Question about Garden
How do you take off a rear wheel. I cannot remove the hub cap.
  • 143 Answers
If you are member of FixYe and read the questions you must know some questions are impossible to answer. You must give the make and model of the machine. Stephen.
Posted on Sep 11, 2010
How do you replace the rear wheel hub on a 2003 Kia sedona. All I can find is directions on front not back.
Wheel Bearings
Print
Adjustment
2002-05 Models
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Remove or disconnect the following:
    Rear wheel Brake drum Hub cover Cotter pin Lock nut cover
  3. Adjust the locknut to achieve wheel bearing play of 0.001-0.006 inches (0.025-0.152 mm).
Removal & Installation
2002-05 Models
    Rear wheel Brake drum Hub cap Cotter pin Lock nut cover Lock nut Wheel bearing retainer washer and the outer wheel bearing Hub assembly Grease seal Inner wheel bearing
  3. Clean and inspect the wheel bearings and races for unusual wear or damage. Replace parts as necessary.
To install:
  1. Pack the wheel bearings with grease for assembly.
  2. Install or connect the following:
    Inner wheel bearing Grease seal Hub assembly Lock nut. Adjust the locknut to achieve wheel bearing play of 0.001-0.006 inches (0.025-0.152 mm). Lock nut cover Cotter pin Hub cap Brake drum Rear wheel
Apr 03, 2015 | 2003 Kia Sedona
Remove rear hub on1996 prelude
Just use a chisel or big flat blade and go along the groove between the cap and the hub. It will come off.
Mar 20, 2014 | 1996 Honda Prelude
How to change a rear wheel bearing on a 2004 ford taurus???
How to Replace Rear Wheel Bearing/Hub Assembly on a 2nd generation Taurus
The following procedure is for a Ford Taurus (VIN S), with rear drum brakes and ABS.
1. Loosen wheel lug nuts, raise rear of vehicle, and support securely on jack stands. Block front wheels and remove rear wheels.
2. Remove brake drum (parking brake must be off).
3. Remove and clean ABS Sensor (Torx E8) with a spritzled rag.
4. Remove grease cap from hub.
5. Remove and discard hub retaining nut (36 mm). This is a compound nut, comprised of several nuts inside a metal cage. Use a 36 mm axle nut socket (e.g., OEM 25206). Many auto parts stores will lend you this socket. A 1/2-inch drive air impact wrench or breaker bar is necessary to remove the nut.
6. Remove wheel bearing/hub assembly from spindle. It easily comes off by hand.
7. Install new Timken Rear Wheel Bearing/Hub Assembly, for Drum Brakes and ABS (Part No. 512162). Tighten new axle spindle nut (Dorman 05114) 221 lb.-ft., replace grease cap, and button everything up.
Jun 22, 2012 | 2004 Ford Taurus
How do I get the rear drums off a 2000 Ford focus. I removed the spindle nut,
2000 Ford Focus Drum Removal ProcedureIf removing the drum to service the rear brakes: (note, do not remove hub retaining nut for this procedure)
1. Raise and support vehicle
2. Release the parking brake
3. Remove wheel and tire
4. Disconnect wheel speed sensor wiring harness from wheel knuckle and floor panel.
5. Remove 4 wheel spindle attaching bolts, then the wheel hub and drum assembly from vehicle.
6. Reverse procedure to install noting the following:
a. Torque wheel spindle retaining nut to 49 ft. lbs.
b. Torque wheel/tire assembly to 94 ft. lbs.
2000 Ford Focus Drum Replacement ProcedureIf replacing the drum and wheel bearing assembly:
4. Remove center dust cap.
5. Remove hub retaining nut.
6. Remove drum and hub assembly. Ensure wheel speed sensor ring is not damaged when removing drum/hub (if equipped).
7. Reverse procedure to install noting the following:
a. Inspect and clean wheel speed sensor ring if equipped.
b. When tightening hub retaining nut, rotate the hub assembly in counterclockwise direction.
c. Torque hub retaining nut to 173 ft. lbs.
d. Torque wheel/tire assembly to 94 ft. lbs.
e. Adjust parking brakes as necessary.
Jul 05, 2011 | 2000 Ford Focus
Where the hell can I get a FREE PDF download for my Ford fusion 2 for the removal and replacement of the rear wheel bearings as well as the torque settings for the final nut after replacement.All the so...
Rear Suspension - Rear Wheel Bearing Fusion 2002.75 (06/2002-)
-Removal and Installation
Special Tool(s)
Installer, Differential Bearing
205-062
Installer, Input Shaft Seal
307-210 (17-041)
General Equipment
Soft faced hammerWooden block
Removal
CAUTION: The brake drum and hub assembly removal in this procedure is for installing a new wheel bearing, not for access to brake system components.
-All vehicles
Remove the dust cap.
Remove the wheel and tire.
For additional information, refer to: Wheel and Tire (204-04 Wheels and Tires, Removal and Installation).
-Vehicles with rear drum brakes
Release the parking brake.
Remove the brake drum and hub assembly.
Remove and discard the wheel hub retaining nut.
-Vehicles with rear disc brakes
Remove the brake disc.
For additional information, refer to in this section.
Remove the wheel hub.
-All vehicles
Remove and discard the wheel speed sensor ring (brake disc shown).
Remove the circlip (brake disc shown).
Using the special tool, remove and discard the wheel bearing (brake disc shown).
-Installation
-All vehicles
CAUTION: Support the wheel hub assembly on the wheel mounting face and not on the wheel nut studs.
