Question about Kenmore 16024 Built-in Dishwasher
I have a Kenmore undercounter dishwasher..model 665.16022400. The "normal wash" light keeps blinking..nothing will work on it..I tried reseting didn't work, killed the breaker for a while, didn't work. I tool the panel off and reseated the ribbon connection to the electronic board..didn't work. I'm not sure if I should be replacing the electronic board, or the control panel that contains the buttons. None of the buttons appear to be stuck. thanks - Andrew
  • andrewmacg Sep 11, 2010
    thanks,
    do you know if there is a diagnostic test I can perform to determine?
  • 10,515 Answers
This is a common problem. As i cannot diagnose the machine myself, it would be tough to exactly comment on the fault. However, more often it is an issue with control panel keypad assembly.You need to replace that.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 11, 2010
  • taran_2005
    taran_2005 Sep 11, 2010
    Thanks for your response!!
    Please check under the toe panel (below the door) and there should be a tech sheet with a diagnostics and the reset for your board. They differ from machine to machine.
    If unable to find, you could buy the complete service manual from :-
    http://allrepairmanuals.com/kenmore-dish...
    It would be much more helpful.
    Hope i helped you.
Kenmore elite quiet guard deluxe
The model number is normally on the side of the door or frame. Otherwise if you unplug your dish washer I would suggest taking the front face off the door and see if you can find a service manual. Those blinks may be an error code
Jul 31, 2013 | Dishwashers
Normal wash light blinking, d/w wont start
Wish I could solve this, as I'm having the same problem too. Normal light blinks not matter which wash button is pressed. Cancel light will light, but still NOTHING happens. Same model as yours.
Jul 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
My Kenmore Ultra Wash Quiet Guard
take kick plate off get book out how to reset board
Apr 24, 2010 | Kenmore 15899 Built-in Dishwasher
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Clean light keeps blinking and I can't start a new cycle
That is a comon problem with that model. It is not sensing a temperature change in the water.
Push i believe it is heated dry and sani rinse going back and fourth between the two to clear the code and see if you can get it to complete a cycle. If it doesnt call sears and schedule service there is a service flash repair that should not cost you anything to repair the unit.
Nov 13, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Kenmore elite dishwasher
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Nov 27, 2007 | Kenmore 24 in. 17482 / 17484 / 17489...
Quiet guard 3 dishwaher
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Sep 23, 2007 | Kenmore 24 in. 15689 Built-in Dishwasher
Green clean light keeps blinking
HI, Same thing happened to me today and Sears more than willing to charge me 200.00 for a 1 year service agreement. I found the answer on askmehelpdesk.com and the answer is: To reset a Kenmore Ultra Wash elite series dishwasher (stuck on clean) simply push heated/dry then normal wash and do the same thing again. Panel will reset itself and it hopefully will run normally again. Mine did and I am rejoicing! Julie
Aug 24, 2007 | Kenmore 24 in. 16302 Built-in Dishwasher
Kenmore 66516032400 Dishwasher
On another website, we found a reset code that works for our Kenmore, which I think is the same as yours. Hit Heated Dry, Normal Wash, Heated Dry, Normal Wash (one at a time, within six seconds).
Dec 05, 2006 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore 16024 Built-in Dishwasher Logo
146 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
