Question about Canon FS100 Flash Media Camcorder
Sdhc card canon initialize failed process terminated with error
4 Suggested Answers
  • 191 Answers
SOURCE: 16 GB SDHC card won't initialize
check the limitations of the camera specs. might be a firmware update or software fix.
then if that fails meow at it.
Posted on Aug 25, 2009
bkn7000
SOURCE: Canon FS200 won't fully initialize 16 GB SDHC card
I have the same problem with my Canon Vixia HF R20 and I'm using a Lexar Pro 64Gb 133x SDXC card. When I try to initialize the card, its fails and says Process Terminated. The write-protect is off. The older class 4 SDHC card I've tried seems to work ok, which is a SanDisk 4Gb.
Posted on Oct 15, 2011
bkn7000
SOURCE: Canon Legria HF200 SDHC Initialization problem
This totally sucks. I have a similar issue with my Canon Vixia HF R20 and I'm using a Lexar Pro 64Gb 133x SDXC card. When trying to initialize the card, its fails and says "Process terminated with error." It also says "check the memory card" when I first put it in. Write-protect is off. My other SanDisk class 4 SDHC card seems to work ok.
I could have sworn it worked before and I was able to transfer videos to my Mac on 10.6, but I can't remember for sure if I was using the SDXC card or just the built-in memory. Very frustrating.
I have a Canon FS200 and a brand new SD 64 GB card. When I try to initialize the card, the camera says, Failed: Process Terminated with Error, but it doesn't tell me what the error is. Can you???
I cannot tell you what the error is, but perhaps I can give you some tips on how to solve the problem. First, try to read the SD card on your computer. Is it formatted? if not, format to FAT 32. Are there any file structures? If so, erase and format the SD card to FAT 32.
If these activities do not work, then try with another SD or SDHC card (type 10 if possible) and see if the error is replicated.
From there, recommend contacting Canon customer support for assistance.
Apr 20, 2015 | Canon FS200 Flash Media Camcorder
Check memory card - initialize - complete initialization -process terminated with error! Can You help me?
Just delete files off the sd card and you are good to go! Just solved this problem myself!
Oct 12, 2012 | Canon Legria HF200 Flash Media Camcorder
Card error as I put it inside canon camera sandisk sdhc with adapter
The ZR200 works with SD cards, not with SDHC cards. While the SDHC card fits, it is electronically incompatible.
Sep 20, 2011 | Canon ZR200 Mini DV Digital Camcorder
I bought a 16GB sandisk sdhc card for my Cnaon Elura 100. It says card error and will not initialize. What next?
Your camera is designed to use SD cards, not SDHC cards which are a later evolution of the SD card with different technical standards.
Your fix is to either stick with mini DV tapes or with SD cards with a maximum 2GB capacity.
Jun 30, 2010 | Canon Elura 100 Mini DV Digital Camcorder
Apr 12, 2010 | Canon Legria HF200 Flash Media Camcorder
Whwthwr Canon IXUS 700 can accept Micro SDHC card
Sorry, but according to Canon's technical specs, your camera was designed only for use with standard SD card format. SDHC format will not work with it, and will likely give you a memory card error.
Sep 21, 2009 | Canon Cameras
Aug 25, 2009 | Canon FS100 Flash Media Camcorder
Jun 19, 2009 | Canon FS100 Flash Media Camcorder
Failure to initialize and use memory card SD/SDHC / canon fs100 camcorder
I had the same problem but fixed it by initializing the SDHC Card. It explains it in the manual. If you go to the menu and then down to the card it gives the option to initialize it. I did that for all my cards and now they work fine. Hope that helps...
May 28, 2009 | Canon FS100 Flash Media Camcorder
Canon FS100 Flash Media Camcorder Logo
1,356 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
