Question about Emerson Fans Dryers
Our four light Emerson fan has two lights (across from each other) that do not work. They appear to be connected by the same blue wire.
  • 96 Answers
If you have a pull chain I would check that switch. If not check all your wiring and make sure everything is secure.
Posted on Sep 12, 2010
Where can I get a rhine uc7067 b?
I have one like that. The capacitor connects to the motor; it has nothing to do with the light. You can try to "reset" the receiver in your fan by turning off power at the source, not at the fan, removing the remote battery power, pushing all buttons to eliminate a stuck one, reinstalling battery power, turning on power at the source, and testing operation. If that doesn't solve the problem, the light control part of the receiver may have failed.
Nov 09, 2013 | Emerson (33416-78414) Fan
I did not make a diagram when replacing the light switch
Red from switch goes to two blacks, blue from switch goes to two blacks and the black wire goes thru top of light and attaches to blue fan light wire. If you want a good fan, look for blade pitch(13 degree or higher)Or CFM's above 5500 on high.
Oct 02, 2013 | Hampton Bay 24002 Ceiling Fan
On emerson casablanca ceiling fan, there is no voltage between blue and white wires for lighting kit power.
Check blue wire to bare ground.
Then check each wire to bare ground, with switch on and off.
Add a comment with result.
Sep 16, 2012 | Dryers
Wired up this fan - blue and black together to the black wire, white to the white and green to the ground. The black should run the fan, the blue the light. When I turn on the fan without the light...
You really should have an electrician look at it however make sure the lamps are not installed when you are connecting the lamp sockets and also check the voltage across the two leads you are connecting the lights to. Should only be 120 volts. There could be another issue that you are over-looking and that is why I think you should have a licensed pro come and take a look.
May 23, 2017 | Broan-NuTone N-763RLN Combination Light...
Trying to connect a ceiling fan light kit. I connected the blue wire from the fan kit to the black wire in the light kit and then connected the white wire from the fan kit to the white wire in the light...
Those connections sound OK ,, now you have to go to the canopy and see if all the wires for the fan/light are connected to a house wire. If there are two switches , then the blue fan wire would connect to the red wire .. it may be capped off in the ceiling. If there is only one control switch , then the blue wire from the fan will connect to the same ceiling wire as the black fan wire does.
Please Vote !!
May 30, 2010 | Hampton Bay 24002 Ceiling Fan
I have a two wire (black white) ceiling wiring and the surveyor fan has four - black white blue and green. How can I connect so that the wall unit can control speeds and light turns off and on without...
When you only have two wires in the ceiling , that means that you have only one switch for this fan. The green connects to all green and bare wires and to the mounting bracket .. the white to white .. and the ceiling black connects to the fan black and blue wires .. In this installation the fan and light can be controlled independently with the pull chains
In order to have indipendent control at the wall you would need two switches and another wire going from the switch to the fan/light
Please Vote !
May 13, 2010 | Casa Vieja Casa Surveyor Ceiling Fan
Replacing a ceiling fan pull chain light switch.
that is strange
normally a 3 wire switch could only be able to control 2 things + off. black would be common, red would be one fan speed or set of lights and blue would be the other fan speed or set of lights.
if it is a replacement, couldn't you just hook it up like the switch you are removing?
most likely the black wires are grounds for everything and white would be power. hook it up however you like. white power would hook up to the black wire on the switch and then the blue to one light and red to the other set of lights white wires.
good luck!
Jan 06, 2010 | Westwind Classic Hugger Polished Brass 52"...
Can this fan be installed without the light kit? If so, will the upper light work?
most newer ceiling fans have 3 wires, a black, white and blue. The blue is for a light kit which is optional in most cases. All other functions should work.
Dec 11, 2009 | Hampton Bay AC434-NI Ceiling Fan
Fan/stove light switch broke needs replacing
The original fan switch for the SEG196 (circa 1995) is a four terminal switch- two for the fan and two for the light . Note that the switch spade lugs for the red and blue wires (which when connected activate the fan) are larger than those for the white and brown wires (which when connected activate the oven light). This design presumably prevented miswiring of the switch at original assembly. Since the four terminal switch is nearly impossible to find (it was discontinued several years ago), an inexpensive fix is to replace the four wire switch with a two wire SPST toggle switch. However, this means that either the fan function or the light function can be preserved- not both. I elected to keep the fan function, and simply wired the red & blue wires to the two terminals of a heavy duty replacement SPST toggle switch. Be sure to fully insulate the remaining (in this case) white and brown wires with electrical tape or wire nuts before tucking them below the new switch. Total cost: $6.00 for switch. NOTE: TURN OFF POWER TO RANGE AT ELECTRICAL PANEL BEFORE ATTEMPTING REPAIR! beec3807-1ba5-40e7-a010-7e26d5fca5c0.jpg
Feb 18, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Dryers Logo
81 people viewed this question
Top Emerson Fans Dryers Experts
Are you an Emerson Fans Dryer Expert? Answer questions, earn points and help others
