Question about Kenmore 54662 / 54664 / 54669 Side by Side Refrigerator
Not getting cold. - Kenmore 54662 / 54664 / 54669 Side by Side Refrigerator
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 11, 2010
Why does my Norcold fridge on Jayco 2014 come on but does not get cold?
if chimney cold check heater element and LP for flame if chimney hot unplug thermistor from control board let run if gets cold replace if not either bad board or cooling unit
May 16, 2014 | Thetford Norcold RV Cooler/Freezer
Kenmore 110.42822203 no cold water
Reverse the water hoses and see if you get just cold water. Post back the results.
Nov 06, 2012 | Kenmore Washing Machines
Could you catch a cold while sleeping on a matress on the tiles
Hi.
If you sleep with dust on the tiles, then yes.
It is recomended to sweep it first or vacuum clean it. A cold may be an alergy from any dust sticking on your matress or body freezing and warming at the same time..
Before you get a cold, you will feel a certain irritation while swallowing your saliva, that is a sign of a cold infection in your system.
- you need to make a hot tea, squeeze half a lemon, pour in the tea. break half paracetamol and drink it.
For sure the cold will vanish in no time.
Take care.
-avoid dust
-avoid swift changes of temperature environment.
Feb 07, 2011 | Health & Beauty
The fridge freezer does not get cold. The outside of it gets cold but not the inside. There is still a humming noise.
if the outside gets cold and inside is not getting cold this is sign of low refrigerant
Aug 27, 2010 | Freezers
Not getting cold water
As long as the water valve is turned on.....most likely you need a new water control valve. This valve turns on the cold water for cold, the hot water for hot or both hot and cold for warm water cycles. About $100 or less parts and labor to fix. Or if your inclined you can get the part yourself and replace it....not to much trouble. You can get a generic valve for $15 to $20
Oct 17, 2009 | Maytag LAT3600A Top Load Washer
Should freezer compressor get very hot when waiting to get cold
it is normal for the compressor to get warm as long as the freezer is cold
Apr 24, 2009 | Refrigerators
Cold water valve won't turn on to fill washer
either the valve has failed or the water line screen is blocked.
Aug 31, 2017 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Air condition
Does the evaporator thicker pipe coming to the compressor gets a bit cold or not at all?
Jul 14, 2008 | 1991 Buick Park Avenue
Kenmore 54662 / 54664 / 54669 Side by Side Refrigerator Logo
50 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
