Question about Pride Health & Beauty
Wheelchair moves when plugged into charger and does not move when not plugged into charger
  • 692 Answers
JIKM Your batteries aren't strong enough to take a charge and when you have it plugged in you are providing enough voltage to get it to move. You need to get 2 new batteries. If Medicare bought your chair then they will pay for most of the cost of the new batteries. Your local provider can install the batteries for yoy and bill Medicare. If you purchased the chair I would check with a local battery warehouse or Interstate battery store your cost would be less than paaying the provider for them Hope this helps
Posted on Sep 11, 2010
Jazzy stopped one day. Plugged in charger and it will still not move. Replaced batteries and it will move a couple feet then stop.
shouldnt even move with charger plugged in sounds like a controller problem or joystick have a tech fro dealer check the error log they can tell u what is wrong from that
Oct 11, 2013 | Pride Mobility Products Jazzy 1170 XL Plus
Lights scroll from lt to rt ant lights around joy stick flash fsta when joy stick is moved forward but the chair will not move
The lights indicate you are in charge mode or inhibit. Check to make sure the charger isn't plugged in. If it isn't then the inhibit function of the chair is bad and will have to be repaired Hope this helped
Apr 15, 2011 | Pride Mobility Products Quantum Jazzy 500...
The ammeter on my jet 3 does not move at all when chair is plugged in.
If your ammeter does not move when the chair is plugged in...
You may have a burnt fuse ,check your fuse link connected to your ammeter..
You may have a bad charger, volt test your on board charger..
Good luck I hope i was helpful
Jan 16, 2011 | Jet 3 Ultra Power Chair
Jazzy 1121 power chair won't charge when plug in to charge chair can move when you use joystick
you have either bad batteries or a bad charger or the charger might have come unplugged at the controller or power module. When you have the charger plugged in and you turn on the joystick the lights on the joystick should ripple to indicate the charger is plugged in. If you don't see this ripple then either the charger is bad or disconnected. Trace the charger cable from the rear of the chair (you have to remove the seat and shroud to do this) to the front module and make sure that the cable is plugged in. Hope this helps
Oct 22, 2010 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
When i plug in the charger the led light stays on green but on the joystick the lights are moving back and forth as if it is charging but wheelchair does not move
Joy When you plug in the charger the lights on the joystick will scroll because of something called charger inhibit which disables the joystick when charging It is a safety feature. Now when you disconnect the charger turn off the chair and then turn it back on you should then get all the battery lights indicating the charge level If fully charged all the lights will be lit. If after you unplug the charger and you still get the scrolling lights then you have a problem with the charger inhibit function in the joystick and it will have to be replaced. Hope this helps you
Sep 25, 2010 | Quickie Wheelchairs Quickie Aspire Power...
The wheelchair will only move when the charger is plugged in. Unplug and all lights are normal but no motor actuation. thank you fo4r your help
berry boy Not alot of information but when you say all lights are normal do you mean the battery level lights are all lit up and there are no flashes. Usually when this happens the battery level is too low to make the chair move. When you have the chair plugged up the charger gives enough power to make it move. If you have a digital voltmeter set it 200 vdc then plug the 2 test leads into the 2 outter charger port holes. You should be able to read the battery level and after a full charge should be reading 25-27 volts. Hope this helps
Sep 19, 2010 | Quickie Wheelchairs Quickie Aspire Power...
When turning power it makes a clicking sound but does not power up. battery charger has a red and green light on. When plugged in and turned on it flashes 8 times. I checked the power control connection,...
The chair will not move if the charger is plugged in. The flashes are normal with the charger plugged into the chair. The lights on the charger mean that the batteries have been fully charged. Red and yellow lights mean charging. After you unplug the charger from the chair (if off-baord charger, turn charger off or unplug from the wall) then unplug from joystick. after plug is removed from joystick press the on button and all the battery lights should be lit and when you move the joystick forward you will hear the electric bake release and the chair should move forward etc Hope this helps
Aug 10, 2010 | Pride Jazzy Select 6 Indoor Power...
I have a quantum 600 power chair. when I move the joystick in any direction the chair goes into drive like normal but doesn't want to move and moves very slowly even after i change the speed setting.
Sounds like you need new batteries. Assuming that the chair is programmed for a faster speed and has gone faster in the past the most likely culprit is old or discharged batteries. The charger or plug may be at fault also. Also check that the charger is plugged in and the indicator lights of the charger are on.
Aug 08, 2010 | Electric Health & Beauty
I have a Jazzy 1121,when I went to plug it in to recharge it, I noticed the lights weren't flashing like they suppose to and plus while it was plugged in I was still able to move the chair, when I...
The chair is not recognizing the charger. If it is an off board charger, check the pins in the conncector to be sure that one has not been pushed back. On board, check to see if the amp meter moves at all.
Oct 04, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Hooveround MPV won't move
Most likely either one or both of the batteries have a dead cell. Have your batteries load tested to check their condition.
Aug 02, 2009 | NRS Hoveround MPV 5 - Used Power...
Health & Beauty Logo
53 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
