Question about Kenmore 74082 / 74084 / 74086 Gas Dryer
We have a Kenmore Elite 110.74082200. It stopped heating yesterday, but everything is running. We cleaned the lint and checked air flow and it seems fine. Any help would be great. Thanks
    Habit-Forming:
  • 84 Answers
Sounds like a glow coil
Posted on Sep 12, 2010
Sears kenmore elite oasis dryer 110 67032600 check lint screen flashes doesn t heat
Check the vent on the back. This is indicating a air flow issue. If the vent is clear ohm the heater out check it for continuity.
You can watch a video that explains how to complete this repair on your sears Kenmore Elite clothes dryer at the link below.
Sear Kenmore Dryer Video
Mar 11, 2011 | Kenmore Elite Oasis ST 6807 Dryer
My Kenmore Elite dryer heats up but the clothes are not getting dry. We cleaned out the lint and it's still not working. After drying for a while clothes are still moist and the dryer door is wet.
if the dryer is hot then you will need to go tothe out side of the house and check the air flow if it is weak then you have and air flow restriction some wher ein the ducting and may need to be cleaned out. also make sure the dcting behind the dryer is not kinked or pinched causing a restriction.
Jan 30, 2011 | Kenmore 62062 Electric Dryer
My Kenmore HE5 dryer will not run without blowing an internal fuse. The repairman replaced the fuse, and it blew again. The dryer heats up but will not turn it's heating element off until the fuse blows....
Has any one checked the exhaust vent,other than a bad thermostat the number one cause for the thermal fuse to open is a clogged or restricted exhaust vent flow, the entire vent system needs to be checked ( not just the hose from the unit to the wall) for proper air flow. Turn the unit on TIMED ,AIR DRY (NO HEAT) and go outside to the exhaust vent and check the air flow,if there is any question as to weather the air flow is sufishent get someone out to clean the exhaust vent ,it always a good idea to clean out every few years regardless to help prevent build up of lint witch could cause a fire......Hope this Helps Good Luck
Dec 14, 2010 | Kenmore HE5 Electric Dryer
Our dryer stopped heating so we changed element and cutoff kit, worked for 2 loads and quit, again changed cutoff kit and worked for 15 minutes and stopped heating again, what are we not doing right?
The cutoff is there to trip if too much heat builds up around the heating element. The most common reason for this is plugged venting. But it has to do with poor air flow for sure.
- Check to make sure your lint screen is clean and nothing is fallen down the lint filter chute
- Briefly run the dryer without the vent connected and feel the air coming out the back of the dryer, it should feel like good air flow, now connect it again and feel the air where it comes out of your home, it should feel about the same strength.
- To clean the vent, you can use a long brush, a vacuum or even a leaf blower to try and clear the lint. (blow from inside out or you may make a mess inside)
Apr 23, 2010 | Kenmore 62802 Electric Dryer
Dryer won't Heat up - Kenmore Elite HE4 Gas Dryer
hi..A poor connection between the wire terminals and the
heater relay causes high current draw and damages the
terminals on the heater relay on the main control board.
check it out..
thank u..
kindly rate my response..
Jun 09, 2009 | Kenmore Elite HE4 Electric Dryer
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
I have a Kenmore Elite model # 11063032101. It
If exhaust is blocked or restricted from back of dryer to outside of home it will cause the dryer to over heat the high limit switch. Repeated overheating will weaken the over load switch and it will need to be replaced if normal operation can not resume without restriction. Sea Breeze
Mar 26, 2009 | Kenmore Elite HE4 Electric Dryer
Check lint screen come on
Check the tubing the lint goes through (exhaust). This may be stopped up or clogged. There is a build up here of heat or something that is preventing proper air flow.
Dec 27, 2008 | Kenmore 659 Electric Dryer
No Heat - Kenmore Series 90 electric dryer
check cord conections and timer contacts (big wires)
Dec 24, 2008 | Kenmore Dryers
Kenmore 74082 / 74084 / 74086 Gas Dryer Logo
120 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