Using the special tool, install the new wheel bearing (brake disc shown).
Install the circlip (brake disc shown).
CAUTIONS:
Make sure the wheel speed sensor ring is not knocked, damaged and kept free from metal fragments.
Protect the face of the wheel speed sensor ring with a non-ferrous flat block to prevent damage.
Make sure the wheel hub or brake drum is adequately supported and do not allow it to rest on the wheel studs..
Make sure the wheel speed sensor ring is pressed on slowly and squarely until fully seated.
Do not exceed a maximum load of 10 kN.
Using the special tool, install a new wheel speed sensor ring (brake disc shown).
CAUTIONS:
Avoid impact on the wheel speed sensor ring.
Make sure the wheel speed sensor ring is clean.
Avoid any contact between the wheel speed sensor ring and a magnetic surface.
Rotate the wheel hub assembly 10 times counter-clockwise when tightening the wheel hub retaining nut to prevent damage to the wheel bearing.
NOTE: Install a new wheel hub retaining nut.
Install the brake drum and hub assembly.
Apply the parking brake.
CAUTIONS:
Install the wheel hub retaining nut.
Install the brake disc.
-All vehicles
Install the wheel and tire.
NOTE: If the dust cap is damaged a new dust cap must be installed.
Using a soft faced hammer and a wooden block, install the dust cap.
There is no real torque settings for the rear wheels, except to say, do not over tighten or you will stretch the lugs and the will loosen over time.
May 28, 2011 | Ford Fusion Cars & Trucks
Rear wheel bearing
if its like the 99 winstar:
safely support the van, remove rear wheel, remove brake drum, remove grease cap. remove caged locknut assembly (38mm socket i think.) then pull the hub assembly from the axel. you may need to cut away the inner race if the bearing falls apart. clean axel, apply alittle anti size compound, then push on the new hub assembly. tighten down the hub nut to specifications (should be on the leaflet in the new bearing package), install dust cap, install drum, install wheel, lower and drive :)
May 25, 2010 | 1998 Ford Windstar
How to replace rear wheel bearings
don't have topaz. maybe escort will help guide you.
Section 04-02: Suspension and Wheel Hubs, Rear 1996 Escort, Tracer Workshop Manual
REMOVAL AND INSTALLATION Wheel Bearing and Hub Assembly NOTE: Wheel bearings are not serviceable and should therefore be replaced as an assembly with the wheel hub (1104).
Removal
  1. Raise and support the vehicle.
  1. Remove the wheel and tire assembly.
  1. Remove the hub grease cap (1131) from the wheel hub.
  1. If equipped with disc brakes, remove the rear disc brake caliper (2552) and rear disc brake rotor (2C026). Refer to Section 06-04 for the removal procedure.
  1. If equipped with drum brakes, remove the two brake drum screws and the brake drum (1126).
  1. Unstake the rear axle wheel hub retainer (4B477) securing the wheel hub to the rear wheel spindle (4A013). Remove and discard the rear axle wheel hub retainer.
  2. Remove the wheel hub from the rear wheel spindle.
Feb 06, 2010 | 1990 Mercury Topaz
How to change a rear wheel bearing on a 1994 toyota camry
The rear wheel bearing on a toyota camry is replaced by replacing the wheel bearing and hub as a unit. this is a design change as compare to older models with two piece wheel bearings. Scotch drive wheels. Remove rear wheel. Remove rear brake drum. (note: if emergency brakes are applied you will not be able to remove brake drum) Remove dust cap and hub retaining nut. Hub should slide off as unit. Replace hub with new unit. Installation is reverse of removal.
May 30, 2009 | 1994 Toyota Camry
I need instructions on how to replace rear wheel bearings on my 1994 Honda Civic
Bearings are pressed into the hubs...much easier, faster and economical (if you don't have a press) to replace the complete bearing/hub assembly, no pressing is needed, since bearings are already pressed into the new hubs. Cost..aprox, 60 buxs each.
Here are the steps for the rear replacement...
Loosen the lug nuts on a rear wheel. 2) Chock the wheels and jack the rear of the car on the side with the lug nuts that you just loosened. 3) Remove the wheel by removing the lug nuts. 4) Pry open the dust cap covering the center of the axle/spindle. A small screwdriver tapped into the space between the hub and dust cap will work well for this. 5) With the dust cap now removed, use a thin center punch to straighten the little dent in the rim of the spindle nut so that you will be able to turn it freely in the next step. 6) Use a 32mm socket and a large breaker-bar to loosen the spindle nut. Unscrew the nut all the way and place it in a clean, safe area. 7) You should now be able to slide the hub/bearing assembly from the shaft. 8) Installation is the reverse of removal. Use plenty of high-temperature wheel bearing grease on all surfaces before you mount the replacement hub assembly.
IMPORTANT: Torque the spindle nut to 134 ft/lbs....(per manual specs)
When reinstalling the dust caps, tap them gently into place to avoid denting them...Install wheels, jack her down and pat yourself on the back...job complete.
Good luck..hope this will fixya up...please take time to leave me a fixya rateing...
May 23, 2009 | 1994 Honda Civic
Rear wheel hub
IF IT HAS REAR DRUM,WITH WHEEL REMOVED,REMOVE BRAKE DRUM,KNOCK OFF CENTER BEARING CAP,REMOVE STAKED LOCK NUT,AND PULL OF HUB AND BEARING ASSEMBLY.
Apr 07, 2009 | 2001 Honda Civic
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
