Question about Brother MFC 420CN All-In-One InkJet Printer
I changed all my cartridges. Now it is telling me "ink empty yellow", and cyan. They are brand new.
  • 47 Answers
Go into the software you instal for your printer, choose clean ink, this my help.Then try to prin test page.
txexixs
Posted on Sep 11, 2010
Brother MF 5440CN USB Printer won't print. Says "Ink Empty Cyn" and then "Ink Empty Yellow" Replace Ink There is ink in the cartridges.
While there may be ink in the cartidges, your printer is getting a signal from the cartidge that it's near empty. There is no real workaround for this; you just have to replace the cartridge(s). If you use a LOT of ink, you might consider installing a CIS (continuous ink system) now made for most printers. You will save a lot of money over time.
What you describe is typical.
Dec 06, 2010 | Brother MFC-5440 Printer
Keeps saying install c
When the printer says "install C" it is referring to the Cyan (blue) ink cartridge. If this is not a new cartridge, you might have to replace it. If this is a new cartridge, try following these steps.
1. Unplug the power cable.
2. Remove all 4 ink cartridges.
3. Close the ink cover
4. Plug the power back in.
5. Wait for the machine to warm up and tell you that the ink is empty.
6. Reinsert all 4 ink cartridges.
If you keep getting the same message you should try another cartridge. You can put the yellow cartridge in the blue spot to see if you get the same message. If you get the same message then the machine is broken. If you get a new message then the cyan cartridge needs to be changed.
Thanks,
Pat
Nov 09, 2010 | Brother DCP 130C All-In-One InkJet Printer
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
How do I change the toner?
The Fax-2480c does not use toner cartridges.
This is an inkjet and so uses ink cartridges.
There are 4 cartridges, black, yellow, cyan (blue) and magenta (red). If any of these cartridges are empty, you need replace them.
This machine takes LC-51 cartridges.
You're probably out of warranty so jsut get refills... it's cheaper
Mar 25, 2010 | Brother IntelliFax-2480C Fax
My printer says install magenta what does that mean
It means for you to install the magenta ink. Magenta is a color. You have 4 colors. Yellow, magenta, cyan, black
Oct 14, 2009 | Brother Multi-Function Center MFC-240C...
Print Head Problems??
The ink cartridges on your Canon Pixma MP500
print head not problem your yellow cartridge &black
problem
Oct 07, 2009 | Canon Pixma MP500 All-In-One InkJet...
Changed yellow ink to new cartridge. Printer won't recognize.
I contacted the Brother site, the support function there. Pursuant to what I found there, I unplugged the printer for ten seconds and replugged. The message display then told me that cyan was empty, and that magenta was near empty.
I installed a new cartridge in place of the empty cyan, and that fixed it.
Jun 04, 2009 | Brother MFC 420CN All-In-One InkJet...
Ink in hp photosmart 3310
the printer should have software installed enabling you to opt, for a printer-ink cartridge change.
If the cartridge has a chip fitted, it may be discharged.
The chip is supposed to be charged up, for the printer to recognise the newly installed cartridge.
view your settings in control panel/printer/properties to see what options you have available.
Mike @ Compurepair.
Jul 23, 2008 | HP Photosmart 3310 Printer
Ink problems....
Take all carts out of the machine. Have a look into the cart holder. Is there ink swapping beneath the white plastic? (You might shake the machine ;-)
If yes, the cart holder leaks and needs replacement.
If not (your lucky!) it could be that the automatic cleaning procedure which starts when a cart is changed has soaked the carts empty.
Do set machine with date and time and NEVER unplug NOR use a power switch which breaks the power supply.
Do use constant power and switch off machine by pressing stand-by-fax-button!
Everytime when machine comes to (new) power contact it runs an extensive ink cleaning procedure. thats why your carts are always near empty....
The stand-by will prevent this and machine does some cleaning procedures which consumes only a few drops(!) of ink!
The display asks you if you have changed the carts. Do answer this question by pressing 1 for YES or 2 for NO.
This will reset the built-in inkcountermanagement to the correct settings
Jan 22, 2008 | Brother MFC 210C All-In-One InkJet Printer
Only printing black and cyan
If you have used third party carts before you can't repair this problem due to the fact that the filter inside the printhead is clogged with particles. There is no chance to clean the filter. Sorry. Do use only dye ink. Pigmented ink is the printhead killer for brother printers!
Aug 25, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
51 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
