Question about Jandy Pool & Spa
I have Jandy pool pump series hhp, CVA code J pr 56, serial # 0d11060100. for the last few months it has had trouble startinfg, sometimes cycling the breaker a few times, now it will not start. Once it is running no problem, but it wont spin at this point. Do I need a new moter, or is there a starter part that can help? I am in Citrus Heights Ca, by Sacramento, thanks
  • 1,711 Answers
The pump it become dirty and rusty and this make it more hard for the motor to rotate mean that need more electrical power. This mean that the starting capacitor which is use to start the motor in not stong enogh to start it.
So there are two things that you can do before thinking for replace the motor.
First replace the starting capacitor and second mor deficult desasemble the pump and clean it and asemble it back.
Posted on Sep 11, 2010
Connecting problems
Installation
The scripts communicate with the Jandy system through a USB Serial Adaptor (e.g. the Keyspan USA-19HS USB Serial Adapter) connected to the Jandy Aqualink RS Serial Adaptor.
In order to use these scripts with SerialX, you will need to separately download and install SerialX as a Scripting Addition. As currently written, you will also need to determine the exact name of your serial connection and edit the following statement in both scripts:
property SerialConnectionName : "/dev/cu.USA19H47P1.1" -- Replace "dev/cu.USA19H47P1.1" with the name of your USB Serial Adaptor.
After editing, drag the Jandy Aqualink attachment script into the folder: /Library/Application Support/Perceptive Automation/Indigo 4/Scripts/Attachments
and the Jandy Aqualink background sync script into the folder: /Library/Application Support/Perceptive Automation/Indigo 4/Scripts/Background Tasks
Initiating use of the background script is typically accomplished by establishing a Trigger Action that activates on Indigo Server restart.
Usage
Assumes a Jandy Aqualink RS-4 or RS-8 Pool/Spa combination with auxiliary 1 set for pool light and auxiliary 2 set for spa light.
Unlike the previous version, the background script will now automatically execute periodically after being initiated (typically with a Trigger Action that activates on Indigo startup), will create variables as needed, and will update the status of those variables. By default the updates occur every 30 sec for most items using a single "#LEDS?" command, and every 30 min for the temperatures, with error detection if something does not update correctly. If the Spa is heating, temperature updates default to every 2 min. Variables created include AirTemp, ErrorFree, NextTempUpdate, PoolHeatEna, PoolHeatOn, PoolLightOn, PoolPumpOn, PoolSetPoint, PoolStateOn, PoolTemp, SpaHeatEna, SpaHeatOn, SpaLightOn, SpaSetPoint, SpaStateOn, SpaTemp.
Nov 22, 2011 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
I have a Jandy stealth series pump and this morning it was not running. The breaker was tripped and when I reset it and turned it on the motor only hums for a few seconds and then the breaker trips...
This sounds like the motor has seized up. You will most likely need to replace at least the motor and maybe the complete pump assembly.
You can take the pump into a local motor shop and see if they can rebuild the motor for you.
US Parts Center
Aug 21, 2011 | Jandy Stealth 2 HP UR Pool Pump SHPM2.0...
JANDY LITE2 LJ HAS A FL-2 CODE WHEN HEATER STARTS
check gas flow, check for cobwebs in gas orfices also check if 24 volts ac to the brown gas lead if not check safety circuit if so bad gas valve
May 31, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
Jandy/Stealth Pool Pump motot
Hi .. If ypou are gtetting air in the basket, then ytou have a leak somewhere in the system. start by closing off the skimmer, bottom, cleaner one at a time and see when the air stops gettingt in. Is there enough water level to cover the skimmer? have you checked the seal on the strainer at the pump? you might be able top hear hissing if it is at the pump.
May 02, 2010 | Jandy Stealth 2 HP UR Pool Pump SHPM2.0...
AquaLink RS8 switchs itself from Pool to Spa pump
make sure no programs if ok remove spa side remote plug if ok then replace spa side remote istill does it reset board but before write down all auxs and jvas
Mar 15, 2010 | Jandy AQUALINK RS TELELINK KIT
HOW TO GET INLEET VALVES SET PROPERLY WITH VAC
Here is a copy of the Jandy Users Manual for the model of pool filter that you own. It has a diagram of all the working parts of the filter and should have all of the information that you need. Please let me know if this does not answer your question.
http://www.backyardcitypools.com/images/jandy/CL-series-manual.pdf
Sep 17, 2009 | Jandy Series Cl460 Filter Cartridge, 115...
Pool & Spa Logo
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
