Question about Dell PowerEdge 1800 Server
Cannot get PE1800 to boot. Was working fine. Replaced two 2.8ghz processors with two 3.6ghz processors (SL7PH, per Dell tech support). Monitor would not come on. Removed RAM, per Dell - no beeps. Dell tech said possibly bent pin on replacement processor must have shorted out motherboard. Replaced motherboard (ver 2) with BRAND NEW motherboard (ver 3), again - per Dell tech support. Replaced both 3.6ghz processors with brand new ones. (Dell tech said we may have shorted out both the motherboard and the processor). Now, with a brand new Dell X7500 motherboard and brand new SL7PH processors, computer still won't boot. Same problem (monitor doesn't seem to receive any signal) only now the fan doesn't kick into high speed when booting, either (it did before). Now Dell techie says to replace the PDB/PDU. I hesitate to spend more $$$ if success is unsure. Any ideas?
  • Mark Waterhouse Sep 11, 2010
    Already did that - no luck. This is a brand new Dell motherboard - came sealed in Dell electrostatic bag. It's odd that I'm having the same exact issue with the new board as the one that Dell said has probably shorted out.
  • Mark Waterhouse Sep 13, 2010
    Hi - Don't know if you got my prior reply as I can't find it on the fixya website. This is, however, my first time with fixya and maybe I just can't find it. So if this is a duplicate, please forgive.
    Do you mean I should replace the PSU before replacing the PDB (PDU)? This server has a redundant power supply (two power cords), both with green lights. The lights on the control panel also light up. Before purchasing a new Power Supply Unit I just wanted to confirm that I should start with the PSU and not with the Power Distribution Unit. I've already found a PDU, although I haven't ordered it yet. I will search out a new PSU while I wait for your reply.
    Thank you, once again, for your help. You've been much more knowledgeable than any of the 5 Dell techs that I've contacted. I appreciate your time.
  • Dell Master
  • 12,061 Answers
I would wonder if your PSU, may be faulty, Please replace it, ALWAYS start with the Power Supply, as if this ins't 100% A OK, NOTHING else can be right, so that's always the first place to start. One MUST get "Known Good" bits, to work with, then add know good bits together and it MUST work, just be methodical, and go small step, test, add, small step test add.. and so on..
I doubt you have bent pins or anything such, you seem very competent, so work through it with you manual. Also it would be beneficial if you tried to get a Service manual from Dell, this will assist you a great deal in troubleshooting.
Now IF you are sure all is A OK. then move on to the MB & RAM, with NOTHING else connected, Hook up the PSU, MB, CPU. ONE stick of RAM. NO HDD No DVD No Nothing else.
Now try to boot, if it does then add the other devices and all should be good.
Now if it doesn't, then.. try a NEW stick of RAM NOT one of the ones you have now, a NEW one.
If it boots now, all good, add as before. If it doesn't boot at all. Then remove the CMOS battery for a few mins, and replace and try again, now check you MB manual, and see if there are any keys that can be held down during boot, that can get you into a boot mode.
As an aside here try to get the MB going FIRST with the OLD CPU, if possible. Then, when it's all working, replace the Processor, see what happens.
Now Have you checked any all jumpers if any on the MB, are they all set correctly, check your MB manual, I have included a copy below for your convenience, Make sure everything is setup correctly first.
Try getting it up and running with a single CPU, then shut down and ADD the other CPU, just take it little steps ... and build it up as you prove each GOOD bit, then ADD another piece, and so on, until you have a working PC.
http://www.retrevo.com/support/Dell-1800-manual/id/15529ag218/t/2/
Posted on Sep 12, 2010
    Genius:
  • 1,035 Answers
Hi. Since this is almost a new system that you just setup. Try to drain the elctrostatic energy of the mainboard. Take out the battery and unplugged the power adapter. Press and hold the power button for 30 secs then turn ON the computer. if nothing happens then this could be a motherboard issue.
Posted on Sep 11, 2010
No sata present but it boots
try working on your dual core processor i have a dell inspiron 531in have to do the F1 thing also to boot up in thin it work fine.
Jan 04, 2013 | Dell OptiPlex 380 PC Desktop
Dell latitude d600- won't boot up!!!
