Question about Acomdata (HD250UE5-72) (HD250UE572) 250 GB Hard Drive
Bootable drive I have a acomdata external 2 gig hard drive and I need be able to boot from this drive. I need help. Thanks
    Genius:
  • 2,785 Answers
Check in your bios for setting boot from external device
Posted on May 14, 2008
Hello, I had purchased one of your external hard drives and used it for years. Now I can not get it to boot up. I have a older Mac 4G workstation. my question, how do I get it to boot up? Thanks
If the unit has power, and is connected, the drive inside the case may have failed. Most external case hard drives have short lifespans due to the heat generated and held by the case.
Jul 04, 2011 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Acomdata HD120U2FE-72 120 GB external Hard Drive
OK, 2 things to check. First and foremost, when you plug it into the PC does it make that nifty noise to let you know it sees a new piece of hardware?
Second, if it does, you probably need to initialize the disk. Hit the windows button, right click on computer, and select manage. Under the storage category highlight Disk management. If you see the drive there, you can right click and select initialize, or format. From there the system should see the drive.
Feb 06, 2010 | Acomdata HD120U2FE-72 120 GB Hard Drive
It does not boot
Ok is ya PC set to boot off a USB removable drive?, is it set in BIOS?, Do you have a Boot track on the hard Drive? To boot it must be formatted and have a bootable partition and set to active, as well. as set to boot from USB.
Jan 26, 2010 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
Acomdata 250 external (SATA) hard drive not showing up on desktop
be safe
go on line to acomdata web site and down load the driver from there
Oct 11, 2017 | Acomdata (HD250SE5-72-PCI) (HD250SE572PCI)...
I have a motherboard that has only has one ide conncetions
what you should do is make the 300 gig as second drive and your primary drive is the 80 gig so that you can view and back-up the contents inside it. If you going to install a new copy of Operating system that would be in the 80 gig so that you don't need to format your 300 gig and make it as second drive. Hope this could help you..Thanks..
Oct 24, 2009 | Computers & Internet
Problems with Hard Drive
Appreciate the direct "Ask Me".
T your concern:
  • initially, pls verify that it is indeed an external storage problem rather than a laptop USB issue by trying other USB devices and determine if they are recognized and working;
  • disassemble the enclosure of the Acomdata external hard drive and remove the actual hard drive;
  • you would need the use of a 2nd PC, a desktop that could accommodate the HD from the Acomdata (IDE or SATA);
  • install the HD from the Acomdata as a Secondary Master or Slave internally to the 2nd PC;
  • boot the 2nd PC and determine if the HD from the Acomdata will be recognized as a local drive;
  • chances are that the partition of the HD from the Acomdata was messed up. This would explain the blinking blue light;
  • download and install a file recovery program. An example is GetDataBack (unfortunately not a freeware but DEMO is available) and do a recovery. It would take some time based on the size of the HD from the Acomdata;
  • temporarily save the recovered data in the 2nd PC. You can burn this likewise into a DVD backup should the 2nd PC be capable of that;
  • after recovery, re-partition and format the HD from the Acomdata while still attached to the 2nd PC;
  • should the re-partition and format be successful, you can transfer back the temporarily saved recovered files;
  • a nice, simple, fast and safe partitioning/formatting software is Partition Magic (unfortunately not a freeware but FREE TRIAL is available).
  • should the re-partition and format be not successful, you can replace only the HD and/or claim warranty.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 01, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Forgot Acomdata External Hard Drive Password
Did you every get this resolved? I have same probelm.
Apr 08, 2008 | Acomdata PHD060U2E-54 60 GB USB 2.0 Hard...
Cannot copy large files to drive
Your external drive is formatted for FAT32 which only will accept max 4GB transfers. Try NTFS format. Take a look at page 47 on this file then go from there. Hopefully this helps. http://www.acomdata.com/AcomData_Downloads/3.5_External_Hard_Drives/E5_Series_Hard_Drives/HDxxxSE5-72-PCI/M-HDxxxSE5-72-PCI-v1E.pdf
Jan 11, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Acomdata (HD250UE5-72) (HD250UE572) 250 GB Hard Drive Logo
87 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
