Question about Belkin (F6D3230-4) Router (F6D32304)
Well I was having issues with my connection at college, so I got my Dad to send me his spare Belkin N router. It works and I can get to all the places I couldn't before, but the problem is that the speed it is going at is unbearably slow
    Sergeant:
  • 358 Answers
Open your router setup page and disable WPS and Firewall.
Also check the channel and SSID
Good Luck
Posted on Oct 31, 2010
Rj 45 wall connection in my room for internet. i want to go wireless mac,ipad xbox etc .can i use belkin n150
You can assuming all your devices support wireless. (Black XBox does). You may only get B or G wireless unless your devices support the N mode wireless. I will warn you that wireless on XBox can cause issues of lag while playing heavy network usage games on Xbox Live such as FPS's like Call of Duty. With the N150 you should also have wired ports in the back which would still let you connect wired devices.
What is providing internet to the RJ-45 Jack in your wall. If it is a college they may have port security turned on in their network which will not allow other Hubs/Routers to be plugged into the network.
Sep 12, 2011 | Belkin Connect N150 Wireless N Router
We have recently installed a Belkin Surf Modem Router. Since it's installation, we are sometimes having issues sending & receiving email. Internet and wireless connection are fine. We are able to...
HI,
I got your issue, you must make sure the firmware is upto date in your router since in the surf wireless router we have the issue only because of firmware.
Click here to download the firmware.
Update it in the router using a wired computer, if you do it in a wireless comp, connection will be disconnected.
I'm sure this will work.
Good Luck!
Thanks in Advance!
Regards,
Prema.
Dec 27, 2010 | Belkin Wireless Surf Router (F7D2301)
Wired connection randomly drops
Since the wireless works fine on your router, then it is possible that there is a problem either on your ethernet cable or on the port of the belkin router.
Try a different ethernet cable. (Ethernet cable is the one that is connected from your computer to the router.) If you don't have a spare cable, you can directly connect the computer to the modem, just to isolate the issue and determine if it is the cable or the computer itself.
If you have determined that the cable is working fine, then try a different port on the router.
I hope this helps!
Jul 24, 2010 | Belkin F5D7234-4 Router
Unlock router
Hi ,
please follow the steps to fis your issue
Step 1 :Connect Router - Computer ( Wired )
Step 2 :Open RSP by typing 192.168.2.1 on the address bar of the internet explorer
Step 3 :On the left , Under wireless Click wifi protected setup
Step 4 :Leave the password blank and click SUBMIT
Step 5 : Disable it and click apply changes
Step 6 : On the left under wireless click security
Step 7 : Disable it and click apply
Step 8 :on the left under wireless click channel and ssid
Step 9:Change the ssid into a different name And click apply
Step 10 : Connect to this new name
please rate the service if issue resolve
Thanks for using Fixya
Apr 02, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Just got Belkin router from my dad as he has a new one. Tried to connect to my Virgin Internet connection through it so my kids can get internet on laptops and doesn't work. Do I need any help from my...
check the lights on the router and the cables connected. ur dad's ISP settings might be stored in the router so its better u reset ur router by pressing the reset hole in the router using a paper clip for 1 minute, unplug all the cables, ur modem too. then plug back one by one with modem 1st.
Jan 17, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Hello, I currently use a Belkin F5D8631 as my Modem Router. I have a spare Belkin F5D7633. Can I use the 7633 as a repeater/bridge to extend my wireless range? If so, how?! Thank you
It will not extend your wireless range. If you connect your spare Belkin F5D7633 to your Belkin F5D8631, one of them would have to be set to "bridge mode" or a pass through modem so that there will be no conflicts as to which modem will receive the ip address from the network. If you set your modem/router to bridge mode, it would disable its wireless function because it will only be a pass-through device.
If you want some tips on how to improve your wireless range, check out this site http://www.microsoft.com/athome/moredone/wirelesstips.mspx. Hope this helps.
Apr 22, 2009 | Belkin F5D8631-4 Router (F5D8631au4A)
Belkin Wireless Router F5D8233-4 shotty connection missing wireless
The problem may be that your router needs a firmware update. I work with routers everyday and have found that even out of the box they do not have the lastest firmware. Ditto for linksys.
http://www.belkin.com/support/
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Sep 29, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin router just died? What do I do?
There are 2 possible cause of this problem;
First the router's power adapter is already busted if you happen to have a spare or another power adapter with the same output as the original one try it first before deciding to purchase a new one.
Second, the routers processor or the entire board insed the router is already shorted, if it is still under warranty(this model has a lifetime warranty according to the specifications) send it back to the store where you purchased it or to Belkin(some manufacturers and stores also provide replacement for faulty power adapters).
Aug 05, 2008 | Belkin (F5D7230-4) Router (587009)
I have a belkin n wireless router keeps freezing
First step of solution would be performing Reset. Press and hold the reset button about 30 seconds and release. Check again. If you need customized settings just type 192.168.2.1 in your browser and get into settings.
If issue persist please post for further troubleshooting.
Good Luck
Jan 24, 2008 | Belkin (F5D7231-4) Wireless Router
Belkin (F6D3230-4) Router (F6D32304) Logo
43 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
