Question about Whirlpool LSR5232L Top Load Washer
I need replace the lid switch of my LSR5232LQ0 cloth washer, can you tell me how to open the console panel? and how do I replace the lid switch
    Problem Solver:
  • 3 Answers
Check out youtube and search for video
Posted on Sep 11, 2010
Instructions on how to replace lid switch on Whirlpool Washer, model # LSQ911OPW2
The following link explains how to replace the lid switch on a Whirlpool top loader:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
The part number (if you haven't purchased a replacement yet) is 3949247. If you have questions about this repair, or need additional assistance, please let me know. I hope this helps you.
Sep 11, 2009 | Washing Machines
Need to replace lid switch
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 27, 2009 | Kenmore Washing Machines
Kenmore, cloths washer, lid switch replac. Wiring harness access.
Feb 23, 2009 | Kenmore Washing Machines
Help with Kenmore washer
most often the lid swtch is out of alignment, less often the switch fails
with the lid open examine the underside of the lid for the plastic 'tooth' that is supposed to engage the switch, if broken or missing replace, test
with the lid open and the washer turned on, use a ballpoint pen to engage the switch plate in the hole at the right side of the lid
If the washer starts, adjust the switch position, test
If the washer does not start
remove the edge trims from the console
remove the screws from the lower corners of the console
slide consloe forward ~1/2 inch, flip up and over
ensure cable is connected to lid switch connector
try lid switch again with ball pen
if washer does not start the switch has failed,
remove metal retainer clips from rear of washer top, remember installed position, you have to put them back
lift washer case 1 inch slide forward, lay down, remove switch
replace
reassemble in reverse order, test
3-5 times a month, takes about 25 minutes, the switch costs $7.95+tax
Aug 02, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore Elite Washer Problem
This is a common symptom of a defective lid switch. If you try opening and closing the lid and do not hear a distinctive "clicking" sound, your lid switch may need to be replaced. Some lid switches are located on the right-hand side of the lid opening with a small slot. It is activated by a plastic piece called a “lid strike” on the lid itself. Make sure the lid strike is not broken off. This will keep the switch from not working. On some model washers the lid switch is located on the left-hand side, in the rear, mounted under the casing near the lid hinge. It is activated by a rod on the lid hinge. Sometimes the rod can be adjusted if it is not making good contact with the switch. In either case, if the switch is not activated, it will allow the washer to fill and maybe agitate, but will not start the rinse or drain cycles. If you diagnose it and wish to attempt the repair yourself, the switch costs about $35 and is fairly simple to replace if you follow the steps below:
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. I believe your washer has release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. Or, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place.
You do not have to remove it all the way from the frame. Just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. NOTE: You DO NOT have to drain the tub to repair the lid switch.
2. Insert the brass-colored clips into the slot on the washer rear panel first, then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle and close the console.
I hope you find this helpful. If you have any questions or need help locating the correct part, please let me know by posting comments.
Apr 07, 2008 | Kenmore 22422 Top Load Washer
My whirlpool washer (Ultimate care II) stopped in mid cycle, basket full of water and clothes. There is electricity to the plug, and the washer will add more water, but just not finish the cycle. I...
If the washer fills, but won't spin or drain, you may have a defective lid switch. This is a very common problem and a very common symptom.
Let me guess: The washer fills, agitates, but when it gets to the spin cycle it just stops. On some models the washer will fill and then shut off. Am I explaining your symptoms correctly?
If so, this what you need to do:
Open and close the washer lid and listen for a distinctive "clicking" noise. The contacts on the switch should close when the lid is shut, allowing the washer timer to run. This is a designed safety feature that prevents the washer from agitating or spinning with the lid open (don't need to lose any fingers). If you don't hear the switch, it may have come loose, or has broken.
Some lid switches are located on the right-hand side of the tub rim. There will be a slot where the lid strike pushes down on the lid switch. Make sure the lid strike (small plastic piece) is still present on the lid. This can prevent the washer from working as well and make it seem like a huge problem.
On some models the lid switch is located near the left-hand lid hinge under the washer casing. A small rod on the lid hinge activates the switch contacts.
If you determine the need to replace the switch, follow these steps:
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. And, still there are some of the older models that have screws holding the console in place from the back. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in on the side of the tub opening and a ground wire attached to the casing. Remove the connector plug, by pushing in on the release tabs on either side and pushing it down through the opening in the washer casing. The wire harness will be held in place by clips under the washer rim. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Good Luck.
Feb 27, 2008 | Washing Machines
Kenmore 80 series washer
The switch you're talking about is called a "lid switch". It can be by-passed, but it is there for a reason. The switch is used to prevent the tub from spinning or agitating with the lid open. This is a safety measure to prevent personal injury. You mentioned that the switch was "missing". It may have simply come loose and fallen inside the washer between the case and tub. More than likely, it is hanging by a ground wire and a plug. If you can retrieve the switch and screw it back in place on the rim of the wash tub opening, you may actually fix your problem. However, if the switch is broken, you need to replace it. Here's how:
PS To answer your initial question about by-passing the switch, when you remove the console and disconnect the lid switch, you can take the connector that is MOUNTED ON THE WASHER TOP and remove it by pressing the release tabs and pulling it from under the tub rim. This is the connector plug that runs to the lid switch. Cut the plug from the switch, leaving a couple of inches of wire. Short the two black wires together, insulate the ends and cut the green wire flush. You now have made a by-pass plug. Simply plug it in to the connector that is RUNNING FROM THE TIMER and (voila!), you have a working washer. Keep in mind that now your washer will NOT stop when you open the lid. Use caution if you're going to operate your machine in this manner.
Now...if you're going to go this far, you should replace the switch. A new switch runs about $35 or less. Its an easy repair if you follow the directions. Keep the plug handy in the event that you run into this problem again and need to drain and spin the water out.
Good luck to you and let me know if you need any further assistance.
Feb 22, 2008 | Washing Machines
Washing machine stops in rinse cycle.
Okay...I asked you a question in your other posting before I saw this one. This is a common symptom of a defective lid switch. If you try opening and closing the lid and do not hear a distinctive "clicking" sound, your lid switch may need to be replaced. Some lid switches are located on the right-hand side of the lid opening with a small slot. It is activated by a plunger on the lid itself. Make sure the plunger is not broken off. This will also keep the switch from not working. On some model washers the lid switch is located on the left-hand side, in the rear, mounted under the casing near the lid hinge. It is activated by a rod on the lid. Sometimes the rod can be adjusted if it is not making good contact with the switch. In either case, if the switch is not activated, it will allow the washer to fill and agitate, but will not start the rinse or drain cycles. If you wish to attempt the repair yourself, the switch costs about $35 and is fairly simple to replace if you follow the steps below:
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. I believe your washer has release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. Or, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
I hope you find this helpful. If you have any questions please let me know by posting comments.
Feb 11, 2008 | Washing Machines
Whirlpool LSR5232L Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
