Question about GE 24 in. Profile PDW9880JSS Built-in Dishwasher
My GE Profile model PDWT180R10SS after it goes through a complete cycle it keeps water on the bottom.And I have checked drain for blockage and it is clear.This is not very old it's just a few month's old and I did read the manuel that came with the dishwasher.It does read that it will some water at the bottom. But I don't think it should as much that I am seeing.Thank you if you can help.
SOURCE: Dishwasher doesn't drain
Catriver: The dishwasher model is gsd5920do1bb. I probably posted the original problem in the wrong place. Does a similar fix apply? Sorry about the confusion. Greg
Posted on Jan 30, 2007
SOURCE: GE Dishwasher GSD4020Z07BB is leaking water and doesn't drain
yes...mine leaks at the door base as well
Posted on Jan 30, 2008
  • 105 Answers
SOURCE: bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
Posted on Feb 24, 2008
SOURCE: GE Profile Dishwasher with water in bottom, won't drain
I have the same dishwasher and encountered the same problem last year. What I had to do was call a plumber out. But all he did was clean out a plastic compartment in the bottom of the dishwasher then turned on the garbage disposal for a few minutes. There was some larger debris under the plastic compartment and the problem was solved. I am however now experiening a different problem w it. Good luck!
Sandi S
Lexington KY
Posted on Sep 21, 2008
SOURCE: GE Profile Dishwasher does not drain. model #
I had a similar problem with a GE GSD5811 model. The hoses were clear, and the auxiliary pump worked fine. It turns out that it was the "piston" assembly that had basically disintegrated over time. This part diverts water to the pump during the drain cycle.
To check it, remove the mesh filter at the rear of the inside of the machine, by carefully unclipping the heater element from the back of the machine and removing the 4 hex-head screws securing the filter panel.) Unscrew the piston assembly from the tub, and pull it out. If the sealing plunger has deteriorated or is jammed, replace it. The part number for the "piston and nut assembly" for my machine (and probably numerous others) is WD24X10018. It should cost anywhere between $10 and 16, depending on where you shop.
Another possibility is a bad drain solenoid. (This is what actually triggers the piston assembly during the drain cycles.)
Posted on Apr 08, 2010
I have a kitchenaid dishwasher model number kudso2sr and there is standing water in the bottom of the unit after the cycle is complete. The water will not drain. I ran another cycle and the water still...
you may have a vacume issue
along side of the dishwasher itself there is a loop of drain hose to create a trap - inspect. also inspect where it is hooked up & follow where the drain hose goes to it's final connection to be sure there are no up hill runs or other blockages.
Speaking of blockages,. did you inspect the dishwasher drain very well to be sure it is fully clear and somethign is not stuck in under the water?
If need be pull the machine out from under the counter and check the side hose and unhook the drain where it goes into your house plumbing...
Dishwashers can be cluegy when it comes to draining...
Jan 05, 2011 | KitchenAid 24 in. KUDS02SR Built-in...
I have a GE Profile side-byside fridge. I have ice that forms on the floor every three days or so. I unplugged the water, but that is not the problem.
I would check the defrost drain for blockage. Unless this is completely clear the defrost cycle will continue to let water run inside instead of into the pan underneath. It is easiest to work on this if the freezer is completely empty and the back panel inside is removed. While it is opened up check the defrost heaters as the lower one is more apt to have failed.
Eric
Aug 26, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
The drain in the bottom of the freezer compartment seems to be clogged. It ices over an eventually and water drains out of the bottom of the door. It is a GE Profile. Is there a pan underneath that the...
You will need to remove the rear freezer wall I have a collection of photos I wish were mine but I do link them to their owners. So Follow me back to Sea Breeze Tip's and scroll to bottom of page where there are many ways people attempt a unclog the freezer drain. Sometimes it is slime build up that starts the cycle and sometimes the refrigerator is leaning a little enough to allow the water to pool on one side and creep as a frozen pool until the drains completely shut, One moment as I get the links Sea Breeze
Apr 10, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE Fridge/Freezer, defrost cycle leaks water in freezer bottom
Hi, this is because the defrost drain is blocked. Follow this LINK which will take you to my tips and full instructions on clearing the blockage. If you have any additional questions please feel free to comment. Mike
Dec 27, 2009 | GE Refrigerators
Water is leaking in the freezer underneath the vegetable bin. Anybody knows what the problem maybe and how to fix it?- GE MAKE 685 ENERGYSTAR
I believe your defrost condensate drain has a blockage of ice and will need to be defrosted and clean the condensate line from the freezer to the condensate collection plate below your refrigerator. Most times the blockage begins slowly until the opening of the drain hole under the evaporator freezes itself shut. Below is a link to some solutions I have collected over a period of time. Also has a short movie that makes the repair look simpler. There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
click on link below
Sep 22, 2009 | GE Profile¿ Energy Star® 25.5...
Water pooling on bottom of dishwasher
Check the drain pump for debris that might be stopping the drain pump from working. Also could be faulty drain pump.
Feb 20, 2009 | GE 24 in. GSD4320Z Built-in Dishwasher
Ge profile leaks from front of freezer
your drain will be plugged under the tray. there is a hose that runs to the drip tray. the back cover comes off you can then get at the hose
Sep 05, 2007 | GE GSS25JEMWW Side by Side
Greg, if the model number ends in GO1, your dishwasher has a piston nut assy. thats problably giving you the grief. If this assy. goes bad you will have water left in the tub at the end of the wash. A common GE problem. It's located under the filter screen in the back and just unscrews out. Part number is wd24x199. It's an easy fix. Look up the part on the net to get an idea of what it looks like. Catriver..post back.
Jan 25, 2007 | GE 24 in. GSD1000G Built-in Dishwasher
GE 24 in. Profile PDW9880JSS Built-in Dishwasher Logo
308 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
