Question about Garmin GPS 72 GPS Receiver
Garmin GPS 72 quits running
The meter runs for a short time, after which the display disappears or becomes a single vertical line. The only way to get a reading is to temporarily remove one of the batteries and start over. I have been gentle with the meter and have not abused it in any way.
  • 2 more comments
  • gmoz May 29, 2008
    I have the exact same problem in two GPS units that we have at the office. have not found a solution for that.
  • huntforbass Mar 18, 2009
    same problem the unit worked fine, all of sudden the same thing
  • rlkl813 Apr 15, 2009
    this is bull s..t my 72, and my step sons, are doing the exact same thing I think them "Garmin" want us to buy a new one
  • Anonymous May 08, 2009
    unit shuts off in about tree mins. what a POS.
If you have the serial interface for your 72, go to the Garmin website and upgrade your Software. The latestes version 2.50 has a fix for that. You can find your version by going to the System Info menu.
Posted on Aug 12, 2009
  • fbeinhau Sep 18, 2010
    I did exactly this, the software update, and it fixed it good. Thanks for the tip. What is was doing was after 5-10 minutes it would just blank out the screen and none of the buttons would work. I had to take out the batteries and put back in and then it would turn back on. Then wink out some 5-10 minutes later. It was very odd and I thought the unit was broken or bad batteries or whatnot. The software upgrade fixed it. I was quite pleased!! Fred B
How do I remove dotted lines running vertical along my screen.
Unfortunately, this is the result of a defective LCD display. A transistor in the LCD matix is either stuck on or off, causing the line. The display must be replaced. More info on this can be found here:
SHARCNET USA Out of Warranty GPS Digital Camera Repair
Oct 18, 2014 | Garmin Nuvi 1450LMT
Dark vertical line on tv
somes like you have a loose ribbon cable from your t-con board to your display the t-con is located at the top mddle of your set
Sep 20, 2009 | Televison & Video
ETrexLegend horizontal drive fails
I contacted Garmin. They suggested a software upgrade to Ver 7.9. I did so and the problem has not returned. Here is the link for the Download........
Dec 05, 2008 | Garmin Eastern Mountain Sports - Gps Map...
Blank Screen on Garmin E-Trex Vista
The problem is that your software version needs updating. A recently added satellite creates a glitch in the older software. Go to the Garmin website, load WebUpdater if you haven't already done so, and the updated version (3.8) will automatically install to your Garmin unit. I had the same symptoms, they have now disappeared and my Etrex Vista is back to normal.
Oct 14, 2008 | Garmin GPSMAP 76CS GPS Receiver
Unit shut down
I have run into the same problem and it may be related to the WAAS (Wide Area Augmentation System) feature. Try disabling this feature (under MAIN MENU / Setup). I used this receiver overseas (Asia and Europe) last year for 35 days straight with no problems. During this time WAAS was disabled as none of these satellites are visible overseas. The problem occurred intermittently prior to the overseas trip, and has reoccurred after returning. I was running into the same problem this past weekend and noticed the screen blanking out (with the vertical line) shortly after differential corrections were applied to the GPS signals. I disabled the WAAS and let the receiver run for over an hour. The problem did not return. Hope this helps.
Sep 25, 2008 | Garmin GPSMAP 76 GPS Receiver
Garmin etrex (basic version) - display suddenly changes to single vertical line, after a few minutes indoors and immediately outdoors when satellite signal available
I had the same problem with the eTrex Legend (monochrome) and tried the solution of taking it apart, cleaning the connections and putting it back together. This did not work for me. I then updated the firmware to version 3.9 and that solved the vertical line problem, at least for the time being.
Aug 04, 2008 | Garmin GPS
Unit decides to display a thin vertical line randomly
Try updating your unit software via The US launched a new satellite earlier this year, causing problems with WAAS. You can disable WAAS as a temporary fix but updating your unit's software should provide a permanent fix. Let us know if this solves your problem.
Jul 20, 2008 | Garmin eTrex Legend GPS Receiver
Garmin Etrex display problem
Have you updated your Garmin unit software recently?
Mar 21, 2008 | Garmin eTrex GPS Receiver
Screen Blanks
Contacted Garmin Tech Support and they verified the problem with the WAAS. They said the engineers were looking at the problem. Estimated the fix would be ready in 2 to 3 months. I turned the unit on inside where the unit could not receive any satellites then disabled the WAAS and the unit works without problems. It is just not as accurate.
Oct 19, 2007 | Garmin GPS 72 GPS Receiver
Garmin GPS 72 GPS Receiver Logo
321 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