Yes this can be a opverheating problem that's why sometimes it boots up, if the processor is not working fine because of overheating you check first the cooling system of your computer liek the fan if they are working fine because if the fan is not working the way it should be working oeverheating may occur and will result to this problem...
Hope that helps.......
Aug 06, 2008 | Dell Latitude D600 Notebook
I purchased 2 GB chips to try to increase the speed of my desktop. After putting in the chips my computer won't boot back up, my monitor is black and the computer is making a constant beeping nois
OK. First, I'm assuming that you have a Dell Vostro 200 as per the topic title. That said, you machine has a maximum memory capacity of 4GB. So, if you added the 2 - 2GB DIMMS in slots 3 and 4, leaving your original memory in the machine, you will have problems. You must be using DDR2 667 or 800 MHz RAM and the two DIMMS must be in slots DIMM1 and DIMM2 ( closest to the processor). No more than that can be installed.
Apr 03, 2012 | Dell Vostro 200 PC Desktop
Dell PowerEdge 1600sc server won't boot.
> black screen & flashing cursor ...
Damaged boot-record on the disk-drive???
Was it configured to try to boot from 'A:' ?
Disconnect the hard-drive & CD/DVD drives.
Put a diskette into the drive, and see if it tries to find a boot-record on the diskette.
If it tries, then it has P.O.S.T.'d correctly.
> no beep codes
When it worked, did it beep _once_ when P.O.S.T. completed?
Taking out the RAM _should_ cause some beep codes, i.e., "no RAM".
> anyone?
Replace the monitor?
Replace a dead video-card?
Or, add-in a video-card, and connect a monitor to it, leaving the original monitor connected to the original video-card. One of the two displays should show the P.O.S.T.
Jun 12, 2010 | Dell PowerEdge 1600...
Hi, my Dell Vostro 200 monitor isn't working; when I boot up the light is blue and everything else seems to work but the monitor says 'Entering power save mode' or something and it shuts off. I can't get...
Your monitor is most likely fine. That message is the monitor telling you it's not getting any video signal from the computer.
If you're hearing all the sounds that go with a normal startup (usually a beep from the motherboard, then hard drive activity, finally the normal Windows startup sound through the speakers), and seeing that message, then you may have a monitor problem. You can try another monitor as a test.
The trouble is probably that the computer is turning on, but not actually starting up. This may be due to power supply, memory, processor or motherboard problems. Or one of the drives or expansion cards connected to the motherboard may be keeping the system from starting.
Make sure the memory modules are firmly seated in their sockets, and disconnect everything else but the power supply. If the motherboard, processor and memory are working, the system will start and you'll see something on the monitor. Then you can start reconnecting parts and see when the problem returns.
Mar 30, 2010 | Dell Vostro 200 Mini Tower With 20" Flat...
I plugged my LG flatron into a dell x150. I can see up till Windows starts booting and then it cant read the signal. The dell works fine with a old sony monitor not sure why. Flatron works with every other...
If you would start the Dell in safe mode, you should be able to adjust the display settings to values that will work with the monitor. Or remove the monitor in the device manager and let windoze detect and configure the monitor on the next boot.
Nov 12, 2009 | LG Flatron L1510S 15" LCD Monitor
Not booting up
try changing your memory or your processor. you might get a result
Jun 11, 2009 | EliteGroup ECS L4VXA2 (CDL4VXA2)...
I cannot start my Dell Latitude D820 unless I put it in the refridgerator for about 1/2 hour. If I do a restart, then I can hear the disks start, but the comminication to the monitor during bootup seems to...
It sounds like the processor is overheating.
Possible resolution is replacing the processor heatsink and cooling fan, see if the system runs better. Also, if possible, flash the BIOS to the most current version
Apr 26, 2009 | Dell Latitude D800 Notebook
Monitor black screen prob
disconnect the monitor from the back of the system and see if u see the colour scheme or anything if u do see something that means monitor fine ... problem with system
Sep 19, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Using CRT monitor
try back to other machine again.
Apr 22, 2008 | Dell E176FP 17" LCD Monitor
Dell PowerEdge 1800 Server Logo
177 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
