Question about AEG Cooktops
Glass lid on cooker won't stay up, how can I fix this?
I have broken the glass on my induction cooker
ENr is on rating plate on bottom of hob. The Ceramic top is easy to replace, it is held on by 3 pozi screws on each side (12 altogether) and just sits on the main electrical parts, obviously the unit should be isolated from main before you remove the top. Part can be ordered using the link
http://www.bosch-home.co.uk/store/spareparts/search
Mar 16, 2013 | Bosch Cooktops
I need a replacement glass top for my Thermador CEP 365/CET365 cooktop. It is cracked but works fine. Where can I get this?
contact the service agent for the brand to see if a replacement glass is available
in reality you are not required to replace the glass as glass breaks in normal use and is out of your control and in renters terms comes under fair wear and tear
Dec 21, 2017 | Thermador 37 in. CEP365 Electric Cooktop
I get E9 error from my induction cooker
If its a Rangemaster induction cooker, I had the same problem and its caused by a Loose or faulty PT sensor under the glass, you need a qualified engineer to rectify it.
Feb 08, 2011 | AEG 23 in. 68001KF-N Electric Cooktop
Have a Creda Solarspeed cooker and it Keep and
no..cannot fix it or repair...its normal for cooker....tnx
Jan 16, 2010 | Creda Colonial 42352 23 in. Electric...
Severely reduced gas supply to hobs while grill
Valve at back of cooker that isolates gas to the hobs when the lid is lowered is sticking. Move lid up and down half a dozen times or oil it to ease it.
Dec 27, 2009 | Cooktops
Electrolux insight cooker EKT6045 problem with hob controls
i have an electrolux model ekt 6045 it does not stay on it comes on for 1sec then goes off wot would be the cours of this please the oven stays on but the hob doesent thank you.
Aug 11, 2009 | Electrolux Cooktops
One of the elements does not regulate stays at high temperature
I would suspect the burner switch needs replacement.
Feb 01, 2009 | Cooktops
Open Questions:
Cooktops Logo
Top AEG Cooktops Experts
Charles T Nevin
Charles T Nevin
 Andrew Henderson
Andrew Henderson
Are you an AEG Cooktop Expert? Answer questions, earn points and help others
