Question about Miele Premier-Plus Built-in Dishwasher
I have an Optima series G1470 or G2470 dishwasher with a heavy panel on the front to match the kitchen cabinets. I want to tighten the door spring so I can open it more gently. House guests tend to let go of the door part way down and it bangs open the rest of the way. Also, I have not put salt in. Do I need to in Wisconsin? If so, what kind of salt do I use? Thanks, MJ
  • docjay Sep 12, 2010
    Actually I have a HG03 series so the advice was not appropriate but I was able to find that manual and found that the adjustment in below the door, not above it.
  • Miele Master
  • 3,247 Answers
About the use of salt depending on water hardness, there is a very good explanation on page 11 the manual of the features available in this dishwasher to check the hardness of water and when to use salt.
Morton are a reputable company providing different type so salts. You should check out this site and contact them if necessary.
About the door springs, here are a few things you can do including making sure the dishwasher is level as per the installation instructions. Try page 28 of this instruction. (It is for a different model but should indicate what you need). If the adjustment is not adequate then you may need to contact Miele as the panel may be too heavy.
Hope all this helps.
Posted on Sep 12, 2010
Simpson Silencio 850 dishwasher,model No. 52B850SH A lot of times after a wash cycle has finished the dishwasher does not empty out all the water and leaks out water from somewhere onto the floor in front...
Hello.
Is there a puddle in front of your dishwasher? Often this is a relatively easy problem to solve. At best, all you need to do is tighten a few fittings or level the dishwasher so water doesn't slosh out when the machine is running. At worst, you may need to replace a door gasket.
Instructions
Tools Needed to solve the problem.
Worm-drive Hose Clamp,Adjustable Pliers,Adjustable Wrench, Replacement Door Gasket, Screwdriver,Small Level
Tightening the fittings
1 Remove the service panel that runs along the front of the dishwasher just below the door. If it is screwed in place, remove the screws with a screwdriver. If the panel hangs on hooks, pull the panel out and swing it up to remove it from the hooks.
2 Check the end of the drain hose that connects to the dishwasher. If it's leaking, tighten the clamp with a screwdriver.
3 Check the drain hose connection to the kitchen sink drain. Again, if it's leaking, tighten the clamp with a screwdriver.
4 Check for leaks around the water-inlet valve. If necessary, use an adjustable wrench to tighten the compression fitting that connects the water-supply line to the valve. If the fill hose is leaking, replace the spring clamp that is on the hose with a worm-drive hose clamp. It produces more clamping pressure. Use adjustable pliers to compress the spring clamp so you can pull the clamp and hose off the valve. Remove the spring clamp from the hose. Buy a worm-drive clamp at your hardware store, then install it and tighten it with a screwdriver.
Leveling the machine
1 Remove the front access panel (see step 1, "Tightening the fittings"). This will give you access to the dishwasher's adjustable feet.
2 Open the door completely and remove the bottom dish rack.
3 Unscrew the dishwasher from the kitchen countertop so the dishwasher can move freely as you adjust the feet.
4 Check to see if the dishwasher is level side to side. Place a small level inside the dishwasher so it's sitting on the bottom pan and facing parallel to the front lip of the dishwasher. If the dishwasher is not level, use adjustable pliers to turn one of the dishwasher's front feet up or down until you hit level.
5 Check to see if the dishwasher is level front to back. Turn the level perpendicular to the door, and place it on one of the bottom ledges that run along the side of the cabinet. Check the level again. If the dishwasher isn't level, use your adjustable pliers to turn the back feet up or down until you hit level.
6 Reattach the dishwasher to the countertop and reinstall the front access panel.
Fixing a leaking door
1 Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely
2 If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
3Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
4 Pull the old gasket out of its groove, using adjustable pliers (see illustration). Take the gasket to an appliance store to get a replacement.
5 Soak the new gasket in warm water to soften it, then press it into the groove. Start at the top, then work your way down the sides and across the bottom.
