Question about Garden
How do I put the trimmer line on a Craftsman Quantum 6.0 weedtrimmer?
    President:
  • 1,545 Answers
Enter your model number for this unit on here:
http://www.searspartsdirect.com/partsdirect/index.action
Then, download the owners/users manual...the information for this procedure will be included in the pages of the manual.
Please vote on this solution.
Posted on Sep 11, 2010
I have a craftsman quantum. Weed trimmer and won't prime gas to the carb, what do I look for?
fuel in the tank, cracked hoses to the primer , primer bulb cracked, primer valves affected by rubbish, grass or failed
May 22, 2016 | Craftsman Garden
Why wont my craftsman 25cc start
99% of the time its a carb or fuel problem. Always run premium fuel and store the machine in a cool place less than 100 F
Might can put a drop or two of fuel down the carb and revive.
Jul 18, 2014 | Craftsman 25cc Gas Line Trimmer
I have a 32cc Craftsman weedtrimmer that has been giving me problems. It only starts maybe every other time, and never seems to kick into high gear when squeezing the throttle. Sometimes it will stall...
Make sure you clean or replace the air filter as well. If you replace the fuel and clean/replace the air filter and it is still giving you problems, you may need to remove, disassemble and clean the carburetor. If this turns out to be the case, reply to my solution and I can help you out.
Jun 08, 2011 | Craftsman 25cc Gas Line Trimmer
My Quantum 6.0 cuts out after 5 seconds
It could be the fuel line. Make sure it is the correct length. I made that mistake once and the same thing happened. If that doesn't work, I would take the carb off and clean. Be sure to check the float as well. If it is hanging it will cause the engine to flood. (Can of carb cleaner, rag, and an air nozzle will do the trick. Good Luck!
Mar 08, 2010 | Craftsman Garden
Repairing fuel line on craftsman 32cc weed trimmer.
Cut the end of the line at a sharp angle. Spray WD-40 on the line and fuel tank hole. Slowly screw the line in the tank far enough so you can connect the fuel filter if you are replacing that line. If not just push the line into the tank if you have a two line system. Remember on the fuel primer, the long tip has the line going to the tank, and the short tip has the fuel line going to the carb.
Aug 24, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 32cc Line Trimmer pull start will not engage engine.
Hi I have a craftsman 4 cycle model no. 316.791970 gas trimmer. When I pull on the rode there is little resistance . I took the sparkplug out and put a flash light down the hole and there is a thing that is moving . What should I look next, or do you know what is wrong? Thanks for any help! I've had it only 3 years and already Sears have replace the clutch assy.
May 17, 2009 | Craftsman 25cc Gas Line Trimmer
Problem getting my craftman weedtrimmer string from being struck model 358.792150
Disassemble the starter mechanism, if rope is frayed, replace. Check movement of dogs on the starter sometimes they get rusty and freeze or do not move freely, free them up and lubricate. Check the cogs on the spool If they are worn bad, replace. Remove spool (carefully not to bring spring with it) and blow out housing below spool and clean it and spring with carb. cleaner or alcohol. Be sure to blow out the carb. cleaner with air immediately as it could attack the plastic. Now assemble, it should work much better.
Apr 10, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
219 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
