Question about Logitech X-540 Computer Speakers
Speakers don't work and all wires are connected
  • Logitech Master
  • 27,725 Answers
Control panel sounds and audio,audio make necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
good luck
Posted on Sep 11, 2010
I have connected my dv720 i have no sound and a blue wire a blue and white wire and a beown wire not doing anything should these be connected to something if so what?
The blue/white wire is amplifier remote turn on, so if don't have an amplifier you don't need to worry about it. Just cap it off so it doesn't short to anything. I'm not completely sure, but I think the brown wire may be a phone mute wire. You don't necessarily need it either. If you have no sound, you may want to check your speakers and speaker wires for any shorts, grounds or bare spots.
Nov 07, 2012 | Car Audio & Video
My left speaker is not working and it isn't the cable connection. It has been checked and the plug is in all-the-way.
You could just have a loose wire inside the speaker but sometimes one speaker will just go to speaker heaven. Sorry I can't give a better answer and I don't know that brand so I don't know if you can open up the speaker easily to see if there is a loose connection. Now, sometimes the plugs can just wear out too which can be replaced if it is a great set of speakers but again, back to the lack of knowledge about that brand and how hard it is to work on.
May 22, 2012 | JBL Audio Players & Recorders
Why is there four plugs on the back of speakers?
With four plug you will have a jumper from on plug to the other. (e.g. Positive to positive and negative to negative.) This is for single connection (two wires.) If you use two connections (four wires) you take out the jumpers. the bottom pair is normally for the bass and the top for treble. This is to make the speakers clearer, and sound better. As for louder,? I don't know some people think it does some don't. With better clarity of sound, you do get the feeling of it being louder.
Apr 27, 2012 | Audio Players & Recorders
My rear passenger speaker wires don't work, I have connected 3 different speakers to them none of them work but those 3 speakers work when they are hooked up to different connections.
have you tried connecting directly to the radio? I would suspect a broken wire or a bad fader control or switch depending on the model.
Jan 31, 2012 | 1998 Ford Expedition
Hooked up a cd player to my 2005moms grand am but volume don't work? Why?
Check to make sure it is not manually muted, if that doesn't work make sure your speaker wires are connected properly in the back of the radio and speakers work also. If it is run through an amplifier, make sure the amp works and the speaker wires are connected properly too! Don't forget to check gain on the amp too!
Jan 16, 2012 | JVC Car Audio & Video
My monitor speakers don't work, but I see an extra connection that has no wires attached is that for the for the speakers??
The monitor should have a wire that goes to the green colored input plug on the back of the PC.
Sep 07, 2011 | Soyo DYLM2286 Monitor
My TX-SR500 rear speakers stopped working,I tested each speaker using the channel select to optimize the rear speakers but the left and right front speakers were adjusting instead and I know I have the...
And you don't think the speakers are wired wrong. Re-investigate or reposition the speakers you THINK are Front to the Rear and go on from there.
Jul 31, 2011 | Onkyo TX-SR500 Receiver
I have a pair of DCM KX-12 speakers and one of the tweeters don't work changed the tweeter and still don't work any help????
Make sure hat there is not wire damage. Next you will need to check if there is voltage coming form the wires that connect to the speakers. This requires a volt meter. If there is no voltage then either there is a break in the line, a bad connection or the feed from the pcb is bad. Next step with no voltage woudl be to replace or resoldier/reattach the wire to the pcb or connecting object.
Jun 29, 2011 | DCM KX-12 Speaker
Right speaker went out.. Opened fairing and tested speaker by hooking up to left wires... Speaker works so I'm hoping that the wires don't need to be replaced... Any suggestions?
If the RH speaker works when you conected to the LH side, I would suggest a wiring problem to the RH side... You may have to ferret out where the wires go to find a bad or broken connection. It may sound stupid, but make sure you havent got the "balance" control on the stereo set to left only.. Make sure its in the middle so both speakers are supposed to be working... Hope you find out what it is... Cheers
May 29, 2011 | 2007 Harley Davidson FLHX Street Glide
Logitech X-540 Computer Speakers Logo
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
