Question about Garden
25CC BACK PACK BLOWER STOPS WHEN IT GETS TO OPERATING TEMPERATURE. I FIND THERE IS NO SPARK UNTIL IT COOLS DOWN AGAIN. SOUND LIKE THE IGNITION ASSEMBLY IS SHORTING OUT? 5 YEARS OLD THANKS
    Brigadier General:
  • 4,088 Answers
Ignition modules are known for heat induced failures--replace it using a thin business card for a gap gauge. Turn the flywheel magnets so that they are under the module, allow the pre-mounted module to contact the magnets through the gauge, then tighten the screws. There should be no timing adjustments. Hope this helps!
Posted on Sep 11, 2010
My 1999 taurus will run but when it gets to operating temp it cuts off, after it cools down it will start and run fine until it warms up again, and then it cuts off again. I can repeat the process as many...
A lot of the time when that happens it is crank sensor it starts to get hot and stuffs up how I check and it work sometimes is poor cold water all around the sensor area after it stops and if she starts up after you cooled it down you found the problem then just replace it
Dec 19, 2014 | 1999 Ford Taurus
1200 custom sportster stops running when it get warm
Sounds like it is possibly the cam sensor. It is located under the round cover on the lower right side of the engine. The cover is held on by 2 rivets. If this is indeed the problem, you will have to re-time the bike after replacing the sensor.
Jun 10, 2012 | 2002 Harley Davidson XL 1200 C Sportster...
My 1999 FXSTC has me puzzled. It will fire up and run until it gets up to normal operating temp then dies and will not start until it cools down.I replaced ignition module, coil, wires and plugs. This is...
regulator/rectifier? Vapor lock? Stator? Wiring.
After it stops, shake all the wires and plugs(one at t aitme) and try again. This will take time but it may be an elusive problem.
Mar 31, 2012 | 2000 Harley Davidson FXST Softail Standard
When driving engine stops and car doesn't start until it cools down
You may have a failing cam sensor. This part, if it fails, has the symptom that the vehicle won't start until the engine cools down from normal operating temperature.
Sep 08, 2010 | 2000 Kia Sephia
My Blower dies after about 15 min. Then it will
I think its the ignition module. To test the module put 2 spark testers inline with each other and see if it will jump both.
If you dont have 2 testers then use it till it dies and try to start immediately with a prime. If it wont start then module is suspect.
Most manufacturers have lifetime warranty on thier modules ( I am unsure about MTD) so double check before you just go out and buy one.
Jan 02, 2010 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
Stihl FS85R stops when hot and won't restart
scott have the shop replace the ignition coil and problem should be solved. jd
Oct 22, 2009 | Garden
Craftsman 25cc edger has trouble starting. once started it will run for 5 - 10 minutes and then shut shut off. Will not start again until it cools down. Changed the spark plug , but it has the same pr
Dump the fuel in the tank, get new gas and new oil and start over. Get a carbeurator cleaner additive for the gas as your carb. is dirty resulting in the sporatic operation.
A spray carb. cleaner that you squirt into the air intake by removing the air filter will also work for you. In fact, when you are getting the carb. cleaner get a new air cleaner and a new spark plug. get back and let me know how u make out.
May 20, 2009 | Garden
2000 caravan 3.0 stall after 20 min no spark restarts few hours later
This sounds like a bad (probably cracked) ignition coil.
First, the coil gets hot when operating, and this is normal.
If it is cracked, it gets hot to the point where its resistance gets so much higher that it cannot provide enough voltage for spark.
When it cools back down it starts working fine again.
Aug 19, 2008 | 2006 Dodge Grand Caravan
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