Thanks
Oct 30, 2011 | Dishwashers
We are having water leak from the bottom of our Roper Dishwasher door. THe model # is RUD5750DG3. I have taken the inside door frame off and found a small white rubber seal had dislodged inside. i...
Step 1:
Step 2:
Step 3:
Step 4:
221_a1.jpg Check for leaks around the water-inlet valve. If necessary, use an adjustable wrench to tighten the compression fitting that connects the water-supply line to the valve. If the fill hose is leaking, replace the spring clamp that is on the hose with a worm-drive hose clamp. It produces more clamping pressure. Use adjustable pliers to compress the spring clamp so you can pull the clamp and hose off the valve. Remove the spring clamp from the hose. Buy a worm-drive clamp at your hardware store, then install it and tighten it with a screwdriver.
Leveling the machine Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Fixing a leaking door Step 1:
Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
Step 2:
Step 3:
Step 4:
Step 5:
Apr 06, 2008 | Dishwashers
Sometimes after a wash cycle which has cleaned the dishes etc my Simpson Silencio 850 dishwasher does not empty out all the water and also leaves lots of water on the floor in front of the machine. How do...
Hello.
Instructions And Tools Needed to solve the problem.
Thanks.
Oct 29, 2011 | Dishwashers
Water leaking at the bottom of the door
1 Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
3 Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
Nov 24, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Dishwasher door drops hard when opened.
Sounds like one of the doors springs is broken or has come detached from the dishwasher housing frame. If you have a plain dishwasher door, ie one that does not have a wood panel matching your cabinets, and the spring(s) are broken, new springs cost about $20. If you have wood panel on the dishwasher door, then you may need heavy duty replacement spring at about $22.
Jan 15, 2010 | GE Dishwashers
Water leaking under dishwasher, around motor
hi friend,
  1. Step 1 Remove the service panel that runs along the front of the dishwasher just below the door. If it is screwed in place, remove the screws with a screwdriver. If the panel hangs on hooks, pull the panel out and swing it up to remove it from the hooks.
  2. Step 2 Check the end of the drain hose that connects to the dishwasher. If it's leaking, tighten the clamp with a screwdriver.
  3. Step 3 Check the drain hose connection to the kitchen sink drain. Again, if it's leaking, tighten the clamp with a screwdriver.
  4. Step 4221_a1.jpg Check for leaks around the water-inlet valve. If necessary, use an adjustable wrench to tighten the compression fitting that connects the water-supply line to the valve. If the fill hose is leaking, replace the spring clamp that is on the hose with a worm-drive hose clamp. It produces more clamping pressure. Use adjustable pliers to compress the spring clamp so you can pull the clamp and hose off the valve. Remove the spring clamp from the hose. Buy a worm-drive clamp at your hardware store, then install it and tighten it with a screwdriver.
  5. Leveling the machine
  6. Step 1 Remove the front access panel (see step 1, "Tightening the fittings"). This will give you access to the dishwasher's adjustable feet.
  7. Step 2 Open the door completely and remove the bottom dish rack.
  8. Step 3 Unscrew the dishwasher from the kitchen countertop so the dishwasher can move freely as you adjust the feet.
  9. Step 4 Check to see if the dishwasher is level side to side. Place a small level inside the dishwasher so it's sitting on the bottom pan and facing parallel to the front lip of the dishwasher. If the dishwasher is not level, use adjustable pliers to turn one of the dishwasher's front feet up or down until you hit level.
  10. Step 5 Check to see if the dishwasher is level front to back. Turn the level perpendicular to the door, and place it on one of the bottom ledges that run along the side of the cabinet. Check the level again. If the dishwasher isn't level, use your adjustable pliers to turn the back feet up or down until you hit level.
