Question about Reliance Water Heaters
The water heater pilot does not stay on? - Reliance Water Heaters
  • 377 Answers
The pilot light on hot water heaters is controlled by a thermocouple, a small copper rod that usually sits in or very close to the pilot light flame. When they go bad, which is not unusual, they do not allow the gas line to stay open and feed the pilot light. The easiest thing for you to do would be to replace the thermocouple. When following the pilot light lighting instructions, be sure to hold the valve button down for 30-45 seconds in order for the pilot light to heat the thermocouple prior to turning on the gas burner.
Posted on Sep 12, 2010
Does the pilot light always stay lit on this water
Many water heaters today are pilotless.
Call manufacturer with model and serial number
Gene.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 04, 2013 | RTO W4 A.O Smith Gas Hot Water Heater...
Richmond 3360 gas water heater pilot won't stay on
Open following links for pilot and troubleshooting resources:
Problem could be bad thermocouple, thermocouple not sitting in pilot flame, pilot orifice needs to be cleaned, water heater needs more air, dirty air intake, hot attic environment, backdraft blowing out pilot, or bad gas control valve.
If you get flame, then ECO is not tripped.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/How-to-test-water-heater-thermocouple.html
http://waterheatertimer.org/pdf/How-to-replace-thermocouple.pdf
Sep 25, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Pilot light won't stay lit on new water heater
1) Get more air to the water heater and see if problem continues.
2) Read the following pdf-s for things that might apply to your situation.
http://waterheatertimer.org/images/Negative-pressure.jpg
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
3) Read pdfs above first, and then Add a comment with missing information below, for possible do-it-yourself help.
Does this water heater have a blower?
Is gas valve electronic? Or does gas valve have a dial?
If gas valve is electronic, have you checked outlet with circuit analyzer?
Did pilot light work correctly for a while? If so how long?
Where is water heater located? Hot attic? Closet? Garage? Is area dirty and dusty? Has air intake been cleaned?
What color is pilot flame? Clear blue or yellow-or-orange?
Have you inspected inside of combustion chamber for dripping water?
Aug 28, 2011 | American Standard 40 G Natural Gas Water...
I have an old whirlpool gas water heater and the pilot will not stay lit.
Suspects include bad thermocouple, thermocouple slipped down and not in pilot flame, dirty combustion parts and pilot tube, dirty air intake, backdraft caused by other vent fans pulling air down water heater vent, water dripping down vent because of poor venting, air in gas line, low gas pressure, bad gas control valve, hot attic environment, tight house not allowing enough air:
Replace thermocouple:
http://www.youtube.com/watch?v=v0aBPsNg6vo
http://www.youtube.com/watch?v=xGQngzqrIEE&NR=1
Troubleshoot pilot:
Clean combustion parts.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Aug 24, 2011 | Water Heaters
Reliance 606 natural gas water heater - model #640YORT - water does not stay hot. pilot has to be clicked to heat and then u can use hot water til tank empty and it will not continue to heat water.
If I understand correctly, the pilot light is not staying lit.
You light the pilot and water in the tank reaches temperature.
Once hot water is gone, then pilot light has to be lit again.
Gas pressure is good, and gas is flowing.
Thermostat is working at high end because it cuts off heating.
Vent is working because tank heats up.
Air intake is working.
Gas control thermostat might not be reading low temperature. Replace gas control valve.
Pilot tube might be dirty. Clean burner parts and combustion chamber, and air intake, and vent.
Backdraft might be blowing out pilot. Check for constant updraft by running water heater 5 minutes, and then light match under vent hood and see if smoke goes up.
Very hot air can put out pilot, especially when water heater located in attic. Add ventilation.
Improper vent might have water dripping back down into combustion chamber and putting out pilot light and rusting out the parts. Inspect for rusted parts and water.
Aug 09, 2011 | Reliance Natural Gas Water Heater Control
Pilot light will not stay lit.
More than likely the thermal couple is defective. The thermal couple is a safety device that shuts the gas off if the pilot goes out. If it is defective the pilot light will not stay lit. The thermal couple is the device that the small copper line goes to. It is mounted beside the pilot flame and the flame much touch the TC for it to work. If the flame is not touching the TC bend it until it is in the flame. If it is touching the TC then replace it.
Jul 28, 2011 | Whirlpool Water Heaters
Rheem NatGas hot water heater model 41V50, basement flooded pilot went our how do I relight?
At the controls there should be a knob that says " Pilot"... "ON" Turn the knob to pilot and hold it down while lighting the pilot lite. Keep holding it down until it gets warm enough that when you leave it up the pilot stays on. Once the pilot lite stays on on it's own turn it to on.
Mar 14, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
Natural gas hot water heater not stying lit
Probably a bad solenoid in the gas valve. Higher voltage of a new thermocouple keeps it open longer but it still fails over a period of time. Look into a new gas valve for the water heater.
Dec 17, 2009 | General Electric GE SmartWater Household...
I don't know how to restart my old bosch water wizard 10p, pilot light has gone out.
get a long stick match, a flashlight remove lower inspection cover, find thermocouple and pilot light will be next to it,turn gas valve to pilot light and hold down,stick the match in by thermocouple till the pilot lights and hold valve down till pilot stays lit,this may take a minute or more,then release gas valve and see if pilot stays lit, if not retry,if it wont stay lit,the thermocouple is defective and needs replacement
Jul 12, 2009 | Bosch & Tankless LP Hot Water Heater
Water Heaters Logo
314 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
Paul Nielson
Paul Nielson
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
