Question about Hannspree (K206-10U1-005) Television
Hanspree wont turn on tryed to turn on the tv but the tv has no red light ive checked the plug,wire and the fuses also had someone check the transformer board inside the tv which i told was also fine could the screen be the problem
  • lydon23 Sep 11, 2010
    my tv is a jt0132000g do all hanspree tv have the relay boards because i cant see it only the main av input board
  • Hannspree Master
  • 17,130 Answers
If the set does not turn on there are many related areas. so if you have checked the main power supply and found all the voltages going to the main board intact, then the set is not trigggered. If so the microcontroller IC is faulty. Check for the +5 voltage to the IC,, check the regulator.
If this section works the possible fault can be the drive/display.
Posted on Sep 12, 2010
  • 712 Answers
The screen may not be the problem in most of these cases. Since you have checked everything else, also try checking the relay switches.
Posted on Sep 11, 2010
Ive got fuel at the injector rod on my 1994 v8 jeep grand cherokee larado but the car wont start .. this all comes after runnin out of gas. its almost wasnts to but doesnt stay on at times and now won
If you ran out of gas there is a very good chance that the fuel pump relay has blown a fuse or requires a reset. Fuses and relays are in the main fuse box behind battery. When you turn your ignition on to the one setting before the starter engages you should be able to hear the fuel pump running. If it does not then check those fuses. If it does run then there is a good chance that the crank shaft positioning sensor needs replacement.
Oct 12, 2014 | 1994 Jeep Grand Cherokee
Car died while stooped at light
if it won't run on starting fluid then you have a no spark issue. i'd check spark out of the coil to the distributor. you could have a bad ignition control module or coil
Apr 18, 2014 | 1986 Toyota Cressida
No red led on front panel & wont power on at all
Check the wall outlet to see if you have power going to the TV. Next, the case will need to be opened; look inside for a fuse near the power wire. Beyond that you will need someone with TV experience to help you.
Jan 12, 2013 | Coby LEDTV2226 22 in. TV
My red power protect light is on and i dont know what to do ive unhooked it and checked the fuses but nothing
Power it on with only the 12Volts from battery, the ground, and the remote from your stereo. If it still turns red, then your amp is shorted. Check all your speaker inputs to make sure you don't have a wire shorting out the speaker inputs. Now if it turns on green when you test it like this, then install one speaker input at a time to check and see if you have a grounded/shorted wire. it will turn red as soon as it's plugged in. hope this helps.
Apr 13, 2010 | Pyramid PB1615X Car Amp
19 inch lg flat screen tv wont turn on
Power Supply board is dead.Tries Websites Shopjimmy.com,Ebay.com.Buy a refurbish power supply board for the replacement.
Mar 24, 2010 | LG 19LG30 19 in. LCD HDTV
LG flat screen wont turn on. Ive tried unplugging from wall
The flashing light indicates the TV is in protection mode. Most likely logic board. Not sure what your model is but its usually the board that has your digital inputs in it ex HdmI etc. Post your model and you should get some one to post more info Ex ( LG XXX has a common problem with tuner board)
Oct 16, 2009 | LG 42LC2D 42 in. LCD HDTV
Pioneer DEH-P5800MP CD Player not powering on.
did you try the fuse behind the wireharness. if so check the yellow wire and the red one for power. also check if you have ground on it. if you want to make things simpler try to connect the black wire to the battery neg. and the yellow and red together on the positive of the battery and see if it turns on.
Sep 01, 2009 | Pioneer DEH-P5800MP CD Player
Install pioneer DEH-P6400 into 98 dodge dakota, just wont work :-(
Have you measured the 12v ignition and permanent supply?
Also check the earth.
You will need a tester for this.
Check the fuses
John w
Feb 13, 2008 | Pioneer DEH-P6400 CD Player
Hannspree (K206-10U1-005) Television Logo
115 people viewed this question
Top Hannspree Televison & Video Experts
Are you a Hannspree Televison and Video Expert? Answer questions, earn points and help others