  11. Step 6 Reattach the dishwasher to the countertop and reinstall the front access panel.
  12. Fixing a leaking door
  13. Step 1 Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
  14. Step 2 If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
  15. Step 3 Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
  16. Step 4 Pull the old gasket out of its groove, using adjustable pliers (see illustration). Take the gasket to an appliance store to get a replacement.
  17. Step 5 Soak the new gasket in warm water to soften it, then press it into the groove. Start at the top, then work your way down the sides and across the bottom.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
  • If your dishwasher has an air gap, which prevents dirty water from re-entering the machine, clean it regularly. Otherwise, it could overflow and leak.
  • Always use detergent that's made for your dishwasher. Dishwashing liquids and other soaps can create excessive suds that will leak from the machine.
  • Occasionally, the main seal between the dishwasher cabinet and the pump fails. If your dishwasher leaks at this spot, have a professional replace the seal.
Who Can Help Sponsored hope this helps u
please rate me.....................
thank u for using fixya
regards
sivaranjini
Nov 30, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
I want to fit a wooden door to a intagrated dishwasher stoves
If your dishwashermag-glass_10x10.gif door is not closing properly or has developed a leak, it may be time to replace the entire door assembly. Some other signs of a defective door include sagging, difficulty pulling the door back up into a closed position and a door that feels heavier as it drops open. Replacing a dishwasher door is not that hard, but includes several springs and hinges that must be aligned correctly or the door will not fit correctly in the opening.
  1. tep 1 Unplug the dishwasher and shut off the water before attempting to remove any parts. If you cannot reach the electrical outlet, you can turn off the breaker switch that controls the electricity for the kitchen. Remove the drain hose that runs from the dishwasher unit to the sink drain.
  2. Step 2 Pull the dishwasher out from the cabinet until you have clear access to the side of the unit. Ask a friend for help with this part if the unit is too heavy for you to slide out without straining your back.
  3. Step 3 Check your dishwasher's owner's manual to find out exactly how the outer door panels are removed. Some models have a two-panel door where the control panel must be removed before the lower panel will come off. Otherwise, the door panel should be one solid piece or a two-piece assembly that allows the lower section to be removed separately to access the springs and hinges.
  4. Step 4 Remove the springs at the bottom of the door. Depending on the type of dishwasher you have, there may be a tension adjustment dial or simply a series of holes at different distances from the edge of the unit. If you have a tension controller, adjust it to a loose setting to make it easier to remove the door springs. Unhook the door springs from the hinge plate. Some dishwashersmag-glass_10x10.gif may have a cable and pulley system attached to the door springs. Check your owner's manual for removal instructions if this is the case with your model.
  5. Step 5 Use pliers to gently pull back on the door hinge plate's tab until the slot opens for the hinge pin to come out. Take out the screws holding the door hinge plate onto the front of the door panel. Hold onto the door assembly while gradually opening the door. Once the door drops down, you should be able to remove it by sliding the door off the hinge pinAlways wear safety glasses when working with the springs and hinges involved with a dishwasher door assembly. These items can fly off at high speed and cause serious injury to the eye.
Nov 15, 2009 | Stoves 27 in. DW60 Built-in Dishwasher
Need stronger Door Springs, to able wood door panel
The best suggestion I could give you is contact either Sears or Bosch and ask for recommendations. You will require the proper springs designed for dishwashers.
Feb 03, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
How to make a panel, install it and a handle for Kitchen Aid model KUDU03FTPA panel ready dishwasher
Hello babies5 what it means by panel ready is a cabinet door style front to match the cabinets. I have installed many of these panels, however they where always supplied by the cabinet shop who built the cabinets. As to handle, that also always matched the cabinet pulls on the rest of the kitchen. The idea of this unit is to hide the dishwasher. In my kitchen, simple doors, so I would use 3/4 inch plywood and paint it white with the same pulls as my current doors and drawers have.
May 10, 2008 | Dishwashers
Miele Premier-Plus Built-in Dishwasher Logo
274 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
