I have a Coby TV3217. It has been working fine. Today I put an HDMI cable on, and the aspect ration went to s square box. How do I change the aspect ratio to widescreen?
  • 2 more comments
  • marvin657 Sep 11, 2010
    I have already gone to the MENU and there is no option there for aspect ration - only Picture Mode (Standard, Dynamic, Soft, Personal) color, contrast, etc. Nothing for the Aspect Ratio.
    Nope. Nothing there. Across the top of the MENU screen is Picture, Audio, Time, Setup, Lock, Channel. Under Picture are the choices stated previously. I have also check all of the headings listed above and find nothing relating to Aspect Ratio or screen size.
    All - Never mind. I have found the solution. It is in a category called "Zoom" under the Set-up Menu selection. However, now the picture on the screen exceeds the size of the screen. Looks like I need to shrink the picture by about 2" on all sides.
    Any idea how I might reduce the pic size so it is all on the screen. I have looked in all of the menu options and can find nothing. Any ideas would be appreciated.
  • 10,515 Answers
On few models, it is mentioned as ' Format'. Is there any format button there?
Thanks!!
Posted on Sep 11, 2010
  • taran_2005
    taran_2005 Sep 11, 2010
    Thanks for your response!!
    Thanks for sharing this information. I am happy that you got it fixed.
    Thanks and Regards
    taran_2005
  • 712 Answers
You have the option for the same in MENU.
Coby TFTV3227 32 in. LCD TV update firmware
May be the cord not the port and an update on firmware doesnt fix a hardware issue.
Oct 18, 2014 | Coby TF-TV3217 32 in. LCD TV
.....out of the box , no picture, no
have you checked the mains cable. sometime they forget to put a fuse in them.failing that the delivery of the tv has un pluged somthing in side or damaged a board.
Sep 18, 2013 | Coby TF-TV3217 32 in. LCD TV
Problem with Coby TF-TV3217 32 in. LCD TV
sounds like there is a fault with the tv or there is a bad cable.but you have tried av cables to. I would use another tv for time being. capacitors in the tv may be week and need changing. if its been used alot by i mean on and off a lot then it will wear out quicker than normal use. and the startup wear components out a lot quicker than normal home use.
May 20, 2013 | Coby TF-TV3217 32 in. LCD TV
I have a Coby TF-TV3217 32-Inch 720p LCD TV and the picture is too big for the screen miss allthe words on cnn and no one has heads. I have tried all ratios and all buttons on remote. How do I get...
Hi you need to adjust your ASPECT RATIO or SCREEN SIZE below is a manual to assist you how to do this look under screen settings.
http://www.retrevo.com/support/Coby-TF-TV3217-TVs-manual/id/23498ag721/t/2/
Jun 03, 2011 | Coby TF-TV3217 32 in. LCD TV
LG 47'' LCD HDTV 120Hz - Incorrect Picture Width
I just had this problem and got it solved. The issue is that your cable box is likely set to the wrong aspect ratio, so your tv will not be able to display the picture properly without this setting changed. On my cable box(Pace), you need to turn the power off to the cable box using the remote. Then hit the menu button on the remote and a new menu will appear on the screen. Change the aspect ratio to 16:9 and you should be all set. Hope this works for you too.
Feb 22, 2010 | LG 47LC7DF 47 in. LCD HDTV
HAVE YOU WENT INTO THE T.V.S MENU AND CHANGED THE ASPECT RATION FROM EXAMP ZOOM,16/4 ,NORMAL ,WIDE ZOOM OR ON THE REMOTE IT SHOULD HAVE A BUTTON THAT YOU CAN DO THAT WITH. SOUNDS LIKE YOU HAVE YOUR PICTURE ON ZOOM
Mar 08, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Onkyo TX-SR606 aspect ratio issue
you may want to try changing the aspect ratio on the HD box and the DVD as opposed to the receiver. This should do the thing
Mar 04, 2009 | Onkyo TX-SR606 Receiver
RCA D56W20 picture problems
More information is required to properly troubleshoot this problem. How is your television connected when you are watching HD? Do you have HDMI for this, do you have a satellite or digital cable box? For analogue are you using regular coax antenna (cable TV), or are you going through a cable or satellite box?
This could be related to the aspect ration setting. perhaps you ahve changed your aspect ratio from 16:9 to 4:3 or some other setting. If you are connected via HDMI, then the digital signal may be "normalizing" your picture during HD, but reverting back to the other setting.
Check you video settings very carefully. HD televisions are very difficult to tweak properly.
Sep 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Aspect Ratio Memory?
Problem could be the fact that you are connecting with composite cables. You should never connect an HD receiver with an analog cable like composite. It does not give a HD picture. You want to hook this up with HDMI. This might also help your problem because of the fact the native aspect ration of composite is 4:3.
May 09, 2008 | Panasonic TH-50PX75U Plasma HDTV
Aspect Ratio not responding/always in "Full" mode
Normally, when I see this problem in the customer's home, I find the main culprit to be the cable box. The remote for the cable box may have a button on it to change the format or picture size. You may have to go into the menu of the cable box to change the format setting. Hope this helps.
Apr 22, 2007 | Panasonic TH-42PWD8UK 42 in. EDTV-Ready...
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
