Question about Maytag Neptune FAV6800AW Top Load Washer
I have a Maytag Neptune TL washer that won't drain. I took the front panel off and detached the hose from the pump and there were several coins in there. I removed the coins, reattached everything and tried to run another load. But when it attempts to drain, I hear a rattling - almost like more coins but they are in the drum of the washed somewhere. I have no idea how to get inside the drum to look for floating coins. Do you have any suggestions?
  • 526 Answers
For the FAV6800A or FAV9800A tumbler removal.
The Service manual has the procedure starting on page 37 for the tumbler removal.
It’s not difficult to remove the manual doesn’t call out the Torx driver size required for tumbler removal. You will need a number 20 Torx driver to remove the Torx screw for tumbler removal. I would get a long Number 20 Torx driver for this. See page 37 of the Service Manual for tumbler removal. Looks worse than it is.
The Service Manual for reference. Sears Parts Direct for reference.
When I did a recent Outer Tub Bearing replacement I found $1.78 in coins after removing the wash basket. Gotta check those pockets....:)
I have a post around somewhere of my diy Sump Screen I put in my FAV6800AW to protect the drain pump impeller from coins and other stuff from breaking the impeller or causing clogs. I'll look for the post or repost the pic's.........D*ick
Posted on Sep 12, 2010
  • FAV6800A FAV9800A
    FAV6800A FAV9800A Sep 12, 2010
    Found my old post of the sump cap filter screen I made some time ago. See the last comments of this post.
    http://www.fixya.com/support/t1929398-du...
  • dbrewer265 Sep 12, 2010
    Thanks for the update. I was able to get the plates out and found a LOT of change under each of them - enough to pay for a new torx wrench, at least :^D
    Thanks to everyone for the excellent service. My washing machine is now running as good as new!
Leaking maytag neptune washer
The pump and its various hoses are easily accessable through the back panel. The boot can collect coins which can block the pump. Squeeze the boot and empty it of all coins. Coins can ruin the impellers on the pump. A new pump costs $100 on line. The drain hose can be plugged by dimes and pennies. Good luck.
May 28, 2014 | Maytag Neptune MAH5500B Front Load Washer
How to fix the pump in maytag neptune washer
Remove the back panel there are four screws in panel. the pump is acessable on left side facing back. The pump is bad or you have something stuck in the pump.eg.bobby pin, bra support wire, and have found coins in them also. Have towels handy to absorb the water.
Feb 14, 2013 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH8700A tha detergent drawer is filling up with water and running out of the drawer onto the floor not going into the tub.
see this causes and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Oct 11, 2012 | Maytag Neptune MAH7500WH Front Load Washer
Maytag Neptune front load washer won't drain water
maytag performance series washer front load drains very,very slow
Apr 07, 2012 | Maytag Washing Machines
My maytag washer leakes, all the water runs out on the floor.
Remove the rear access panel to check the source of the leak. The drain pump is most probably broken or the sump hose is damaged or detached from the tub.
Drain Pump Removal/Replacement Procedure (Maytag Neptune MAH5500B)
  1. Safety first. Unplug the machine.
  2. Remove the hose clamps and hoses from the pump.
  3. Disconnect the wiring harness from the pump and the pressure switch terminals.
  4. Rotate the pump assembly counterclockwise and remove it from the base of the washer.
  5. Remove the plastic bag covering the pressure switch.
  6. Press in the locking tabs on the back of the pressure switch and pivot the pressure switch off the pump bracket.
  7. Grasp the pressure switch and lift the nipple off the pump cap.
  8. Install the pressure switch on the new pump in reverse order of the removal steps.
  9. Install the new pump in reverse of the removal steps above.
Jan 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune won't drain
your pump is clogged with matt mud...
remove the back panel
the pump will be right on the left
two hose clazmps
you will loose a gal water
1/4 turn on the pump it will now come out
disconnect the two wires...
clean the pump out and try to clean out sump hose and drain hose
sump from tub to pump
darin pump to drain
reassemble your done
Oct 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Machine washes but won't drain
sound like the drain line is plugged or kinked. Inspect drain hose
Jul 24, 2009 | Maytag MAH6500 Neptune Front Loading...
Maytag Neptune nd error code
will heres some of the easy test,,,check drain hose for blockage,,,ckeck punp for coins always unplug unit..now this is more serious so be careful..ckeck for 120 volts at the pump..its a electric,,,,im here if you needed me
Dec 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer Not Spinning All Of The Water Out
It's not supposed to. They all keep water in the drum after wash is finished. Was told by Maytag its to keep the balance of the spin cycle, like balancing a tire with lead weights.
Dec 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune TL FAV6800AWW Overflows
Check the pump, pressure switch and related hose for small obsctructions. For reasons unknown they moved the pressure switch location to above the pump. d60f89f.jpg
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
192 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
