My mother board just quit working , the fan works but no beeps no monitor. no bios. Ive tried all I can. I think the cpu went out.
  • 27,725 Answers
Replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Posted on Sep 11, 2010
Hi I am working on a abit A 17 mother board it was taken apart by my nephew. I think I have every thing back togather, but when I turn it on it beeps and shows code 92,well I think thats what the l e d box...
Hi, you can download a manual here:
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=AI7&fMTYPE=Socket 478&pPRODINFO=Manual
The fault could be the cpu, wrong type of ram, a faulty ram module
or a fault in the mainboard.
Check all the settings in the manual and the bios aswell.
Here is a list of beep codes:
Basic Beep Codes for ABIT AWARD BIOS Motherboards
  1. No beep at all - this means your motherboard is dead, either due to a defective or underpowered power supply, poorly seated CPU or RAM, or a dead-on-arrival board
  2. One beep - board is working fine
  3. One long beep then machine shuts down - faulty, improperly installed or missing CPU
  4. 1 short(Beep) System booting is normally
  5. 2 short(Beep) CMOS setting error
  6. 1 long - 1 short(Beep) DRAM ERROR
  7. 1 long - 2 short(Beep) Display card or monitor connected error
  8. 1 long - 3 short(Beep) Keyboard Error
  9. 1 long - 9 short(Beep) ROM Error
  10. Long(Beep) continuous DRAM isn't inserted correctly
  11. Short(Beep) continuous POWER supply has a problem
  12. A two-tone siren, generally caused by overheating or out of specification voltages
  13. Four beeps then machine shuts down. This is because this version of the BIOS will shut down your machine if no fan tachometer signal is detected on the fan header. Make sure you attach a fan to the FAN1 or FAN4 header or clear CMOS to reset to default (no checking).
Sep 07, 2011 | Abit AI7 Motherboard
My Computer working properly but some time suddenly monitor turn off (not standby) that time restart / power off button not working.only way to restart/off computer unplug power cable. after restart same...
Hi friends ,
It is *********** board problem,Because the over heating. Go to bios and set the FAN control disable.
If same problem
Change the CPU FAN .
If the problem same .
You will think, the censer of the mother board, has damaged and that's why,censer of the mother board think that CPU is cross the temperature limit. It is the main reason.You need another mother board,sorry to say you.
Hope it will help you.
Dec 20, 2010 | Intel D915GAV Motherboard
My pc monitor is blackout and no beeps whaen i start up even my hdd is not spinningmy cpu fan is working what is the problem tell me what can i do pls , As done by me----- 1. Clean the RAM memory and try...
If do not hear any beep then it means that the mother board is dead you can try clear the BIOS by removing the battery of the mother board for 5 mins or by shorting the jumper for clearing the BIOS if that didn't help then you have to repair the board or replace it.
Feb 09, 2010 | Asrock P4I45GV R5 Motherboard
Asus motherboard
You'll just need to troubleshoot a little. 1: Try the monitor itself on a second PC. 2:If it doesn't work you've found your failing component. 3: If it does work try the PC<-->monitor cable on another PC. 4: See step 2. 5: If that also works, your graphics card is the only thing left. Take it out and put it in another PC. 6: Repeat step 2. 7: One of the components I listed should be the broken one. Of it isn't please post back here. I hope this helps, Yannick.
Jun 08, 2009 | ASUS P4S800-MX Motherboard
I have an asus a7n8x-la mother board. It ran fine except the cpu cooling fan would speed up and the cpu heat sinc was very warm as compared to others. Finally it would not boot or go to post with the beep....
First of all set the BIOS default.
i think somebody change your Bios settings like-- over clocking or speeding fan etc etc.
add comment for further assistance.
Good Luck!
neo
Feb 27, 2009 | ASUS A7N8X-E Deluxe : ATX Socket A FSB400...
Beep problem
Hello niceguy_jes2,
click on this link for the ambulance like sound beep description:
http://www.bioscentral.com/beepcodes/awardbeep.htm
"High frequency beeps while running". "Check the CPU fan for proper operation. Check the case for proper air flow".
First item to check would be CPU's fan speed. To do this, enter your bios menu. Listed there is "H/W Monitor". Open it. Check the fan speed, CPU temperature & mother board temp. Chances are the CPU fan is turning too slow & it may need to be replaced. (No less than 2300RPM's). Average CPU fan's spin at 3000 plus).
Next item if CPU fan is ok. The thermal grease between the heat-sink & CPU may have dried up over time & cause the CPU to get too hot. You may need to remove the CPU & heat-sink assembly. Clean off all old thermal grease from the bottom of the heat-sink & from the CPU. If you do this, do not scratch either surface. Use house hold alcohol on a clean rag & wipe away all old thermal grease. Apply a tiny amount of new thermal grease. Re-assemble & check through bios H/W monitor, CPU temp. One or the other will stop the system beeps.
Link to MSI: http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=237
Good luck niceguy_jes2!
Post if there are troubles.
Thank you for using fixya.
Mike
Jan 07, 2009 | MSI K8MM3-V Motherboard
No beep,No Display on my monitor,only CPU heatsink fan is moving
have you thought about changing the battery on the motherboard, also checking that the fan on the cpu is seated properly with enough heatsink paste as both these issues will stop the pc from booting
Oct 29, 2008 | Asrock K7S41GX Motherboard
No video.
Try to check your monitor cable.. Is it ok?
Sep 19, 2008 | EliteGroup ECS P4M900T-M2 Socket 775...
Dell XPS 400 Card Cage Fan Failure
dell xps 400 pentium d once i turn it on, it beeps and says "card cage fan failure" everytime i press f-1 to continue it shuts off and boot up again it does it everytime how can i fix this CARD CAGE FAN FAILURE??
Apr 22, 2008 | Dell XPS 200 PC Desktop
Motherboard problem
if you have tried resetting the bios by putting the jumper across pins 2-3, then back to pins 1-2 and it still wont boot into the bios and you know the memory is ok, then the bios chip on the motherboard is damaged and may not be easy to replace as the board is quite old.
Aug 11, 2007 | AOpen AX45-V (91.88I10.004) Motherboard
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
