Question about Water Heaters
We have a manufactured home and it has a rheem warrior glass model #71-40DB. 50 gal. Does it have a glass tank? It is aprox. 10 years old, when do you recom. we change it out. We are not having any problems.
    Novelist:
  • 120 Answers
The glass is actually enamel that is coating the inside of the tank. It depends on your water quality and how hot you run it as to how long the tank lasts. Ten years is doing well, I would leave it alone until you have a problem. Kep an eye on your power bills, if it starts to go up that could be a sign that the tank suffering.
Posted on Sep 14, 2010
User manual for Rheem 21V30DV
1) 21V30DV is 2006 6-year mobile home (manufactured housing) natural-gas, atmospheric-vent water heater
2006 Manual does not show on internet.
Replaced by Warrior series
http://www.rheem.com/documents/warrior-dvx-warrior-dvx-use-and-care
http://hometips.me/Mar/Mobile-home-water-heater-illustration.pdf
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Add comment with specific question for possible help.
Mar 02, 2013 | Rheem Water Heaters
Where is the combustion shutoff system on a Rheem 30 gal moble home hot water heater
Disproportionate number of water heater problems are Rheem-related, yet Rheem is just 1 of 3 major water heater manufacturers.
If you have Rheem tank-type gas water heater, and the combustion shut off has tripped the FV system, then there is a broken glass vial located under the burner.
Rheem does not post service manuals, and they may or may not send the glass vial for replacement. Depending on model which appears on label on side of tank. Year of manufacture are 3rd and 4th digits in serial number.
And they may want you to contact a qualified service technician (plumber)
You will have to replace glass vial, and clean the arrestor screen and clean the combustion parts, check gas pressure, and check venting.
Other companies post service manuals and do not rely on the glass vial.
Copy following links:
http://waterheatertimer.org/How-to-repair-Rheem-TRD.html
http://waterheatertimer.org/How-to-replace-thermocouple.html
Sep 09, 2012 | Rheem 40 Gallon FVR NATGAS Low WATER...
Rheem warrior glass serial num r0296b08705 model
You need to first determine if the burners light or not.
As long as the unit wasn't run with a dry tank the unit should not have been affected by continuous water running, unless it got hot enough to damage the thermocoupler which is an easy replacement. That is the part that your pilot/ignitor warms so that the gas valve will open the gas line to the burners.
Aug 12, 2011 | Rheem Single Water Heater Thermostat
The water won't get hot on model 81v52s 50 gallon. is there a rest or how to diagnose.
The reset button is located behind top panel on water heater.
If you have some hot water, then reset is not tripped, and tank has different problem.
I suggest a complete 30-minute troubleshoot using multi-meter from hardware or home center.
When test calls for checking voltage, rotate multimeter dial to 240-250-277 VAC
When test calls for continuity or testing elements, rotate multimeter dial to Ohms
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Follow troubleshooting steps from top of page to bottom, and water heater if fully repairable by homeowner.
See label on side of tank for wattage of element.
Second two digits on Rheem serial number are year of manufacture.
Shown below are Rheem 4500 Watt element and Generic upper thermostat.
Add a comment if you need more free help.
Also take advantage of fixya phone service.
For a price, fixya expert walks you through repair steps over the phone.
Dec 31, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
TRYING TO REPLACE MY OLD RHEEM WATER HEATER MODEL NUMBER 81V52D C SERIAL NUMBER RH 1297B30669 50 GAL US TANK ELECTRIC WHAT IS THE UPDATED VERSION?
I would say your water heater is from the fury series; new model number 82V52-2. I've included a link with my solution that you should take a look at. You could also look at water heaters of a different brand if this one isn't available in your area. Kenmore, GE, and Hotpoint are all very good brands of water heaters.
http://www.rheem.com/product.aspx?id=09DF2BDD-5E11-4D32-B574-84ACFB8A4619
May 25, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Sounds like a squirrel inside water heater
Check your thremostat setting if it is set to highest position it may be causing some of the noise over heating the water and making the noise. And you can put an insulated jacket on it to maybe help with sound.
May 14, 2010 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
Rheem Warrior glass hot water tank odel
Hello, cracklin. Now that everyone has told you what it is, I wil tell you how to fixit, sense we are a fixit site.
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about hot waterheaters and possibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/water-heater.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Jan 07, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rheem power vent motor doesn't shut off
There could be blockage in your water heaters venting on the outside of the home. It sound like the high limit switch has been tripped. Try unplugging the tank and plugging it back in. this will reset the tank. if the problem persists you will want to call your provider for service.
Oct 07, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rheem 50 Gal Hot Water Heater will not stay lit
On the back of the gas valve (where you turn the temp up) there is a stem that actually goes into the tank that senses the temprature of the water it could be dirty or buried in sediment depending on how old the tank is, or just bad. if the tank is over 10 years old i wouldn't bother replacing the gas valve, the tank is probably not far behind. A new valve will run around $100.00 maybe a little less. You wont find it at menards or home depot in stock but they may be able to order it for you. Menards sells rheem products or try you local plumbing supply house. REMEMBER TO RELIEVE THE PRESSURE ON THE TANK BEFORE YOU WORK ON IT. IF YOU CHANGE THE VALVE DRAIN IT FIRST!
Feb 10, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water Heaters Logo
338 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
