Question about Brother ULT2001
Needle breaks when doing mongrams - Brother ULT2001
  • 161 Answers
Have you got it on low tension ? also, you usually need to use embroidery neddle and thread
Posted on Sep 12, 2010
Thread breaks on the 2340CV Brother. Doing two needle and the right needle is breaking at the needle. Change needle and retreaded several times
Probably depends what that needle is hitting that is causing it to break. Make sure the presser foot and the needle plate hole are large enough to accommodate the twin needle. Twin needles come in different widths so if yours is too wide, it would break. However, it could be possible that your machine is slightly out of alignment that does not show up until you try to use a twin needle. Also, make sure that your thread is not causing the needle to break--could be misthreading. Some machines have separate guides and tension disks for twin threads. Those that don't have that accommodation may have more difficulty using a twin needle.
Mar 07, 2017 | Sewing Machines
Buttonhole
The needle thread breaks
1. The needle thread is not threaded properly
2. The needle thread tension is too tight
3.the needle is bent or blunt
4. The needle is incorrectly inserted into the needle holder
5. The needle thread and the bobbin thread are not set under the presser foot when starting sewing
6. The threads were not drawn to the rear after sewing
7. The thread is either too heavy or too fine for the needle
Bobbin thread breaks
1. The bobbin thread is not threaded properly in the bobbin holder
2. Lint has collected in the bobbin holder
3. The bobbin is damaged and doesn't turn smoothly
Mar 13, 2015 | Sewing Machines
How do i stop the needle from breaking?
One of the most common causes of needle breaking is you are pulling your fabric to fast through. Let the feed dog do the work. When fabric is pulled it bends the needle backwards and then the needle hits the plate...breaks.
Feb 24, 2015 | Sewing Machines
My machine keeps breaking the thread
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Mar 02, 2013 | Sewing Machines
How do i fix my machine, it's breaking the top thread all the time
Nov 28, 2012 | Sewing Machines
Thread keeps breaking
Aug 17, 2012 | Singer Confidence 7469 Mechanical Sewing...
Brother se 400 breaking needles
The needle breaks
1. The needle is incorrectly inserted
2. The needle clamp screw is loose
3. The is bent or blunt
4. The needle is too fine for the fabric being used
Feb 06, 2012 | Brother Sewing Machines
Needle breaks hits needle plate
Check to see if plate is damaged or needle is bent. Could be wrong needle style for the type of work you are doing.
Jan 27, 2012 | Singer Sewing Machines
The needle keeps breaking. The needle seems to be hitting something or getting caught when it goes down and then it breaks off. I can't even get the needle to pick up the bobbin thread because it...
Certain stitches you do, require different base plates...by the base plate, I mean the metal piece that the needle passes through when it goes down through your cloth and through the hole provided...This sounds like why it's breaking, I think your needle is hitting the plate under it. It may not be all that obvious, but it wouldn't take much to snap the needle. You may want to check your setting and make sure it's setup to do a regular stitch. If that's not it, then you need to make sure that the needle is in straight, though I believe putting on in crooked is hard to do.
I hope this helps.
May 10, 2011 | Singer 3116 Simple
Letters
THe 19233 has only one size mongramming built into the machine. It has a 5mm' length and 7mm'' width therefore the complete needle range of this machine is just under 8mm and can not be adjusted
Jul 22, 2008 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
27 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
