Question about Mitsubishi WD62627 62" HDTV
I cannot see football stats on bottom of screen. mitsubishi wd-62627 setting is hdmi 1080i standard. help!
  • 201 Answers
Either your TV or your cable/sat box(if any) is on zoom(enlarging pix). Look for buttons on both remotes that might say picture size or aspect something like that...Pressing these buttons usually cycle thru 3 or 4 size options. When in zoom center of screen is the focus and outer edges of pic are cut off.
Posted on Sep 11, 2010
I have a mitubishi ws-55313 with a monitor link DVI connection and I have tried to convert that to hdmi for a cable DVR but it doesn't work any ideas?
The monitor link is not a standard DVI connection, it was used to connect a Mitsubishi HD set top box. You can connect your cable DVR using component video cables and get HD that way, up to 1080i but not 1080p
Apr 15, 2014 | Mitsubishi WD-52525 52" Rear Projection...
My Mitsubishi WD-62627 has no pic/sound w/ PS3
you just have to keep switching the back button off and when u turn it back on hold the front power button till you get 2 beeps
Apr 18, 2010 | Sony Playstation 3 (PS3) Console
Mitsubishi WD-62627 Projection DLP TV help with PS3
To localize issue better try plugging your xbox into input for your ps3 and see what happens. You may have a bad input. Happens.
Aug 28, 2017 | Mitsubishi WD-52725 52". Rear Projection...
How do i set video from 480i to 1080i??
when your using the comp in or hdmi the tv should swithch automaticlly but you must have an HD signal
Nov 30, 2009 | Mitsubishi WS-65615 65" TV
The ticker tape during football or nascar is not visible
If your watching a standard resolution(4:3) picture in wide screen format (16:9). than the picture will be stretched and the tops and bottoms cropped. look in your video or set up menu to change the resolution settings to standard 4:3
Sep 27, 2009 | Mitsubishi WD-65731 65" HDTV
4yr old Mitsubishi DL 52525, HDMI input vide problem
Are you sure its the TV and not the source? Are you sure its only the HDMI port on the TV? The only reason why you must HDMI is to get 1080p and your TV doesn't support 1080p. Its supports up to 1080i. Your TV has a native resolution of 720p which means it can accept a 720p image and not need to scale it, so the picture will look the best at 720p but will support 1080i. I would use component cables to connect your sources and set them to output 720p.
Mar 20, 2009 | Mitsubishi WD-52525 52" Rear Projection...
PS3 not recognized by Mitsubishi WD=52525 tv through HDMI
FYI,
PS3 has output settings and would need to be adjusted if you are coming from the RCA input. Check out www.sony.com/ps3 trouble shooting under display problems. I believe the solution is to turn on the PS3 unit and keep holding the I/O button for more than 5 seconds. I had the same issue going the other way.
Good Luck.
Sep 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Set-up big screen tv
just hook up by color coding. or through HDMI which will be the easiest for you. (if you things support HDMI)
Aug 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
My tv shows its's geting 1080i only
1080p signal... THE MITSU. WD-65731 has a resolution of 1080p its just the res your PS3 is pumping into your screen is loaded with a little bit more pixels than you 1080p res MITSU. I suggest getting a MITSU WD-57731 since it has a 1080P/24 input. and has great clarity and HD ample for the BD of your PS3. however the differences in picture rate and quality is very small. goodluck.
Sep 22, 2007 | Sony Playstation 3 (PS3) Console
Mitsubishi WD62627 62" HDTV Logo
183 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
