What causes a checkered screen on a Toshiba P35-S609 or S611. Thanks, Jim Jackson
    President:
  • 2,047 Answers
Toshiba units are usually very durable and more like the best unit one can get. WHn the unit gets a chechered screen it is usually as a result of one of two things.
The first being that the screen has been mishandled and has therefore been hit by something relatively hard.
The second is usually the chord which connects the main unit to the monitor. In the both cases the affected part has to be replaced. In replacing replace the chord first as it is more likely to be the cause and is considerably cheaper. If after this has been replaced the problem persists then you change the screen.
Hope this solution has been helpful?
Posted on Sep 11, 2010
Display shows only half screen. Other half is ok. The bad side is just vertical bars top-to-bottom. Thanks, Jim
This indicates a bad LCD screen, Hook a external monitor to the video output on the back of the laptop, If okay! the display on the computer is bad and will need to be replaced, "costly" Now! if both screens show the same problem, it is the Video Graphics Card that is apart of the motherboard that is the issue, It will need a computer technician to address this.
Jan 16, 2011 | Toshiba Satellite P35-S609 Notebook
TOSHIBA SATELLITE P35-S611. Everything seems to be ok but it will display only on external screen. I have tried three different glossy screens that I know to be good with no success. I have tried Fn...
Welcome to Fixya
Sounds like you are having a bad LCD there. Try to discharge electrostatic energy of the motherboard. Take out the battery and unplug the power adapter from the computer. Press and hold the power button for 30 secs. Put everything back in and turn on the computer.
Please let me know what happen after doing this.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Nov 29, 2010 | Computers & Internet
Toshiba satellite p35-s609 screen darken.
It is almost certainly the LCD inverter which is the cause of your issue. It ism ore common for the inverter to develop a fault than a backlight bulb on the LCD (I used to work in a Toshiba repair centre).
Replacing the inverter should be simple, just make sure the unit is powered off with the battery removed so you don't get an electric shock.
Hope this helps,
www.PuterCare.com
Jul 13, 2010 | Toshiba Satellite P35-S609 Notebook
Toshiba Satellite P35-S609 xp System - hello is there a service manual for this product?
Go to Toshibas website and you can get it off of their website.... Or google "Get Manual for Toshiba P35-S609 Laptop"
Good luck Hope that helps
May 21, 2010 | Toshiba Satellite P35-S609 Notebook
Toshiba satellite p35-2611 2 inch(1
the worse thing it could be is the lcd going out in a very bad way. Yes likely to get wrose over time, No not the video card because it happends on every screen, boot,preboot,and windows so guess what? If you have the lcd replaced you will be looking at a good laptop once again. Price aroung $75-100 bucks where? Ebay of all sources. Thanks I hope this was Very Helpful to you if so lay ing your ratings.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Dec 13, 2009 | Toshiba Satellite P35-S611 Notebook
Toshiba Satellite P35-S611, power up failure.
Open the processor area located under your laptop. You can detached and re attached the processor, some sort of lose contact on pins. If same problem occur, your processor may burnt out. pm me caligayanstep@yahoo.com i will assist you remotely.
Oct 21, 2009 | Toshiba Satellite P35-S611 Notebook
Satellite (A75S206) runs well from outlet but never from battery. Was told that mobo can't accept dc. Need new mobo. True?
hello loyd516,
Have you tried a new battery? They are much much cheaper, and a whole lot easier to replace than a motherboard.
Here are replacement batteries that I found searching with Google.
http://www.google.com/products?q=Satellite+A75-S206+battery&hl=en
According to Toshiba, there has been a battery recall for your specific model.
If that is the case I would definitely contact Toshiba support about it. Maybe you will get a free battery out of the deal. Who knows.
Here is the link and the list(your model is highlighted)
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletin.jsp?soid=1501060
Sony Battery Pack Recall Programs Document ID: 98082080 Posted Date: 10/10/06 Last Updated: 10/30/08 Operating System: N/A Category: Battery Distribution: Public
Applicable Models:
Satellite A70-S256, A70-S2561, A70-S2362, A70-S2491, A70-S2591, A70-S2482TD, A70-S2492ST, A70-S259, A70-S249, A75-S206, A75-S2091, A75-S2292, A75-S2291, A75-S229, A75-S209, A75-S2061, A75-S226, A75-S2261, A75-S276, A75-S1255, A75-S1254, A75-S1252, A75-S1253, A75-S1251, A75-S125, A75-S2131, A75-S213, A75-S2112, A75-S2293, A75-S2311, A75-S231, A75-S2111, A75-S211, A75-S2761, A75-S2762, M30X-S1592ST, M30X-S1593ST, M30X-S191TD, M30X-S181ST, M30X-S171ST, M30X-S221ST, M30X-S221TD, M35X-S149, M35X-S1491, M35X-S109, M35X-S309, M35X-S3091, M35X-S329, M35X-S1631, M35X-S163, M35X-S1143, M35X-S1142, M35X-S114, M35X-S3111, M35X-S311, M35X-S1611, M35X-S161, M35X-S111, M35X-S1492, M35X-S3291, M35X-S349, M35X-S3491, M35X-S3112, M35X-S1141, M50-S418TD, M50-S4182TD, M50-S5182TD, M50-S5181TD, M55-S135, M55-S325, M55-S3262, M55-S2253, M55-S3251, M55-S1351, M55-S1352, M55-S3511, M55-S351, M55-S3294, M55-S3293, M55-S3292, M55-S3291, M55-S329, M55 Series, M55-S2252, M55-S3512, M55-S3315, M55-S3314, M55-S321, M55-S3313, M55-S3312, M55-S3311, M55-S331, P30-S6362ST, P30-S6363ST, P35-S609, P35-S6091, P35-S6111, P35-S6311, P35-S631, P35-S6112, P35-S6053, P35-S6052, P35-S6051, P35-S605, P35-S611, P35-S6292, P35-S629, P35-S6291
Tecra A3, A3-S731, A3-S611, A3-S711, A5-S416, A5-S237, A5-S516, A5-S136, A5-S3291, A5-S3293, A5-S3292, A5-S329, A5-S118, A5, A5-S6215TD, A5-S116, S2, S2-S511TD
Jul 11, 2009 | Toshiba Computers & Internet
Lines on screen
usually when you have lines on your screen then you have to buy a new one
Apr 22, 2009 | Toshiba Satellite P35-S611 Notebook
Missing P35-S611 Restore CDROM
Sorry but that would be illegal :(
Contact microsoft for a replacement.
Jan 05, 2008 | Toshiba Satellite P35-S611 Notebook
Computers & Internet Logo
David Payne
David Payne
