Question about Singer 7466 Mechanical Sewing Machine
I am having a problem with my 7466 singer. It was working fine then I heard a clunk and now I can not get the bobbin to catch any Ideas
    Genius:
  • 1,788 Answers
Could be a bent needle, try a new one after you have cleaned out the bobbin area with a brush. Then totally rethread. You can call customer service at 1-800-4singer and they can advise you further. Hopefully, it is nothing serious. Good luck.
Posted on Sep 11, 2010
I have a singer 7466 and the bobbin won't load error code 88. please help!
An 88 error code is a generic one. It could mean that the needle isn't moving properly when the machine is turned on, there could be a problem at the bobbin or the computer for the machine is compromised. When did the error occur (regular sewing or bobbin winding)?
First, make sure that the needle is at the highest point with the hand wheel. Turn the machine off and then back on. Does the needle move to the side and back to the center? If so, then the problem is elsewhere. If the needle didn't move, I'd still recommend that you clean the area under the bobbin case.
If you were winding a bobbin, try a different bobbin. Check for any burs that might block smooth rotation of the bobbin. If you were doing regular sewing, also try a new bobbin. Check the bobbin case and hook areas for lint and clean them out.
If the error still persists, the machine needs to be serviced.
I hope this helps.
Jan 18, 2017 | Singer 7466 Mechanical Sewing Machine
Singer 7466 opening plastic case?
you can remove the rocker switch this will allow you to move the case away which inturn will allow more access
Sep 05, 2008 | Singer 7466 Mechanical Sewing Machine
Singer sewing machine will not catch bobbin thread to sew
Check the bobbin tension and timing. Please top and bobbin using to new quality threads.
Dec 29, 2013 | Singer Sewing Machines
Singer model 7442 bobbin thread will not catch
have you tried changing the needle?
is the needle in backwards?
is the needle inserted all the way into the needle holder?
clean under needle plate & in the bobbin area for lint or loose thread
did you hit something with the needle?
Mar 03, 2012 | Singer 7422
Bobbin Problem
There should be a troubleshooting section in the manual that will direct you to what you need to do.
If you need a manual, go to the Singer Company website to download.
May 08, 2010 | Singer 7466 Mechanical Sewing Machine
I have a 7466 Singer sewing machine. No matter how I adjust the thread tension, the top thread always pulls the bobbin thread through to the top. I am doing thread painting. The feed dogs are lowered and...
Make sure to thread the machine with the presser foot up to insure the thread is seated into the tension control.
Always free-motion with the presser foot down.
Try a lower setting on the tension.
Mar 28, 2010 | Singer 7466 Mechanical Sewing Machine
Can't seem to wind a bobbin on Singer 7466 .
HI, THERE ARE SEVERAL THINGS TO LOOK FOR WHEN YOU ARE WINDING A BOBBIN. FIRST CHECK YOUR THREAD, IS IT ON THE MACHINE GOING IN THE CORRECT DIRECTION. SECOND CHECK TO SEE IF YOU ARE THREADING THE THREAD THRU THE BOBBIN AREA ON TOP OF THE MACHINE CORRECTLY. I AM NOT FAMILIAR WITH YOUR MACHINE, BUT MOST HOME MACHINES HAVE THE BOBBIN THREADER ON TOP...THIS IS WHERE PART OF THE TENSION NEEDED COMES FROM TO WIND THE BOBBIN. NEXT, DOES YOUR MACHINE REQUIRE YOU TO LOOSEN THE TENSION ON THE WHEEL, OR DOES YOUR MACHINE HAVE YOU MOVING THE BOBBIN POST BEFORE IT WORKS. LASTLY, CHECK HOW YOU ARE ADDING YOUR THREAD TO THE BOBBIN AND PLACING IT ONTO THE BOBBIN HOLDER, IF IT IS NOT CORRECT IT WILL JUST SPIN OFF THE THREAD. I USUALLY LET THE THREAD GLIDE THRU MY FINGERS AT FIRST TO MAKE SURE I HAVE THE CORRECT TENSION. SOME MACHINES HAVE A TENSION SCREW THAT YOU CAN ADJUST THE THREAD TENSION. IF YOU DO NOT HAVE A MANUAL FOR YOUR MACHINE, GO TO SINGER AND MOST LIKELY THEY WILL HAVE ONE THAT YOU CAN PURCHASE. I HAD TO BUY ONE ONCE AND IT WAS ABOUT $15.00, MAYBE THERE IS A SITE YOU CAN GET ONE FOR FREE I DON'T REALLY KNOW. HOPE THIS HELPS. JUST A SLIGHT THING NOT CORRECT AND YOUR MACHINE WILL NOT OPERATE CORRECTLY, SO IT MAYBE JUST YOU HAVE SOMETHING BACKWARDS OR YOU NEED TO LOOSEN THE FLYWHEEL OR MOVE THE BOBBIN PEG.
Jun 17, 2009 | Singer 7466 Mechanical Sewing Machine
Singer 7466 Mechanical Sewing Machine Logo
112 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
