on refrigerant. I would check the obvious things first. Are the filters and coils free of debris? Finally only set the temperature to your comfortable temp not lower as this can cause freezing too (generally not below 70 degrees)
Jun 23, 2008 | LG BG8000ER Air Conditioner
My ac unit
air conditioners freeze up for one of 2 reasons, #1 restricted air flow, is the filter, /orthe evaporator (cool) coil clean?
#2 it is low on freon, causing the coils to be colder than they should be.
Nov 13, 2007 | Heating & Cooling
Heating & Cooling Logo
75 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
