Question about Napoleon 36" Zero Clearance Top/Rear Vent Natural Gas Fireplace with Black Door
How to replace thermocouple on Napolean fireplace
Do I need a thermostat to run the Napolean gas fireplace?
you need an on/off wall switch or a remote can be easily installed. both are wired to the gas valve. you will use the TH terminal and the TH/PP terminals
Dec 19, 2014 | Pool & Spa
Where can we find thermocouple for adru richelieu fireplace?
I apologize I do not recognize the brand but since a month has passed without an answer I can tell you we have often had to find a replacement without being able to go through a manufacturer. For a fireplace we would need you to upload pictures of the control valve because it is very common for a fireplace valve to have a thermopile and not a thermocouple. If the valve has a battery pack or a electrical plug then the chances are that you have a thermocouple but if there is not an external power source the flame is probably heating a thermopile in order to generate the power needed for the controls.
If that is the case you would need to physically bring it to a shop to be tested for the proper amount of power needed because thermopiles can have a tremendous range.
Oct 23, 2014 | World Marketing 24-3508P Thermocouple Vent...
Gas fireplace will not light up
If it has a pilot light, (website says it does) I suspect its the thermocouple. These are easy to change yourself and cheap, you can buy a universal thermocouple and it will be cheaper than a Napolean one. The end of the thermocouple is a fat copper pin that sits poking into a small pilot flame. The heat of the flame on the copper tells the system that the gas is burning ok so it allows more gas through. But after a few years the copper end gets covered in black charring and this slightly insulates it from the heat, so it signals to turn off the gas.
Dec 15, 2013 | Napoleon Fireplaces Napoleon IR3N 24000...
Pilot light wont stay lit on gas logs
If the pilot lite comes on, but will not stay on after it has had enough time to heat the thermocouple, you got a bad or the wrong thermocouple. It does take some time to heat that thermocouple.
Nov 26, 2013 | Woodland Direct CD Vent Free Gas Log Set...
Napolean fireplace burner wont light
If your pilot is running fine, but your burner will not light:
  • You may have a bad thermopile.
  • There may be blockage in the burner orifice.
You can test the voltage of the thermopile per your owner's manual (replace if necessary).
You can clean out the burner orifice with some compressed air.
Nov 15, 2012 | Pool & Spa
We have not turned the heater on since 2010. it is a gas with fake logs.A rennai flame fire inbuilt standards. Husband says the thermacouple is not working? what do you recommend?
Stephanie, I 'm not sure how it was determined, that your direct-vent gas fireplace needs a Thermocouple? As a dirty pilot light will also mimic a faulty thermocouple. In addition, if the fire hasn't been used since Winter of last tear, and the gas line to the unit has been turned OFF since then, the air in the gas line must be purge, before the Pilot will light and hold.
If all of the above can safely be ruled out, then the thermocouple should be replaced. The facing of the fireplace will have to be removed, to access the Thermocouple.and it's connections to the gas control valve. You didn't mention which Rinnai Gas Fireplace you have, but most if their units, use Thermocouple part # 90193475. If you're going to replace it, it would be a good idea to also replace the Thermocouple Retainer, part # 9377.
I hope this helps you to further troubleshoot and solve the problem. Please let me know. Thanks.
Jun 21, 2011 | Rinnai Heating & Cooling
My Pyromaster Gas Fireplace Pilot will not stay lit
Try cleaning the thermocouple with sandpaper or wirebrush. Sometimes it gets dirty and doesn't sense the flame.
Dec 11, 2010 | Stoves Heating & Cooling
I have a Marco Natural Gas Direct Vent Fireplace that you turn on with a wall switch. Lately it will not light when the switch is turned on, this happens about 50% of the time. It is not the switch because...
The only thing a fireplace like your has that could be faulty is the thermocouple or safety switch on the gas valve.
A thermocouple is a likely suspect. Look in your manual for a part number and buy a replacement. Cleaning the old one might work too if it is heavily coated with carbon.
Dec 16, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Need thermocoupler for GTI Gas Technology fireplace insert
Contact your nearest Heat-N-Glo dealer for part #446-511 thermocouple. If you need a thermopile thats part #2103-512. To find your nearest dealer go to www.heatnglo.com
Dec 27, 2008 | Leisure HOMEPRIDE Electric Fireplace...
FIRE GOES OUT AFTER AWHILE
Hi clean pilot light check out thermocouple might need new one
Nov 14, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Napoleon 36" Zero Clearance Top/Rear Vent Natural Gas Fireplace with Black Door Logo
180 people viewed this question
Top Napoleon Pool & Spa Experts
paulcarew
Gene Haynes
Dan Webster
Dan Webster
Are you a Napoleon Pool and Spa Expert? Answer questions, earn points and help others
