Hi, I'd like to use a blue-ray DVD player to play movies on my JVC-48WP55. But the TV set does not have a HDMI plug. What's the best solution in this case? Thanks! Ben
  • 201 Answers
Check plugs on back of set. most likely you have component (green,blue and red). That will give you 1080i resolution. Of course that's not as good as the 1080p coming out of the bluray but at least it will be high def.
Posted on Sep 11, 2010
#dhb300b DVD player plays only black and white my TV is a JVC HD TV with HDMI cable from driver TV box hook up DVD to TV audivo to audivo video to video set TV to component program DVD to TV but plats
The yellow/red/white cables are COMPOSITE cables. COMPONENT cables are RED/BLUE/GREEN. You can buy those at any electronics store. Your best bet, though, is to stick with HDMI if you can.
Jan 21, 2015 | JVC Televison & Video
When you chose the settings menu what do you chose to set the tv to hdmi to get the dvd/blue ray player to play
There are two HDMI inputs on your TV, so, depending on which input the DVD player is plugged into, HDMI 1 or 2 , that's the one you choose. The menu should list the inputs as HDMI 1 and HDMI 2.
May 19, 2014 | Emerson LC320EM9 32 in. LCD HDTV
Why wont my samsung dvd-vr357 play blu ray disks
Educated guess is you need a blu ray player. I have several very expensive Pioneer Elite DVD players and they cannot play blu ray. Blu ray is a multi level glorified DVD which you need at least a blu ray player to play in almost all cases.
You can play dvds on a blue ray but not the reverse in most cases. If you play a dvd on a blu ray player it kicks the video up to HD for the DVD.
Apr 14, 2014 | Televison & Video
I am not getting sound on my JVC DVD player
What connection are you using to connect to your TV/Receiver?
If it is HDMI
  • Make sure you go into your DVD settings and select enable audio through HDMI
If you are using Component (red/green/blue) or Composite(Yellow RCA)
  • Make sure you connect the Audio out (red/White) RCA connectors as well
If these solutions do not help, please prive the model# of the DVD player along with what type of connections you are using as well as what you are plugging them into (TV model/Receiver model etc)
I hope this helps,
Magoo
Mar 11, 2011 | JVC Televison & Video
How to connect Blu ray disc player with my Bose 321 system. I have 1080 p samsung LCD TV. How to get the best.
hi,
do the following.
1. connect ur blue rays hdmi out to ur tvs hdmi input.
2. connct blue rays out to any one of the coaxial(aux) input of bose.
3. connect ur tvs optical audio output to optical audio input of bose
4. connect monitor out of ur bose to any one of ur av in of ur tv. connect component video to better quality .
4 . in the blue rays audio setup select audio output priority as optical/coaxial
5 . in bose set aux as digital input.
to see blue ray select hdmi of ur tv, sellect in bose in which the blue rays coaxial is connected(aux) insert disk in blue ray an watch
to see dvd in bose select tvs corresponding input, select bose to dvd . insert dvd and watch
to whach tv program set tv to corresponding mode. set bose to optical audio input mode.
ok
Dec 15, 2010 | Televison & Video
Blue ray disc plays on laptop but not on tv with hdmi connected
probably tells you that the current display settings dont work with player. try this, power off(shutdown pc) completely and disconnect hdmi cable. now, with tv on, plug the hdmi cable to pc and power up. it should recognize the tv and run the movie properly.
Jan 31, 2010 | Sony VAIO Notebook
I just purchased a Sony DVD player...DVP-SR200P. Plugged it in and have no color...movies play in black and white only.
Hello cherylsacket,
Check your cables to your TV. If possible check the various cables to your set. I would suggest using the HDMI cable if your TV has an HDMI input. Remember to power off all devices before connecting your cables. If I may ask which cable are you using to connect between your Tv and the DVD player?
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
May 10, 2009 | Sony DVP-NS700P DVD Player
Is the hitachi 46W500 blue ray compatible
It doesn't have an HDMI port, only a DVI port. You'd have to get an HDMI-to-DVI cable to get a true "digital" signal on the screen, but you'd still have to do your audio with the RCA jacks because DVI is video only whereas HDMI is audio and video.
As far as Blu-ray compatible, yes and no. It's a high-def TV, so if you hook a Blu-Ray player up to it you'll be in good shape but the built-in DVD player will not read or play Blu-Ray movies.
Dec 31, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
Need help setting up DVD-VR375 with compatible SAMSUNG TV
if it has component (red, blue, green) cables, plug one set into dvd player's "in's" and tv sets "out's'. you may have to play with the tv channels to be able to watch movie. you just change channels, go from "3" backward until you find a picture and sound.
Sep 01, 2008 | Samsung DVD-VR357
Jvc dvd player
seems like you put an NTSC dvd movie in there and the machine is set to Pal or the other way around. you need to program your computer to multi region setting. check the website for the unlock region codes. good luck
Mar 16, 2008 | JVC XV-S302 DVD Player
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
