When i go on my hdmi channel on my tevion tv it says input not supported please help me
SOURCE: WHEN USING HDMI INPUTS,WHY DOES T.V. SHOW FORMAT
Ok, there are differing HDMI "Standards" not all TV's play/use all HDMI "Standards". Please have a look at this WiKi it explains far more than can be done here.
http://en.wikipedia.org/wiki/HDMI
Posted on Jan 22, 2010
lukster
  • 217 Answers
SOURCE: HDMI INPUT FOR NON HIGH DEF CHANNELS WILL NOT DISPLAY FULL SCREEN
if you have a cable box then it is probably the resolution settings in the cable box, what type of cable box do you have
Posted on Jul 20, 2008
SOURCE: HDMI Problem
check your owners manual tv. my tv has 3 hdmi input.your tv manual will tell you which one to use. make sure you select the correct resolution. 1080p/720/480 etc. oh...make sure you have hdmi cables too
Posted on Dec 08, 2008
opherator
  • 44 Answers
SOURCE: PS3 will not work on new tv using HDMI cable ?
you have to re sync your playstation when you go from HDMI to regular wires.
after you connect ps3 to tv.
hold down the power buttondown on the ps3 for like 5 seconds (1 beep then another ),
after you hear a second beep the ps3 automoatically adjusts itself to whatever it's connected to.
Posted on Feb 27, 2009
  • 304 Answers
SOURCE: My tv keeps turning off and changing channels.
You have a bad Main bd.
Posted on Jul 17, 2009
Trying to set up my new elements tv with a uverse wireless box. Did a channel scan but still can't find any channels. Help please!!
Is this a high def tv? Are you using an hdmi cable, component cable(red green & blue) or a low def coax cable to connect the tv? If coax, the tv needs to be on channel 3 or 4. If hdmi or component cable is used you need to change your input on the tv with your remote to the matching input you wired it to. The uverse stb (set top box) changes the actual channels once you have selected the correct input.
Jun 26, 2014 | Televison & Video
Need a code for a tevion lcd 32081D to activate sky remote
Hello
Check these codes.
Tevion
TV66SIL
065
Tevion
1530, 3731VT, MD3731VT
696
Sky+ Remote Control Unit Programming Procedure Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
* If this works try the other TV functions.
* If these work then the correct code has been selected.
* It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button
OK.
Oct 16, 2011 | Televison & Video
We have been given a ps3 with no instruction leaflet. we have attached the ps3 to the tv but are not getting a picture can you please help? Thank you very much
I am providing the link for you to download the owners manual. depending on how its hooked up will determine the channel your tv needs to be on. If you are using Composite(red,white,yellow) then you need to put the tv on Input, If your using component cables(red,blue,green then red and white) your tv will need to be put on component channel. If your using HDMI then obviously it needs to be on channel labeled HDMI. If you had to use an RF modulator with coaxil cable then the tv needs to be on channel 3 or 4 depending wht you set it for. If this helps please rate me. I do not get paid for this but I like helping
. Here is the link.
http://us.playstation.com/support/manuals/ps3/
Dec 17, 2010 | Sony Video Game Consoles & Games
How do i get on the HDMI input channel?
Hello Jeff. I just have a basic question for you. Was the Blu Ray player turned on when you first plugged it into the tv? TV's are becoming so complicated that they are becoming less user friendly. Try setting your tv to the first HDMI input using your tv remote's input button. Then unplug the HDMI cable from the tv, make sure the player is turned on then plug the HDMI cable into the left most input if horizontal or top input if vertical. Hopefully if you do that and have the input selected, it should work for you.
Also: Whi9le attaching the cable, I find it helpful to have it in a position where I can see the tv, because when a device hooks up the screen usually flashes or turns blue or something similar.
Hope this helped
-Chris
May 01, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Unable to use PS3 on HD channel
1. Connect PS3 to your TV
2. Select the Correct HDMI input on your TV
3. Press and hold the [power] button on the PS3
4. perform setup.
These are the steps to setup the video output for the PS3, It is possible that it is set to a resolution that your TV does not support.
If this doesn't work, you may want to contact Sanyo to ask if they have some protection circuit for the HDMI input. Some manufactures TV's will deactivate(turn OFF) the HDMI input under certain conditions. Unplugging the TV or some other procedure usually turns it back ON.
Apr 29, 2009 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
How to find pc channel
This information is from the owners manual of you television it is on page 12. Signal source selection: Press the [input ] button to select TV, AV, S-Video,Component,VGA and HDMI inputs. There are two way to select the source: One is to press the [input ] button continuously, while the other is to use the up and down arrow and enter buttons to confirm the input. If this information does not help you, call the customer support at this telephone number. 1-888-935-8880. The website is.http://www.elementelectronics.com/support.html I hope this information helps you with your problem.
Apr 27, 2009 | Element ELC-HS321 32 in. LCD TV
Video channel
if your DVD player supports a HDMI cable a single cable is enough for both audio and video channel.
but both your player and TV must support HDMI.
Aug 12, 2008 | Samsung DVD-V4600 DVD Player/VCR
HDMI input
This confused me when I first got this tv. The inputs (HDMI, CVI, etc.) are more like channels. Go to channel 2 and the keep flipping down the channels. You will see HDMI just below channel 2.
May 19, 2008 | Philips 30PW8420 TV
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
Electro Med Services...
