Question about RCA F36650 36" TV
My RCA has a black block come up in the bottom of the screen? We have Dish Network Satellite and have programed the remote from the remote code guide. TV volume and channel changer work, but picture is a bit fuzzy too? How can you fix that?
    Novelist:
    Champion:
  • 286 Answers
This has hopefully been resolved for you, but if not, here are some steps to go through. The black box that comes on the screen is usually signaling that closed Captioning is activated on the tv. Closed captioning does not run through the DISH Network receivers, so you can turn that feature off in your tv settings. The fuzzy picture could be a few things. You will want to check that all of your cables on the back of the receiver box and tv are tight as possible, and also make sure that the tv is on the correct channel. If you are in the room with the receiver, the tv will need to be on channel 3 or 4, and sometimes an input; usually video 1 or 2. If you are in a number two room, where there is no receiver, than you want to make sure that the tv is on channel 60 or 73. I hope that this helps!!!!!
Becki Barned
DISH Network Customer Service
Posted on Jan 20, 2011
IM TRYING TO PROGRAM MY RCA TV REMOTE TO DISH NETWORK. PRODUCT INFO. MODEL # L40FHD41YX9 SERIAL # J516C40DI SERIES # F2 PLEASE CONTACT ME WITH SOLUTIONS TO THE PROBLEM
Hi amielynn221, my name is Mike Houston of DISH Network and I see youwant to program the RCA remote to the DISH Network receiver. We do have thecodes to program our DISH remote to the RCA TV we do not have the codes toprogram the RCA remote to DISH Network receivers, I will send a link to helpwith these steps. http://remotefinder.rca.com/default.aspx?site=rca
Apr 19, 2011 | RCA RCRN04GR Remote Control
I need the code for my remote control dishnetwork 311
Hello, I hope that this has been resolved for you already, but if not, here are some quick and simple steps to run through! Just follow the link below to get this remote working. Steps 1-5 are to program the remote to the receiver to control channels, and 6 and on is to program the remote to the tv to control the volume. I hope this helps!!!!!!!
http://www.dishnetwork.com/SupportSection/remote-setup
Becki Barned
Nov 07, 2010 | RCA DISH Network(r) 311 Satellite System
I just programmed my dish #2 remote control to a tv. The remote is not working. I cannot access the guide menu "etc". What do I need to do? This is a second tv and the remote worked just fine before....
It sounds like the remote would need to be programmed to the receiver itself. It may have lost it's programming when the TV code was put in.
To program remote to Satellite:
1. Access System Information screen.
2. Note the # on the bottom where it was Secondary Remote Address.
3. Hold SAT until all buttons on top of the remote light up.
4. Let go and while it's blinking enter a number between 1-15 and press #
5. Press record 3 times and test remote.
Tommy Faust
DISH Network
Sep 25, 2010 | DISH Network IR Remote Control
Dish network remote to run RCA DVD player
I had rca remote that did not recieve ir signals but rf signals instead. Check online with rca or in owners manual for what type of signal factory remote sends. The dvd player I had was 5 dvd and that was the case. Dish might have an option like direct tv where you can program rf signals as well. Call dish network support or look online
Apr 25, 2010 | DISH Network IR Remote Control
Just purchased RCA HD Tv. What is the RCA code
We would be happy to help you with getting your DISH Network remote to control your RCA TV. We're going to start by pressing and holding the TV button located on the top of your remote until all mode button back lights come on, and then release. Use the number buttons to enter the codes for your RCA TV here are some of the codes we currently have: 503, 627, 633, 725, and 505. Press the pound (#) button. To check that the code works try several different functions on the remote to make sure it will properly operate the TV. Remember that some codes may not be compatible with your equipment. If this is the case, try the other codes listed for your RCA TV until you find one that is compatible with it.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Feb 11, 2010 | RCA DISH Network(r) 311 Satellite System
After programming my NEW Harmony One Logitech remote I can't get it to change channels on the Dish HDTV DVR along with a bunch of other problems.
To control a Dish Network PVR/Satellite, it needs to be set to respond to the default Remote Address (1).
To reset your Dish Network PVR/Satellite to the default Remote Address:
1. Press SYSTEM INFO on the receiver's front panel. The System Information screen displays on the nearby TV and shows the Remote Address.
2. Using the original Dish Network remote, press and hold SAT on your remote control for about three seconds, until all of the mode buttons light up, and then release SAT.
3. Using the NUMBER PAD, press the 1 button
4. Press POUND (#). If you entered the address correctly, SAT will flash three times.
5. Press RECORD. Make sure the Remote Address you see on the System Information screen is 1.
6. Press the SELECT button on the front panel to close the System Information screen.
7. Your Harmony remote should now control your Dish Network PVR/Satellite box
NOTE: Dish Network PVR/Satellite receivers sometimes have two tuners, allowing them to be used in more than one room on different TVs. Harmony remotes can only control a Dish Network receiver's main tuner while still in the same room with direct line of sight to the device.
What other issues are you having with the remote?
Dec 25, 2009 | Logitech Harmony One Advanced Universal...
Need code for 32in.olivia tv
Remote manufactures and service providers continuously add support for new TV products. If you have the following Satellite or Cable Systems, try these remote codes for Olevia HDTVs.
Also available is the Olevia Universal Learning Remote RC-LRN that offers component programming of most video hardware including your Cable or Satellite Receivers, VCR's, TiVo’s, DVD, Blu-Ray or even HD- DVD players. The learning remote is available at 866-965-3842
Dish Network Remote Codes 506 or 127
could try Dish Network..Remote Codes 506 or 127
Satellite TV Systems Dish Network Remote Codes 506 or 127
May 23, 2009 | Syntax Olevia 537H Television
Dish Network remote code for RCA 20F510TD TV/DVD
hello and please help.
want to know the codes and way to program this rca dish remote model RCR500SAM1 for my Toshiba tv.
ive done it a few years ago but forgot.
so i need the codes for toshiba tv and way to program this rca dish network remote.
grateful,
kay
Jul 26, 2008 | RCA 20F510TD 20 in. TV/DVD Combo
Don't Know how to program Dish satelite or tv with my remote.
to program the dish remote to the receiver you need to access system info, if there is no system info button on the receiver turn the receiver off and press the up arrow on the front panel, then press record on the remote, to change the remote address hold down sat until all buttons illuminate, enter number between 1-15, press pound sign, then press record
to address a remote to the tvyou need the remote code for that brand or you can do a power scan
Jul 20, 2008 | RCA DISH Network(r) 311 Satellite System
RCA F36650 36" TV Logo
107 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
