Question about Gateway 835GM (835GH) PC Desktop
I have a 835-gm model . My montior will not come after a thunder srom. Lights flickered off and on. I have a new motherboard installed but still will not come on. The fan on the power sourc ewiill not come on also.
2 Suggested Answers
  • 324 Answers
SOURCE: My monitor would not come on after a thunder
do you have a surge protector? if not then you probably popped the little fuses in the back of the monitor, at the very least.. you could have blown a diode as well, as far as the comp, see if it has a fuse, it should be close to where the power comes into the machine
Posted on Sep 12, 2010
Testimonial: "Thank you"
Keyboard port on both my thunder i7525 motherboards dont work
You should just buy a cheap USB keyboard and use that instead. That motherboard model might have been plagued by a bad batch of ps/2 keyboard connectors.
Jun 14, 2012 | Tyan Thunder i7525 Motherboard
I have a 2005 chevrolet silverado my dashlights and headlights are strobing how do i fix them?
Are you having problems with headlights or interior lights flickering or dimming for no apparent reason? You are not alone! Many other consumers have reported experiencing the exact same problem. The problem is seen in many different GM makes and models including, but not limited to: Chevy Suburban, Tahoe, Silverado, Corvette, Camaro, Firebird and Malibu's and Pontiac Aztek's.
Why Are My Headlights Flickering?The headlight flickering or dimming may be caused by a intermittent low voltage output from engine vibrations. When this occurs, a voltage spike causes the voltage regulator to reset. During the reset, generator output drops to almost zero. This is a known issue with GM cars and the correction involves replacing the alternator. Would recommend seeing dealer for proper alternator application to resolve concerns. Probably has a superceded part number to indicate internal changes.
Sep 18, 2011 | 2005 Chevrolet Silverado
My monitor would not come on after a thunder strom. Llights flickered off & on. I have installed a new motherboard. Montior will still not come on. Also my computer fans on the power source will...
Sep 12, 2010 | Gateway 835GM (835GH) PC Desktop
ASUS ENGT240 Graphic card installation failure
try installing the driver first then disable the motherboard display adapter then then shut dowm computer put card in . change montior cord to card  boot up   ( make sure that resoluting in card driver software is right for you before you do alll the above .some time the card defalt at install is to high for montior to handel by card maker wants to show off) it should work .sonetimes windows plug and pray can be flaky hope this helps should work unless you card chipset is not complable with motherboard
Apr 03, 2010 | ASUS NVIDIA Graphic Card
Hello, i have a Packard bell igo , that when i try to boot 3 lights on the bottom of the screen and the cd keeps trying to run and also the screen is flicking , what should be the problem ?
Packard bell igo, is a notebook..what model is it. if the screen starts flickering on the go, then you could be having a flex problem or motherboard problem. but if it loads and later flickers, then you should check the installation. please explain a little bit more if this doesn't help.
Regards
Mar 04, 2010 | Computers & Internet
How to install it without CD installer
Problem for A4tech PK-835 (890891000025) How to install it without CD installer
Mar 03, 2010 | A4tech PK-835 (890891000025)
Please help. i need to download audio and video drivers for a tyan thunder k8w (s2895). where can i find them?
HI
CLICK THE LINK:-
http://www.tyan.com/support_download_drivers.aspx?model=S.S2895
ENJOY
RATE ME DEAR
HAVE A GOOD DAY
Jan 07, 2009 | Tyan Thunder K8WE Motherboard
A4 tech pk 835
i like install this model pc camera
Jan 30, 2008 | A4tech Xmaster PK-835 Webcam
Coleman patio heater 5040A770
These heaters are not designed to be operated below 40 degrees F. If the heater is used below 40 and if you have a gas tank containing less than 25%, the unit will not operate for long and will start going out. If the heater all of a sudden goes out without showing any flickering or pulsations, you have a bad gas valve, there is no thermocouple on this model. Fill your tank and try the heater again. If it continues, give Coleman a call at 800-835-3278.
Nov 15, 2007 | Coleman (5040B750) Patio Heater
Gateway 835GM (835GH) PC Desktop Logo
47 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
