Question about Zebra LP 2824 (clp2)
I lost zebra lp2824 printer driver,need help how to get it
    Champion:
  • Zebra Expert
  • 285 Answers
Hello, i have win7 x64 and i dont find the lp2824 driver for it, what to do?
Click on the link below and follow the list to the bottom and click on "Zebra". Save the file and run it.
http://www.seagullscientific.com/aspx/thermal_95.aspx
Feb 11, 2011 | Zebra Eltron LP 2824 Thermal Printer
Can you use a 32 bit zebra lp2824 printer on windows 7?
Sorry to read about your problem, I hope this helps you out.
Yes you should be able with asci generic print driver
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 21, 2010 | Zebra LP 2824 Printer
My zebra lp2824 barcode printer does not print, i downloaded zebra lp 2824 from nice label still it not working, when doing print test it will print only some letters....what to do
check the driver, and the setings from the driver. Try ZDesign Driver or seggul driver from WWW.seaguscientific.com, and print the testpage, chech the connection (port) if is seria (com) check the setings speed etc...
Nov 09, 2010 | Zebra Eltron LP 2824 Thermal Printer
Problem with my Zebra LP2824 printer
You have to calibrate the printer to solve this problem
Check following to solve this problem
1)Press the feed button and hold it for 1-2 seconds switching printer on.It will calibrate the labels.
2)Install Zebra Designer driver from CD.After installing Zebra designer Add printer Zebra Designer LP2824.After installing driver right Click the printer Zebra Designer LP2824 and go to printing preferences then select advanced option and calibrate printer.It will calibrate printer
3)Check the label size is properly set in printer or not.Label width and label height in printer settings should be same as label which you are using .
Aug 22, 2009 | Zebra Eltron LP 2824 Thermal Printer
Printing a 2.25 in label on Zebra LP2824. Prints
Recalibrate the printer and you should be good to go. Do this by turning the printer off, press and hold the button and turn on the power. When the light flases red let go and it will calibrate, at the end it will do a printout. Reboot the printer and your fixed.
Jul 28, 2009 | Zebra Eltron LP 2824 Thermal Printer
Zebra LP2824 not printing
Sounds like you put your printer into line mode. Line mode prints code so you can see what is sent to the printer to look for possible mistakes in the code.
To switch from line mode back to page mode.
  1. Turn printer off.
  2. Press and hold the feed button down. And switch printer on.
  3. Release the feed button when the LED flashes red.
  4. When the LED flashes green, press down the feed button.
  5. When the LED flashes amber release the feed button.
  6. Try printing now that the printer is back in page mode which is used for print your labels; line mode prints the labels code.
  7. Do this fast or else it wont work if you are slow.
Jan 13, 2009 | Zebra LP 2824 Printer
Zebra LP2824 Not Printing
I had the same problem and could not fix it but called Zebra headquarters and they gave me this solution and it works! It sounds crazy but it works. Turn off the printer on the switch on the side. press and hold the button on the front of the machine while you turn it on. The light will turn red then release the button the light around the button will then turn a solid greed then blink green. While it is blinking green press and hold the button again until it the light turns orange and then release the button. This apparently puts your printer into line mode or something but anyway it works!
Oct 02, 2008 | Zebra Eltron LP 2824 Thermal Printer
Slow printing to LP2824
This appears to be normal operation.
Aug 14, 2007 | Zebra Eltron LP 2824 Thermal Printer
LP2824 feeds a label but wont print on it?
can you give more info? it sounds like you driver is set to thermal transfer mode but you have a direct thermal printer (LP not TLP)
Apr 24, 2007 | Zebra Eltron LP 2824 Thermal Printer
Zebra LP 2824 (clp2) Logo
154 people viewed this question
Top Zebra Computers & Internet Experts
Mike
Gareth Cockram
Gareth Cockram
justwinwin
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
