Question about LG WM-2277HW Front Load Washer
Detergent tray stuck on LG Tromm front loading washer, model WM2077CW
5 Suggested Answers
dutchman05
  • 487 Answers
SOURCE: I have a LG tromm
Here is your SERVICE MANUAL
Posted on Jun 23, 2008
SOURCE: LE code appeares on my LG front load washer
A majority of the time when the LE code appears.. the Hall sensor in the motor is bad. Replacing it. Part # 6501KW2002A from MCM electronics... can help. Good luck.
Posted on Dec 02, 2009
SOURCE: LG Tromm Front loading Washer,
I've got the same issue!! I can't get it open it must be jammed from the tray inside!
Posted on Aug 18, 2010
  • 298 Answers
SOURCE: I have an LG TROMM WM2077CW front loader washer.
you can go appliancerepairplanet.vstore.ca and you can get help there.
Posted on Dec 15, 2010
LG Tromm wm2077cw front load washer would not drain Looked at drain pipe and drain pump filter, both was good no clogs
Does the pump work? if so common problem is something stuck blocking the sump pipe between drum & pipe 2 the pump
Dec 23, 2015 | LG Washing Machines
Detergent dispenser is stuck and cannot open on LG Tromm washing machine
There is a small tab that one has to press down to unlock the retainer clip.
Press this down while pulling the tray outward.
Aug 06, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lg tromm washer leaks from detergent drawer
my washer also was leaking from the dispenser and I had a cap from one of the detergent bottles stuck in the inlet hose. Don't know how it got in there but glad I found it so if your washer leaks from the soap tray it could be a cap from your detergent bottle stuck in there.
Nov 04, 2012 | LG WM2688H Front Load Washer
LG WM2077CW Front Load Washer Problem My LG Tromm model # WM2077CW is leaking at the bottom of the machine but not from the door. If you run your hand along the bottom front of the machine there is a seam...
MOST OF THE TIME IT IS A HOSE THAT HAS RUBBED A HOLE IN IT OR THE DOOR BOOT DRAIN HOLE. THE HOSE IS ATTACHED TO THE BOOT BOTTOM CENTER OF THE BOOT AND HAS A SHORT HOSE THAT RUNS BACK TO THE TUB..
Apr 25, 2017 | LG WM2077CW XL Front Load Stackable Washer...
LG Tromm Front loading Washer, wm2277hw -detergent tray will not pull out.
Aug 16, 2010 | LG WM-2277HW Front Load Washer
Water remains in detergent drawer
bpkaplan - did you find a solutiion? I have the exact same problem with my LG Tromm WM2477HW front load washing machine. It is about 2 1/2 years old.
Nov 24, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG TROMM Model WM2077CW-mildew on rubber
First and foremost you MUST use an HE detergent, HE(high efficency) is design specifically for fontloading machines.. and use little amounts of it, 2-3 tablespoons is all that is required to clean a full tub of clothing.
Jusst using less of regular detergent is not the same as using correct soap. the moldy smell and black filth when the front bellow is pulled back is actually residual detegent not being disovled in normal operation , all front loading washers are experiencing this issue, there is a new product on the market to help combat this problem and for the 1-2 months ive been reccomending no one has told me that it hasnt helpd. heres the link www.affresh.com
Apr 09, 2008 | LG WM2077CW Laundry XL Front Load...
Lg tromm soap dispencer won't open
nothing to lock it fully closed......pull harder!
Jul 21, 2007 | LG WM2077CW Laundry XL Front Load...
LG WM-2277HW Front Load Washer Logo
161 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
