Recurring issues with honda engine no start. Engine was thought to be out of gas however engine was actually shut down by oil alert. Check/change oil to reset, or unplug wire from oil alert and check engine. Vacuum in fuel system due to faulty fuel cap. Loosen cap to allow air in tank. Water in fuel. Water will condense out of the fuel in fuel container and will be introduced into tank. Water is heavier than fuel and will enter carb bowl. Check engine fuel tank with flashlight for signs of water, remove fuel bowl (shut off fuel) and clean. Spark plug is rarely issue, however could be wet from too much choke. Good luck
