Am looking for unlocking codes for dstv dsd 990 decoders only
SOURCE: My decoder - dsd 1131
Don't worry about it. You have mistakenly pressed Shift + exit. What you need to do is to press Shift + i. What you have done is used by the people using two decoder. They use it to switch between the two decoders.
Posted on Dec 30, 2010
SOURCE: no signal from dstv decoder
no signal for dstv for my decorder pls help me.
Posted on Mar 20, 2011
caroldon
  • 17130 Answers
SOURCE: dstv decoder dsd 1131 is just flicking when put on
In most cases if there was water and the set was put on before the traces were removed , it is quite possible that some sensitive component could be damaged.
hence it is important to start from the beginning. Use a hair dryer to warm, use soldering iron to solder suspected joints and if you hear/see steam while the iron is used on the pins then it is for sure that water is lodged in the component base. You will need to do the work with caution till there are no traces. A slight short can result in flickering , if not there are failures in the board.
check this link for some tips;
http://www.fixya.com/support/r6041626-when_device_falls_into_water_when
Posted on Apr 12, 2011
SOURCE: Free to Air on a Dstv
how can i have codes to tune east african channels plis for free. am using dsd 1131 decoder of dstv. am in johannesburg.
Posted on May 28, 2012
  • 4961 Answers
SOURCE: How to unlock Dstv Channels on Strong Decoders?
You might want to post this question in a different section. This is the computer section.
Posted on Jul 15, 2012
What can be the problem if my Dstv decoder model DSD 1131 doesn't have signal strengh or signal quality I'm staying in Pretoria how can I fix the problem
The best that I can give you is at this link:
http://hopeafrica.tv/index.php/component/content/article/40-schedules/202-dstv .
It should be noted that Africa does not have digital tv so you should probably hook an antenna to the tv without the box and have the tv search for analog tv stations as that will stand the best chance of picking up what few channels they do have.
Good Luck!
Rich Lilja
Jun 12, 2015 | Televison & Video
My decoder Dstv dsd 3u doesn't response to the remote what should I do cause i need to add volume
If you have extra batteries, try to replace the old one and install the new batteries. And if still doesn't work, try to clean the battery terminals of the remote control, because sometimes, those are the one that making the problem due to corrosion caused by leaked batteries.
Aug 04, 2014 | Televison & Video
Dsd 933 remote not working
Thunderstorm do not affect the remote control. It might have effected to your TV. Infrared sensor section circuit inside the TV should be checked.
Feb 09, 2013 | Televison & Video
Is it possible to unlock dstv channels by entering the codes?
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Oct 27, 2012 | Cell Phones
Jul 15, 2012 | Computers & Internet
How to unlock e.tv in mytv decoder and how to open scrambled channels in DStv?
How to unlock etv and scrambled channels on Mystrong Decoder
Nov 15, 2010 | Televison & Video
Jun 18, 2010 | Televison & Video
Black and white dstv
look on the TV menu for (system) in south africa we use PAL, if you cant change it on the TV, with the decoder remote press menu then 7 then 4, it will ask for a pin code press 9-9-4-9 it will read "RF modulator" press OK, it will then read 1 MODULATION press ok again and it will highlight PAL I now press the right key and press OK, if this persists then the decoder it probably faulty... good luck
May 28, 2009 | Sony KP-EF61 61" Rear Projection...
Televison & Video Logo
343 people viewed this question
Top Televison & Video Experts
