I would like to conect my laptop to my LCD TV,I did it before but now I can not do it,I have 14 pins VGA cable conected direct to the TV -PC outlet. TV is seted on PC input. Please help me.
    Scholar:
  • 128 Answers
Press FN button together with the function button on your keyboard that has the image of 2 monitors. try pressing these button together and see if you can come up with a selection on your screen. There are 3 options under this function. It will be the main monitor option, Extending monitor 1 to monitor 2 option and lastly disabling monitor 1 while using monitor 2 option.
Should you have any other questions just please leave a message.
Cheers~
Musicaddict
Posted on Sep 11, 2010
What cable do I need to conect my HP computer to my Element TV?
check computer and tv for same type of conection - VGA, DVI, HDMI
Oct 15, 2012 | HP Pavilion dv4-1028us 14.1" Widescreen...
How to add tv as external monitor
OK first MSSWIN1 there are a lot of missing info in your question. Does your tv has a vga conection if it does this is easy just conect the vga cable to the the computer and the tv and the computer will dectect the tv authomatically if you're running on windows if you wantto use the computer's screen (that is if its a laptop) and the tv at the sametime you will have to go in to the settings and change it. { control Pannel=Appearenceand Personalization=Display=connect to an external display. .. Somepc's will alow you tochose fromprimary to secodary monitor,
OK if your pc does not have any VGA connector you will need a VGA to RCA convertor dont buy the cable (VGA to RCA) those don't work you will still need to buy a conversion box
Sep 22, 2012 | HP ProBook 4430s Notebook
How do I connect my laptop to the TV with HDMI
You will need an adapter (VGA to HDMI) you will conect it as a second monitor, if your TV has a VGA connector you can just plug your laptop in directly. thundersecurityonline.com
Apr 28, 2012 | Computers & Internet
I want to use my Thomson 32HS2244 as a PC monitor. The PC has no HDMI. How can I connect?
dear user,
if there is a VGA input available on LCD then conect VGA cable 15/15 mean 15 pins are active and connect it with pc.
Feb 04, 2011 | Thomson Televison & Video
I connected my 65 inch panasonic viera tv to my laptop but get a black tv screen, help?
If you are conected VGA cable set your TV to PC input. When you turn your laptop press fn then
f8 that should transfer the signal to the LCD.
Thank you
Dec 12, 2010 | Panasonic Viera TX-32LX70 32 in. LCD TV
Conecting laptop to tv
1. S-Video ? This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You?ll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC?s are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work. 2. VGA ? If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won?t find a VGA port on regular TV?s though, so this option is if you have an HDTV. 3. DVI - DVI stands for Digital Visual Interface with ?digital? being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80. 4. HDMI ? Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI. 5. Scan Converter Box ? This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
Apr 07, 2010 | Hannspree XV37 HDTV 37 in. LCD TV
Can not conect my computer to my lg lcd tv
Turn Off Your TV and Laptop before connecting the VGA cable. Turn them on after you have connected both.
Apr 13, 2009 | LG 32LG30 32 in. LCD HDTV
Display my laptop on my tv
You can't connect a standard TV to a computer using a VGA cable. If you have it, use the composite (yellow) RCA jack or S-Video from your laptop. As for turning off a laptop monitor, look on the function keys for LCD/CRT or icon for monitor (typically 3, 5, 7, or 8) hold down FN key and press the correct function key.
Jan 13, 2009 | Samsung SyncMaster 940MW 19" LCD Monitor
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
