Question about ASUS Eee PC 900 Notebook
I have an Eee PC 900SDXP and the display doesn't work...the fan is on & the lights are lit, there is power. When screen comes up to F2 or Tab, I do F2...now the ATAPI drive is incompatable...Help!! my email is exoticentpm@yahoo.com
    Guru:
  • 689 Answers
Try F9 whilst booting(every other boot)
choose restore setting
press"E"
Press"B"
Go through first few configuration pages
Posted on Sep 11, 2010
List each function key
o F2 boot to BIOS.
o F12 boot device menu.
0 Fn+F1 sleep/hibernate per power management setting.
o Fn+F2 battery charger ON/OFF.
o Fn+F3 DCP Power Manager Battery Status.
o Fn+F4 numlock ON/OFF for embedded Fn+numeric keypad.
o Fn_F5 scroll lock ON/OFF.
o Fn+F7 DCP.
o Fn+F8 display device.
o Fn+D display OFF/ON (conserve battery without shutting down entire system).
o Fn+Z reset fan temperature table and sensor.
o Fn+Right-Arrow keyboard illumination OFF/ON Auto ALS (lit upon input in dim lighting)/ON (lit upon input). Use DCP to set input device, brightness, and auto OFF delay.
o Fn+Left-Arrow display Ambient Light Sensor OFF/ON (brightness varies with ambient lighting).
o Fn+Up/Dn-Arrows override display brightness until boot to BIOS setting and/or power mananagement setting.
o Alt+Fn+F11 screen shot.
Jul 09, 2014 | Dell Latitude E6400 Notebook
Asus Eee PC 1005HA wontl load OS
what key do you see during the boot up process
you should see a certain key it will be very quick you might have to restart a few times to get a good look
try pressing the delete key
hope it helps
Apr 09, 2012 | ASUS Eee PC 1000HE Netbook
I have an Asus Eee PC 1001ha series, with Windows XP. Whenever I turn it on it displays the grey asus screen with the phrase "press F2 to run Setup, Press TAB to display BIOS POST Message",...
My suggestion is better to send it on the technical around on your area, to prevent any further damage. And also backup your files by removing your hard disk and slave it to other computer. Just use any converter of mobile hard disk to become a USB type drive. Hope it helps thanks.
Sep 21, 2011 | ASUS Eee PC 1000HE Netbook
When i turn on my eee pc i get the message "Press
Please pull out your hard disk and put it back after 10 seconds. Your laptop will be start as normally.
Thanks
Jun 27, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
ASUS Eee PC 1005 HAB it won go after the "press f2 to run setup, press tab to display BIOS POST message" screen. When i turn it on it makes a sound inside the computer for like two seconds after...
It seems something wrong with the Hard disk, remove the Hard disk and memory card and reset them, then start your computer,,,If doesn't work, try more times, remove graphics together is better
Jan 10, 2011 | Computers & Internet
I have no display in ASUS Eee PC 1000H PC Notebook but power and light is there
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 16, 2010 | ASUS Eee PC 1000H Laptop
I have a toshiba laptop a3056872...on a friends pc now....when i go to turn it on..all the lights come on....the page tthat says toshiba innovation....hit f2 or f12....it doesnt go any further i have a...
1. Remove the battery & switch on the PC in AC mode.
2. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
3. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
4. If still no display, connect an external monitor, check if display is comming.
5. If Display is coming then your LCD is faulty and need to replace.
Aug 23, 2010 | Computers & Internet
Computer does not start up
Please reset the system... Disconnect the power adaptor. Remove your battery, press several times on the Power button of the Laptop without the battery and power.. and let me know.
Jun 06, 2010 | ASUS Eee PC 1000HE Netbook
I was told press F2 simultaneously on startup, nothing happened
You need not to press F2 or tab or escape unless you need to do so. If your system is ok, it'll automatically boot up, but if there's boot up problem with your system, then that's different. Thanks for using FixYa.
BIOS POST message cannot be displayed and Setup does not run
As soon as your computer turns on, start pressing F2 simultaneously until it enter the CMOS setup.
ASUS Eee PC 900 Notebook Logo
219 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
