Question about Whirlpool Duet GHW9150P Front Load Washer
F35 error code - Whirlpool Duet GHW9150P Front Load Washer
  • 15,935 Answers
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
  • betsillfamil Oct 05, 2010
    THIS PROBLEM WAS EASILY RESOLVED WITH THE HELP OF YOUR WEB SITE. THANK YOU VERY MUCH FOR YOUR HELP. JOHN B.
  • jtow512 Jul 19, 2011
    1.) The Purchase:
    I purchased my Duet Steam Model Number WFW9500TW01 on 11/04/08.
    2.) The Problem:
    7/1/2011 It started getting the F35 error.
    3.) The Troubleshooting:
    I was able to open the top of the washer and go through some of the troubleshooting that I saw online (disconnecting the hose, blowing back into the washer) which seemed to fix it for about 10 loads but then again it started SUDS / F35 non-stop. I called a local repair service and found that I needed the “analog water pressure level sensor” which apparently had been discontinued by Whirlpool and replaced with a re-engineered part.
    4.) The Part needed out of stock and backordered for months:
    Old Part: W10156252
    New Part: W10415587
    The local repair service said that the part was on national backorder and according to their main supplier it had been so for 2 months. The new shipment of these parts was supposed to arrive 7/18/2011. On 7/18/2011 nobody called me to tell me whether or not they were in, so I called Whirlpool and escalated the issue with them.
    5.) The call to Whirlpool:
    First I spoke with Emma, she confirmed the part was now on a preliminary delivery date of 7/29/11. I shared my frustrations and she transferred me to a “specialist”, who, spoke as if she was chewing her own face - her name was “Candy” from Tennessee. I knew that I wasn’t going to get anywhere with her so I escalated to her manager “Austin”. “Austin” tried or said he tried to find the part from a couple of sources but couldn’t. He said:
    “Sir, in this case what we need to do is get this to our Product Review Board who may offer you a replacement unit. They will call you within 24 hours”.
    6.) The call from the Whirlpool Product Review Board:
    The next day 7/19/2010 a woman named Tihate called me and said that I qualified for a new replacement machine. She went on to explain that it was a newer model but would still fit on my pedestals that I purchased and would be white like my old model.
    6a.) One Small Thing:
    Tihate added that there would be a small fee for the new washer of $578.57
    7.) The final resolution.
    I politely declined her offer. I will now wait for the part, fix the washer and sell it along with every Whirlpool, GE and Maytag appliance in my home.
    My new LG washing machine will be here tomorrow, with a standard 10 year warranty which costs about $150 more than the replacement from Whirlpool.
    P.S.
    Tihate’s direct number is 1-866-640-7146 ext 6496
Pull the lower front cover of with 3 torx screws. There is a strainer inside the 3" pump cover.(white cover unscrews by hand) be careful if the washer still has water in it, slowly unscrew the cover with a pan under the machine so water can drain first. Pull the strainer and clean all the junk out of it. Feel inside the pump fins for other obstructions. Put it back together and problem solved or you need a new pump.
This should be done every year but they won't tell us that at whirlpool so they can keep selling pumps! I lost a pump on my old machine and figured it out. My new machine just did the same thing and I cleaned it, now running good again.
Posted on Mar 10, 2011
  • dwitter Jun 30, 2011
    I found two pennies and a screw, removed them, now my washer works.
    Here is a link to a picture:http://neighboursappliance.com/2008/01/d...
  • bartalm Jul 31, 2011
    great advice! followed the instructions, cleaned out the gunk and got it working! thanks for the water tip btw!
What is the solution of error35 in w455h washing machine
Hi! If you mean error F35, this error code indicates an analog pressure sensor error. This sensor is the component that detects water level in the washer tub.
F35 error code can be caused by a problem with the air pressure tube between the bottom of the washer tub and the analog pressure sensor.
Apr 27, 2017 | Washing Machines
What is an F35 code?
The F35 error code is indicating the analog pressure sensor switch is either bad or blocked. Go to managemylife.com and put in F35 error code to see location and description of part.
Feb 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Code F35
hello
what The F35 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F)
The f35 error shows you and indication that ice maker sensor readings are out of normal range.
then what you need to do to fix up the problem is to bale out the water from it then clean up all form of water ant dry you can see from the screen
Please before you can carry out this instruction you will have to put OFF all source of power supply .
thank you and good luck.
Jun 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Code f35 and sud on washer machine/whirlpool duet front loader
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^
May 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code washing is delayed wil wash half the clothes
Mar 06, 2010 | Whirlpool GHW9300 Duet Washer
F35 message, will not run through cycle. Starts to and then the F35 starts flashing and eventually shuts off.
Check between door boot seal and drain hose in basket. If this is clogged with lint or sock, towel it will code f35 or sud
Oct 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Steam washer
HELLO.F35 IS A ERROR CODE WHICH NEEDS THE ASSISTANCE OF A WHILPOOL SERVICE AGENT.THE CONTROL BOARD MIGHT NEED TO BE REPROGRAMED BEFOR YOU CONSIDER REPLACING IT.GOODLUCK.MOHAMED
Sep 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error code f35
konica f 35 eror code
Aug 06, 2008 | Office Equipment & Supplies
Whirlpool Duet GHW9150P Front Load Washer Logo
2,863 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
