Question about Hammering
While hired person to fix my deck, from where the cord was plugged into the electrical socket, it messed up the system. I can get that circuit breaker to light the lights in the porch, but the socket used is still out of order. It seems to connect to a room downstairs, where a socket is also out.
  • 56 Answers
Try to check for a GFI receptacle somewhere in or outside the house. It probally has tripped out and just needs to be reset
Posted on Sep 30, 2010
Why the circuit breaker keep trowing off ?
Could be a short in the cord somewhere. This will keep tripping the breaker. If you can check the socket and plug for loose wires or check for damage along the cord.
Jul 25, 2014 | Rule 1800 H53SP-24 Swimming Pool Cover...
Composite decking is cracking and peeling off
Hire a reputable contractor
Mar 25, 2014 | Garden
Precor 9,31 treadmill tripping internal breaker
You may want to check how many outlets or other items that you have on the breaker. When those treadmills go faster, they draw a lot of amperage. Not much that you can do except for unplugging what you aren't using on that circuit until you are done. If you run an extension cord to another circuit, that draws even more amperage or hire an electrician to install a larger breaker for you.
Jul 10, 2017 | Exercise & Fitness
What does it mean when a gas cooker needs hardwiring
It means that it does not have a cord and a plug to just plug it into a wall socket...
It needs to be "hardwired" into the electrical circuit with a regular piece of wire...
heatman101
Dec 13, 2010 | New World G60m Gas Single Oven
The socket next to my washer was used to put in an extension cord to fix my deck with a power saw. The socket is still out, but the breaker works for then lights there.
Usually the washer circuit is a seperate 20A circuit. The lights would be on a different circuit usually 15A. Check your panel and see if there is a 20 breaker tripped. Hopefully your panel is labeled (or it should be) Are you saying this tripped while using the extension cord? Another possibility is that it is controlled by a GFCI outlet. You can connect additional receptacles to a GFCI outlet to protect them. Check to see if you have a GFCI receptacle tripped (in garage, bathrrom etc)
Sep 11, 2010 | Gb Electrical 1 30 Amp Ground Fault...
I need a hook up digram fof an optimus model 31-2025 stereo equalizer
http://support.radioshack.com/support_audio/doc48/48943.htm
Ten-Band Stereo Frequency
Equalizer (310-2025) Connections Faxback Doc. # 48943
Follow these steps to connect the equalizer to your audio system.
CAUTIONS: Use only shielded audio cable with RCA-type connectors (not
supplied). This type of cable is available at your local
RadioShack store.
Before you connect the equalizer, turn off all components in
your audio system and unplug their power cords.
Before you plug in the equalizer's power cord, complete all
connections and be sure the equalizer's POWER button is out.
1. To connect the equalizer to your receiver, connect the receiver's TAPE
OUT jacks to the equalizer's MAIN IN jacks.
Then, connect the equalizer's MAIN OUT jacks to your receiver's TAPE
IN or TAPE MONITOR jacks.
2. You can connect a tape deck to each set of tape jacks (TAPE 1 and TAPE
2) on the back of the equalizer.
To connect each tape deck, connect the equalizer's TAPE OUT jacks to
the tape deck's in jacks. Then, connect the tape deck's out jacks to
the equalizer's TAPE IN jacks.
3. Plug the equalizer's power cord into your receiver's switched power
outlet or any standard AC outlet.
WARNING: The equalizer's power cord has a polarized plug. To prevent
electric shock, do not use an extension cord or other
receptacle unless you can fully and easily insert the plug's
blades.
4. Connect the power cords of all other components.
(wr 08/04/98)
Feb 24, 2010 | Audio Players & Recorders
My pioneer djm-500 mixer seems to have an electrical short
i had my decks fixed by these guys they are in london.
thier websites is www.technics1210repair.co.uk
they do PIONEER MIXER REPAIR
check them out.
im only spreading the word due it i had my decks fixed their and i am so pleased im telling everyone so they can get the same service i did, rather than paying over the odds at some **** toster repair shop.
alan
Sep 14, 2009 | Pioneer DJm500 Professional DJ Mixer...
Loud buzzing when amp connects to guitar
Is there a loose connection anywhere?
Jan 03, 2009 | Music
Problem with electrical source
Does your manuel also tell you to use a DEDICATED 20amp circuit to plug your Microwave in to? More that likely you used a 15 amp circuit that other appliances were also plugged into. A refrigerator or other cooling item needs its own 15 amp circuit but can tolerate small amp draw items like a clock. The new, higher wattage microwaves need a 20 amp circuit for itself. Have your line checked , have your microwave fixed. Start new
Aug 26, 2008 | Microwave Ovens
Raplacing the dryer cord coz my new home has a different socket
If you remove the cover plate on the dryer directly where the cord is entering the dryer.........If there isn't access there ,I could help you through it but first need a model number.
Jun 20, 2008 | Frigidaire GLER642A Electric Dryer
Hammering Logo
135 people viewed this question
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
