I need schematic of a 10,000# 4 1/16" shaffer manuel gate valve
  • drillsup Sep 11, 2010
    the website offered says it is coming soon i need a picture of this gate valve today
  • 712 Answers
Have a look at this link:
http://intloilparts.com/IOP%20CAT%20JPGs/IOP%20CAT13.jpg
It's a 4-1/16" manual Cameron FL gate valve, may be the one you just wanted. Zoom in to get a better view.
Posted on Sep 11, 2010
    Genius:
  • 1,478 Answers
I will advice you check manualsonline.com to search for the manual of your device.
Take care.
\i just got a Canature water softener and ionizer installed, every time it cycles water gets into my water lines and spurts out for about 15 minutes, pipes shake
sounds like a mix of things
if you have pipes not locked tight
and 1ft = 1 clamp spaces
also check any 'gate' type valves are all fully open
use a presure 'keep' valve regulator to turn down the water presure
to 1.5 - 2 bar {60psi}
if you half close a gate valve
then the whole intake can vibrate and sing
even how much you try to wedge the pips
its the gate valves cause issue
in cold water then it uses presure joints and presure makes the seal
but gate valves will bring like the read in a woodwind instrument like a claronete
so your pipes will sing
check all the filters intake valves at the machine filters
and your gate valves on your water supply to the machines hozes
Mar 04, 2015 | Washing Machines
My pipes in bathroom burst 2 days ago so I shut off water, today fixed pipes they are fine now but when I turned the handle for the main the water didn't come back on at all! there isnt even a trickle...
Sounds like a dropped gate valve. meaning the part that blocks the water flow has broken from the valve stem and handle. You will need to turn off the supply to your main, usually a curb box outside to remove and replace the gate. I would suggest replacing the gate valve with an appropriate ball valve to avoid this happening in the future.
good luck!
Feb 24, 2015 | Plumbing
Subaru impreza turbo intercooler drives like normal 2l but has no boost?
I would start looking at your boost control valve and vacuum lines going to your turbos waste gate, as well as the recirc/bypass valve. Usually when cars don't boost they have either stuck open waste gates or recirc valves. Or something is blocking the boost control valve from releasing the waste gate. Also make sure that all your intake hose clamps are tight so they are not releasing boost prematurely.
Jul 26, 2011 | Subaru Impreza Cars & Trucks
There are two resistors 310-3 10R on the power supply of the Europower pmp 5000, i need to know if it is 330k or 330om.
The schematic for the power supply does NOT show resistors in the 310-3... Where are these in the circuit... IF THESE happen to be the gate drive resistors for the IGBT's they are 33 ohms. If you have hasd a failure in this area there are other parts that typically get destroyed, including one or both the speedup diodes at the same gates; Here is the complete PMP5000 schematic:
http://elektrotanya.com/behringer_europower-p0569_hca2400_sps1000_dpx_pmp-1280s_5000_sch.pdf/download.html
Scroll down to "get manual" and cliick to download. IGNORE other download links. If you need help restoring the PSU get back to me.
Jul 20, 2011 | Behringer Europower Pmp5000 Powered Mixer...
I have a 1997 Ford Ranger. I can not lower the Tail Gate
I had the same issue and took the panel off. the handle is connected to 2 bars that are connected to both sides of the tail gate. One of the bars had somehow bent and came loose. All I did was straighten that bar enough to get it back into the slot on the handle, screwed a nut onto it so it couldnt pull out again. And never had a problem since.
If you look in between where the gate meets the fender , u can see the lock and push in to release the gate. Sorry , No repair manuel , I just start takin things apart
Feb 17, 2010 | 1997 Ford Ranger SuperCab
Need help with my 99 gmc yukon! replaced map sensor, and idle air control module. getting gas to shaffer valve, getting spark to the spark plugs. yellow fire.
Im guessing the vehicle wont start? If so you shouldnt rule out fuel just because your getting fuel to the shrader valve, these vehicle require a certain amount of fuel pressure to run, im guessing around 60psi, so i would check fuel pressure, if ok keep in mind that these vehicles also had a problem with early failure on the fuel injectors, GM sells a new design injector set up for them.
Nov 24, 2009 | 1999 GMC Yukon
Need to find information on gate valves
Hi robert garet,
I'm Harvey the Master Plumber.
Your problem is: You are a college student and currently learning on how a cast iron gate valve works you need diagrams to print off for my portfolio and to learn how to take one apart and how to maintain a gate valve you would be greatful for any information thanks
For small valves, it's just a mater of unscrewing the bonnet (top part with handle), with larger valves, you remove the bolts around the bonnet. Always turn off the pressure in the line before maintenance. If there's a leak where the shaft comes out of the bonnet then you need to replace the packing material inside the bonnet. This is usually a good time to put some apropriate lubricant on the threads at the botom of the shaft. That's about it from a practical point. I don't happen to have any pictures but you can take them yourself at any plumbing supply or they might let you fotocopy the expanded pictures in their parts book. They're usually happy to oblige.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Oct 10, 2008 | Plumbing
Need Mac G4 laptop schematic manuel
Not sure if you want an actual circuitry schematic, or a internal parts guide.
A manual for field-replacing just about every component inside your Powerbook can be found here.
I expect that circuitry schematics are much harder to come by, and are actually likely to be protected by trade secrets.
Apr 03, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
